Yes, you can use the Scaler to amplify voltages to the ADC's input sensitivity.For example for very low DAC output voltage , like 1Vrms - Scaler is a good option?
The Scaler's very high input impedance of 200/100kΩ (Bal/Unbal) acts as a buffer to improve impedance bridging to the ADC.Any other advantages that Scaler would give to ADC?
If you want to test devices with high output impedance, then this will manifest as lower voltage drop and lower distortion, again: minimizing the impact that the Cosmos ADC has on your measurements.
+1
@Music1969 you only “need” the scaler if you are dealing with devices with have high output impedance and want to test frequency response. Capacitor coupled preamps for example will have a hefty bass roll off which doesn’t happen with regular amps. For a 1 kHz test tone it doesn’t matter and if you set the E1DA it’s so good in 10V mode that unless you are going for 118 dB or better SINAD, it’s fine.
The scaler acts as a buffer which addresses the bass roll off and it’s a super clean amplifier. If you are trying to measure to the 122-124 dB SINAD, perfect gain matching is critical.
MultiTone is your best tool for playing with the E1DA. There is a thread where Paul shows the automated test he did with the RME 2/4
That’s a great point. I just wanted to encourage @Music1969 to go ahead and start testing since even that example shows the distortion at a pretty low value so he’ll be OK to start playing with it and getting useful data.Actually, while your roll-off comment is entirely accurate, there's other reasons why a higher impedance for the test gear might be important. Lots of devices you might want to test could be sensitive to the load they're presented with. Low impedance might cause higher distortion. Yeah, that's not perfect, but it's a real thing in the real world.
Here's one example:
Example of 10K load versus 100K
Hi @IVX - I have been using the below adapter with Cosmos ADC.Oh yeah, looks better.
I pretty sure you use the 'Auto' setting at full CCW knob position.Also - with Cosmos Scaler - if I want to change the default 4.5Vrms auto ranger output level : where can I find instructions please?
yes i know that but that wasn't my questionI pretty sure you use the 'Auto' setting at full CCW knob position.
Input the target voltage to the Scaler's left input, then in <2 seconds, change the gain control from manual to auto five times.Archimago review said you can change default 4.5Vrms - my question is how
If you want to reset the target voltage to default, do the same with <1V at the Scaler's left input.
It'll be difficult to get the Scaler to only output from its left output.Now I have the Cosmos Scaler - should I still use this adapter with Cosmos ADC?
For example: if I have only Scaler only Left output -> this adapter -> Cosmos ADC ?
Crystal clear explanationIt'll be difficult to get the Scaler to only output from its left output.
If you input a stereo signal into the Scaler, then the output will be stereo as well.
If you input a mono signal into the Scaler's left input, then it'll output that Mono signal out of both outputs so that you don't have to switch cables around when changing between Mono and Stereo.
So while it is certainly possible to use that splitter on your picture to connect Scaler and ADC, IVX has made it so that you can use the same 3.5mm to XLR cables for both stereo and mono applications.
