Mr. Haelscheir
- Joined
- Mar 16, 2023
- Messages
- 113
- Likes
- 86
I am looking for advice on the practicality of calibrating the in-ear microphones and electronics that I intend on using for conducting in-ear headphone and speaker HRTF measurements. I desire reasonable accuracy from 20 Hz to 20 kHz, and though these will of course be specific to my own auricles, I desire advice in developing an appropriate calibration reference for these measurements if anything beyond a channel match is even worthwhile.
The microphone to be used is https://www.digikey.ca/en/products/detail/pui-audio-inc/TOM-1537L-HD-LW100-B-R/12152294 which will be embedded at the end of a 1 cm canal impression/plug as a more comfortable alternative to the Earfish in-ear mics used in https://www.head-fi.org/threads/mez...eadphone-official-thread.959445/post-17743502 (post #5,152). I may have an additional pair through which I will attach probe tubes via David Griesinger's method for speaker HRTF measurement and to hopefully avoid the trouble of having to use hearing threshold EQ to compensate the response as covered in https://www.head-fi.org/threads/rec...-virtualization.890719/page-121#post-18027627 (post #1,812). From what I understand, probe tube mics can be calibrated by having a reference mic situated next to the probe tube's end, though I am still researching this.
The audio interface is a MOTU M2 to which the in-ear mics will be connected with RØDE VXLR+ adapters unless I find a lower-noise implementation (see https://audiosciencereview.com/foru...hones-with-motu-m2-and-rew.49384/post-1783062 (post #6)). The MOTU M2's DAC line out will be used to drive either the FiiO K9 Pro ESS's 4.4 mm balanced input for headphone measurements or the Genelec 8341A with GLM's analog input for speaker HRTF measurements.
The measurement capture software will include Room EQ Wizard, the https://www.earfish.eu/ HRTF capture software, and Impulcifier.
Crux: For both the microphones and the ADC and DAC electronics, there will exist frequency response nonlinearities I would ideally like to correct with calibration files to be linear from 20 Hz to 20 kHz. There are a few local calibration services within Toronto, Ontario, Canada, but as far as I can tell, these only service professional applications with lab-grade equipment as most likely would not offer services for calibrating mere 4 mm electret microphones or a consumer audio interface (or they would only offer services for calibrating the professional equipment that you would use to calibrate those). I suppose I could go ahead and acquire and trust an Earthworks measurement microphone to conduct free field and if possible pressure field calibrations of the electret microphones, but this leaves in the nonlinearities of the electronics. Likewise, I would need to supplement the DIY calibration with a good subwoofer if I wish to ensure that my measurements are accurately capturing the headphones' bass extension.
Hence:
Hence:
- Are there recommended services I may not have the right search term for for calibrating these electret microphones and electronics?
- For in-ear HRTF measurements, blocked canal and at-eardrum probe tube measurements respectively, is a free field or pressure field calibration required? Does this even matter for non-academic and spatialization uses?
- Is there no way around supplying my own subwoofer to calibrate mic linearity down to 20 Hz?
