Eversolo DMP-A6 Streamer @Purité Audio
Rottmannash
Nashville
do you think there is a risk if I connect it and by previously setting the volume to the lowest in the kefs?
No. Not if you attenuate at the KEF's.
Gremlins
For what it’s worth, feeding the eversolo A6 digital output into my SMSL D6s Dac, I can control the volume if I turn off volume pass through in the settings menu.
I actually run full volume on both dac and eversolo into my pass labs preamp, but the volume is a bit to high so granularity is too course on the X1. I have played with slightly adjusting volume on both the Smsl and eversolo, I might slightly prefer doing it on the eversolo
Ok uderstand, thanks for your input
So eversolo in coax,optical output a have volume attenuation, niiiice
So now, for my setup,i wonder if using eversolo coax output directly into coax input of a hypex fusion 503 would better sounding than eversolo xlr output going into xlr input of hypex fusion
I know that going digital the further is the best on book, but will it be audible?
If amir could tell me, i will take it as granted
shion_ca
Technically I was using USB for my connection. But since its pre-processing before sending I can't see why coax wouldn't do it.
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
Here I use XLR out of the A-8/A-6 into the analogue ’ins’ of the ‘Mantas’ you will have to experiment.
Salt
DE
Don't expect large differences between AD-conversion vs. samplerate-conversion in Hypex (ore different) Plateamps compared to plain distorsions by loudspeaker itself.
shion_ca
With the A6 if I am listening to uPnP and I try to switch to Spotify connect, sound doesn’t come out. It will show the track as playing, but there is no volume. I end up having to reboot the whole box.
Anyone know how to get around this?
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
When you say uPnP what are you actually listening to what is the input on the A-6?
Thanks,
shion_ca
Thanks,
I am listening to files off my NAS. Ie. I have placed rips of my CDs in lossless flac format onto a synology network attached storage. The eversolo is connected to it through a network hub.
All works fine, but when I try to listen to something from Spotify, I first pause the track I’m listening to from uPnP input. I select the eversolo through my Spotify on my phone and select a song. The eversolo shows the Spotify song as playing but…. No sound. I pause Spotify and hit play… no sound. I go forward and back tracks on Spotify… no sound.
I have to reboot, then can here the sound
Womaz
Newcastle - England
Did you change the input source in the app?
upnp may be from the usb C input? If it is you need to change it to internal player on the input maybe ?
Womaz
Newcastle - England
Try this
Instead of pausing the song you are playing actually stop it . Then also delete the other tracks if you have any in the queue .
Then try Spotify…
Womaz
Newcastle - England
I guess it depends what app you are using . I use Roon and recall a similar issue
I seem to remember I had to delete the queue of what I was playing
shion_ca
Womaz
Newcastle - England
So you are using the Eversolo app.
Go into your play queue and delete everything in it .
Gremlins
I loose my playlists eveeytime i rescan my HDD ...help please
I populated songs in some playlist, i still see the 9 playlist i have, but they are empty after rescaning hdd ... whats going on... that a major problem to me
Help please
shion_ca
I think when I am sorting by album and pick a song it does add all the songs in the album to the queue though… maybe have to manually delete all of those first? I can try it I suppose
Womaz
Newcastle - England
I seem to recall that’s what I had to do ……but I was using roon . I wanted to try tidal connect and the Eversolo did not show up on the tidal app
i solved it by deleting my queue in Roon .
