Help me choose an AVR?
Chrispy
PNW
(and born before 1965)
I only remember "made in Japan" commonly being a negative in the early 1960's. By the 1970's brands like Sony, Toyota, and Nikon changed that around. Then we picked on Taiwan and Hong Kong, then Korea for a short time, then China for a longer time. Now it's Malaysia, Vietnam, and Thailand. There is always a place where low labor costs sometimes trumps quality.
We used to say just follow shoe manufacturing for a route to lowest labor :).
Zapper
Am I better just 'KISS' and buying a really good intergrated amp with an optical in from my Shield? And then just running 2.0 or 2.1?
I assume I need an AVR for things like virtual/phantom centres?
Minefield.
Yamaha R-N800A is one of the few integrated stereo amps with bass management and room eq. I can't vouch for the performance of either. Overall quality is high.
rynberg
Bay Area, California
One last go at overcomplicating this before I do as I'm told..
So let's say I have £1000ish to spend on an AVR to run my current gear, which is L&R Kef R3, and a PC-2000 sub. And hopefully in the near future adding a 3rd Kef R3 as a centre.
Am I getting more bang for the buck going for:
  1. Denon X3700/X3800 (~£1000)
  2. Marantz Cinema 70S (£600) + a £400-£600 3 channel power amp (Emotiva BasX A3 / or some Class D amp like Nord NC252)
Even as a former Marantz owner, I would never choose a Marantz over the much cheaper and near identical Denon product. The Cinemas 70S is a far inferior product than the 3700/3800, in terms of audio performance but much more importantly, the EQ functionality.
Separately, the Emotiva products are all very mediocre. It's likely the Denon 3700/3800 will have adequate power with your use of a subwoofer. If you find that you are running out of power, you could add an outboard amp down the road (unlikely).
Fahzz
Outside Providence
So Denon 3700 out of stock - 3800 has a lot of stuff I don't need (four subwoofers???). Anybody have a Denon 2800? Any good 5/7 channel AV preamps that cost less than a gazillion dollars?
Power Pop 23
The Pioneer Elite VSX-LX505 has preamplifier outputs for all channels - if you have amplification - and comes with license for Dirac
Adorama in NYC is currently selling the Pioneer Elite VSX-LX505 for $649. Perhaps a retailer near you is offering the '505'.
I perceive greater clarity deploying Dirac Live. The Denon AVR-X3800H AVR allows the option of deploying Dirac Live
Amir reviewed and recommends the $20 Audyssey MultEQ Editor app at the link below - he thought it approached the performance of Dirac
The Audyssey MultEQ Editor app is compatible with select Denon AVR's including the AVR-X2800H
Chrispy
PNW
If you don't like the advantages of the 3800, the 2800 is definitely less expensive. Personally I like having a full set of pre-outs (especially if you want it as an AV preamp), four independent subs, and prefer the Audyssey XT32 as well as the Dirac option the 3800 offers.
zgmf_x10a
A 5/7 channel preamp will cost WAY more than the 3800 while having less features. Personally unless you want to use active speakers or listen loud even the 1700/1800 are adequate
