Electrostatic speakers?
Duke
Princeton, Texas
Certainly if you have to hear the room you don’t want it to act as a passive equalizer.
I think we're pretty much on the same page here.
I still think the better solution is to kill the room. That will result in hearing less of the room.
"Kill the room to hear less of the room" makes intuitive sense, but arguably can have downsides. Imo an alternative approach is "work with the room".
I'll go out on a limb here and speculate that you'd prefer to hear the spatial signature on the recording rather than the spatial signature of the playback room.
If so, then you and I simply have different ideas about the best way(s) to go about accomplishing that.
Justdafactsmaam
What do you think are the downsides?
Absolutely
Quite possibly. My approach is highly directional low distortion speakers, kill the room, use the BACCH cross talk cancellation SP.
dlaloum
5 to 6 feet is the distance-from-the-wall recommendation I arrived at experimentally many years ago, and later I met Earl Geddes and began reading David Griesinger, and they both recommend 10 milliseconds reflection-free interval after the arrival of the direct sound, which corresponds to the time it takes for the backwave to arrive after bouncing off a wall 5.5 feet behind the panels. (With most dipole electrostats, the effective reflection-path-length distance would be increased if the speakers are toed-in significantly).
About fifteen years ago I started to incorporate rear-firing tweeters in my own speaker design, which imposed a reflection-path-length requirement that called for positioning the speakers fairly far out from the wall. I didn't want to impose this requirement on my customers so I started aiming the rear-firing tweeter either upwards or up-and-back at an angle, which resulted in a considerably longer reflection path length. Imo it seems to work - it seems to give the intended benefits while allowing the speakers to be placed much closer to the wall than would normally be acceptable.
This leads me to wonder whether a large enough waveguide could re-direct the backwave of an electrostat in a way that allows closer-to-the-wall placement than we can normally get away with. Harold Beveridge used waveguides in his (imo brilliant) electrostat designs, but he used them for the frontwave. Unfortunately a dedicated backwave waveguide would increase the "visual mass" of the speaker considerably, even though the net result might be less real estate being effectively occupied by the speakers.
Depending on the room layout and size, you can place them closer to the walls by angling... as soon as you angle them inwards towards the MLP, the back wave, then bounces off the back wall, then the side wall, before coming back into the center of the room ... which allows for a 1m /3ft distance from back wall...
dlaloum
Peter Walker was a genius not a fool.
His white papers on the design are available still from the 1950's Wireless World magazine.
If he could have 'got away' with building a speaker with one panel he would not have produced the 63 with four panels and the 989 with six panels.
Do you think he didn't try smaller first ?
That's how panel speakers work, very low but fast output over a large surface area.
So to reduce this to the size of a shoe box and push it up against a wall - must be magic.
Few people wish for loudspeakers the size of a door including me, that is why I bought the Martin Logan Electromotion which also claimed magical things, turned out the magic was just a marketing trick.
I believe the 989 was produced after the Walker era..., and they basically doubled the number of bass panels - which also raised the treble panels... I owned a pair of 989's for a few years.... enjoyed them hugely.
Duke
Princeton, Texas
The apparent preference for wide-and-uniform pattern speakers in controlled blind listening indicates that a fairly well-energized and spectrally-correct reflection field is generally desirable from a sound quality standpoint.
Very often "kill the room" involves aggressive use of absorption, and absorption tends to be more effective at short wavelengths than at longer ones. So unless the absorption is truly broadband, what can happen is that the spectral content of the reflections is drastically altered. The ear/brain system looks at the spectral content (specifically the overtone patterns) to correctly identify reflections as such. This can be the result: At some point before it decays into inaudibility, the reflections lose so much of their overtone content that they are no longer identifiable as "signal" and become "noise".
Imo better to start out with sufficiently narrow-pattern speakers to begin with, rather than relying on absorption that significantly alters the spectral content of the reflections.
Sweeet!! Do you have Janszens?
I am not certain that what works best with the BACCH system also works best for conventional two-channel. My understanding is that some in-room reflection energy is okay with the BACCH system as long as it is quite late-arriving and/or de-correlated (this based on e-mail exchanges with Dr. Choueri).
Let me ask you this, if you don't mind, since you have real-world experience with the BACCH that I lack:
If you were looking specifically for a loudspeaker with a radiation pattern that was optimum for the BACCH, what would you look for?
Yes! I didn't go into detail about that, but you are right.
Justdafactsmaam
This is a subject worthy of its own thread. I don’t think this conclusion is as solid as is commonly believed on this forum
Absolutely. But when it is broadband it does the trick. I’m rebuilding my dedicated room as we speak. The absorption is extremely broadband.
Dead rooms have lower noise floors. Low level signals are more easily heard as signal.
I’m opting for both
No. But I have heard them a few times. I was very impressed
I’ve preferred less room sound prior to using the BACCH. I think it’s a point of debate. There are serious experts on both sides of this fence. JJ advocates the idea that the best room is no room as well as Ethan Winer.
I don’t want this to decay into an expert pissing contest with the usual ASR suspects. But I think it’s fair to say it’s a point of legitimate disagreement
It’s “ok” but the ideal is a dead room.
The Sanders 10Es. That is what I have. It is also what Edgar uses as a reference. They are very narrow dispersion from 150 hz up. One of the knocks on them have been the “head vice” narrow sweet spot. With the BACCH head tracking the “head vice” effect is completely eliminated. Eliminated in ways that can’t be achieved without the head tracking with two channel stereo no
Matter how wide the dispersion of the speakers.
Newman
This is just battling opinions. No data?
Justdafactsmaam
Edgar and his research team at Princeton have done a great deal of actual scientific research on this and other subjects. He has plenty of data in support of his findings. It’s real science not just battling opinions
Newman
“I’ve preferred less room sound prior to BACCH” and “a point of legitimate disagreement” and “I was very impressed”. Real science :cool:.
Justdafactsmaam
“I’ve preferred less room sound prior to BACCH” and “a point of legitimate disagreement” and “I was very impressed”. Real science LOL.
Yeah, real science. Unless you think JJ is a fake scientist I think it’s fair to say his opinions on room sound are science based.
As for my preferences they are no more or less valid than yours or anyone else’s.
Duke
Princeton, Texas
Neither do I. My preference is for patterns which avoid the first ipsilateral reflections, a preference which is not supported by the Harman listening test data to the best of my knowledge. On the other hand "What speakers are preferred under these conditions?" is arguably a different question than "What do we want to do, and what's the best way to do it?"
Good for you, doing it right and using true broadband diffusion!
Agreed. Not a fan of overly dead rooms, but then I haven't tried the BACCH system.
And I respect your pre-BACCH preference as well.
I don't think you and I are in danger of descending into a pissing contest, and yes there are legitimate points on both sides. Some of it may go back to desired sweet spot width.
Superb speakers imo, and the head tracking sounds like a very worthwhile upgrade. I use time-intensity trading, with speakers designed for it.
Justdafactsmaam and I are having a conversation, not a battle. We are not disputing one another's experiences and conclusions.
misterdog
This is supposed to be a science based audio forum. What are the alleged objective problems with the JansZen speakers and where is the objective data to support them?
So here is the measured data from the Quad 989.
All I can say is that the reasons for this speaker's undoubtedly superb sound quality are not readily apparent from its measurements. I hope to explore this subject in more depth in a follow-up.—John Atkinson
When you can present any data from the Jantzen's, other than
These may be the answer
Or
Then maybe an objective discussion may be had.
Until then you just sound like a marketing sock puppet for Jantzsen.
I look forward to your measured data.
Just the measured data or facts please maaaaan.
Justdafactsmaam
So? Did someone else ask you for any data on the Quads? I sure didn’t
What I did ask for was data to support your assertion that “It's marketing hype trying to sell the magic of panels in a small form factor to the 'audiophile' market.” In regards to the JansZens.
That’s a pretty fierce attack on their product. And yet you have zero objective evidence/facts or even personal subjective experience to support such criticism.
I posted a link to their webpage with relevant information.
Given the fact that I have clearly stated I own the Sanders 10Es which are direct competition to most of JansZen’s speakers I’d say your comment reflects more on your inability to read the room than anything else
Do you need the link to the JansZen webpage or can you find it yourself. The measured data is there.
Maybe you can take a look at it and tell us how you reconcile that data with your assertion that “It's marketing hype trying to sell the magic of panels in a small form factor to the 'audiophile' market.”
misterdog
Do you have any data? This is supposed to be a science based audio forum.
I've provided the data from the Quads.
Where is any data from the Jantzens, other the the crossover point.
Or your.
If one wants added energy in the reflected field the JansZens do offer that option.
how might that help ?
Is that like a DAC where you can add more distortion because you think it sounds better and the artist forgot to include it ?
Justdafactsmaam
Wash, rinse, repeat. I did not ask for any data on the Quads. You can find the data on the JansZens at their website. I already posted the link.
When you get around to looking at that data please let us know how you reconcile your assertion that “It's marketing hype trying to sell the magic of panels in a small form factor to the 'audiophile' market” with the data you can find at the website.
misterdog
the BACCH filter, which purifies the audio playback from crosstalk,
You will be advocating 'special' mains power leads and loudspeaker cable lifter's next.
misterdog
Is this the 'data' to which you refer ?
Between the low distortion, the lack of coloration, the seamless integration, and our careful attention to crossover design, the woofers give no clue that the entire loudspeaker isn't electrostatic.
From the link you posted - https://janszenaudio.com/
I see no measured data on that site at all, merely marketing bullshit.
Blumlein 88
So I've lost track of the disagreement here. I don't think you guys are doing anyone any favors. What data on what thing is being asked for and to support or deny what premise? Clean things up and a resolution is possible which is much preferable to bickering back and forth.
Duke
Princeton, Texas
The "bickering" you mention is pretty much one-sided. @Justdafactsmaam has not accused anyone of bullshit, nor of being a shill, has not tried putting words into anyone's mouth, has not indulged in zingers and personal attacks, and has not repeatedly played the "prove it to me" card in response to an expressed opinion.
