I prefer my reQuests to the little JBLs when listening critically at the sweet spot.
Initial impression switching back and forth is that the panel has a smaller dimmer image, the JBL a little more brilliant and spread out.
But as I continue to listen, the JBL sounds artificial, too much happening off to the sides (maybe my room isn't dead enough), where the panels take on the sensation of listening a little farther away. The "image" turns out to be just as big, or bigger, more like "life size" but at a more appropriate distance than the more "in your face" of the JBL.
Since it seems less loud, maybe you turn it up a few decibels, and then it really comes into its own.
I suppose it is preference, or acclimatization, or any number of other excuses, but I like it better.
Often, when a writer reviews some latest/greatest speaker, there will be a reference to electrostats/panels.
Even Kal did it in his recent Beolab 90 Review:
"In Wide mode, the BeoLab 90s sounded like very good conventional loudspeakers, with a two-channel sound that was on a par with the best I've heard in this room: well balanced, with powerful, extended bass and wide, deep soundstages. However, when I switched to Narrow mode, it became apparent that the standard stereo presentation of Wide mode—and, indeed, of most other pairs of speakers I've used—was flawed. Narrow mode simply erased a hash of spurious ambience that flanked the central soundstage. That hash exaggerated the width, and contributed to the impression of "audiophile air." Also, in Narrow mode, the stereo image snapped into a new level of precise stability.
In Narrow mode, the BeoLabs delivered what I heard as increased resolution, detail, and tonal honesty, unsullied by the interference of short-latency reflections. Users of dipole speakers, in which the interference of the outputs of the front and rear drivers causes cancellation of lateral dispersion, will have experienced something similar—but not to this degree. From that point on, I used Wide mode mostly to demonstrate to myself and to others just how remarkable the BeoLab 90s could sound in Narrow mode, in which I did all of my critical listening."
I consider my little JBLs to correspond to "wide mode" and the Martin Logans to correspond, perhaps to a lesser degree (as he put it), to his preferred "narrow mode".
Again.
"Narrow mode simply erased a hash of spurious ambience that flanked the central soundstage. That hash exaggerated the width, and contributed to the impression of "audiophile air." Also, in Narrow mode, the stereo image snapped into a new level of precise stability."
"In Narrow mode, the BeoLabs delivered what I heard as increased resolution, detail, and tonal honesty, unsullied by the interference of short-latency reflections. Users of dipole speakers, in which the interference of the outputs of the front and rear drivers causes cancellation of lateral dispersion, will have experienced something similar—but not to this degree."
That's as good an explanation as I could give.
Short-Latency reflections in my room - hash, as Kal names it:
Red, JBL. Blue, MartinLogan, impulse response, 40ms time range:
1-2ms - reflection at couch - microphone on a small desk stand on the top of the couch behind where my head would be.
7ms - blue - dipole reflection off front wall - very low amplitude (5%) compared to direct (100%) sound
25ms - blue - sound has traveled down the room, and back, and is reflected off the front wall (behind the speakers) and back to the mic.
red - who knows? reflections from walls, ceiling, floor, all contributing to the "sound energy" but reducing (my opinion) the clarity/focus of the direct sound. Amplitude is much higher (25 and 30% seen) compared to direct sound (100%).
