unpluggged
- Joined
- Jan 5, 2023
- Messages
- 469
- Likes
- 697
On both. Why does it matter to you?
Because although they are very similar, they are not the identical.On both. Why does it matter to you?
You refer to differences between different products from different manufacturers, not between ES9218P and ES9219C. This is significant, since we have seen that different products based on the same ES9218P can have significantly different measurements.In my previous post I refer to some of these differences.
These chips by themselves differ only by their power consumption figures, so as long as Qudelix 5K is within its published specs I don't care which specific converter it uses. And we have yet to see comparison of measurements of ES9218P-based and of ES9219C-based Qudelix 5K. Not that such comparison would be of much relevance today, as they switched to the ES9219C two years ago.
IMO, you are overthinking it The 5K will not disappoint you. The only gripe I have is that I'm unable to find a replacement battery that has started showing its age after three years of constant use (it uses a 3.8V cell that is not that common, as it turns out). In fact, I ordered a second unit the other day. Perhaps I'll try to find some free time to measure them both with the RME ADI-2 Pro.Very true, but there is always some trace of its "character" (DAC), as long as the path to the output is similar. Please take a look at the similarities in the following graph (in spite of Low vs High gain), between the "Shanling M0" and the "Qudelix-5K", both with ES9218, are quite close.
Yes, they are almost identical, at least on paper, but not the same. And indeed, the Qudelix-5K is within its published specs, but what about the unpublished or partially published ones. I do care to know all these details, even if the change was two years ago, especially if I am in the process of comparing to decide which one to buy.
Maybe, but it's something natural for me.IMO, you are overthinking it The 5K will not disappoint you.
3.8V is the nominal voltage (average voltage during a full discharge). A cell of this type (Li-ion) typically has a minimum voltage of about 3.0V (or less), and a maximum voltage of about 4.2V, with a nominal voltage between 3.7V and 3.8V.The only gripe I have is that I'm unable to find a replacement battery that has started showing its age after three years of constant use (it uses a 3.8V cell that is not that common, as it turns out).
Maybe it's not a bad idea, it's not the first time the qudelix-5k has been "redesigned", the following image may be one of the first versions (not 100% sure).In fact, I ordered a second unit the other day. Perhaps I'll try to find some free time to measure them both with the RME ADI-2 Pro.
That's right. And if I replace it with a 3.7V battery, it can lead to some unpleasant effects — from wrong battery charge percentage display to overcharging the battery, depending on how the charging circuit is implemented on the 5K.3.8V is the nominal voltage
This was the initial design (makes sense, since it shows its ES100 roots), they never got past the prototype stage.Maybe it's not a bad idea, it's not the first time the qudelix-5k has been "redesigned", the following image may be one of the first versions (not 100% sure).
Don't worry about, you don't lose anything by trying it either, btw take a look at the following diagram, it indicates Li-ion (3.7 V).That's right. And if I replace it with a 3.7V battery, it can lead to some unpleasant effects — from wrong battery charge percentage display to overcharging the battery, depending on how the charging circuit is implemented on the 5K.
I didn't know that, funny thing.This was the initial design (makes sense, since it shows its ES100 roots), they never got past the prototype stage.
I got one of these BTR15 now also - very nice little device - going to test the PEQ capabilities with a few headphones over the next few days but while the FiiO Control App is better than the Moondrop App for the FreeDSP it still have usability issues when saving the PEQ values (at least the IOS version has)The BTR15 arrived. Nice little thing. I can't comment on sound quality, it seems ok to me. The peq is working even if the settings are a bit confusing. From the android app you have to enter in advanced settings for every single geq slider and you are prompted to set peq parameter (freq, db, and q). 10 bands but just peaks, not shelves, and preamp gain. Storing the curves is even more confusing, I am not sure I understood the process. Once stored you can access the eq preset from the dongle and is working in bluetooth, wired phone and PC mode. You can store just three user preset.
This is the eq for my senn hd580. Not enough power even in high gain for this can and eq if you like listening loud but I guess if you try the bal out you get more juice and headroom for eq (I don't have balanced cables).
Hi! This is unfortunately only valid if "U-Audio" is set to 1.0 (UAC1.0), at least for my unit. Had to learn in the hard way with no music playing, some very weird distortion sounds. Factory reset after V2.2 Update also did not help. Overall, the firmware of the BTR15 is still rather immature, alpha state at best.Once stored you can access the eq preset from the dongle and is working in bluetooth, wired phone and PC mode.
Yes definitely some bugs - I am currently looking at documenting some of the issues - it has lots of potential with the screen and the PEQ and I even like the size / shapre of it compared to even the Qudelix 5K but switching between 'modes' and even switching between EQ settings sometimes doesn't work unless its disconnected and reconnected.Hi! This is unfortunately only valid if "U-Audio" is set to 1.0 (UAC1.0), at least for my unit. Had to learn in the hard way with no music playing, some very weird distortion sounds. Factory reset after V2.2 Update also did not help. Overall, the firmware of the BTR15 is still rather immature, alpha state at best.
True that! Also PEQ for the time being only supports Peak filter types. Shelves would be very handy, that way same presets (Oratory for HD650 here..) could be used.Yes definitely some bugs - I am currently looking at documenting some of the issues - it has lots of potential with the screen and the PEQ and I even like the size / shapre of it compared to even the Qudelix 5K but switching between 'modes' and even switching between EQ settings sometimes doesn't work unless its disconnected and reconnected.
