- Joined
- May 21, 2021
- Messages
- 236
- Likes
- 130
People are telling me I am wrong what I wrote in this first post, so I added this paragraph, did some text strike outs, and changed the title to say Atmos. I guess I was confused with Atmos vs regular surround. Sorry. The replies below are good though.
HTPC's (or PC's) cannot decode surround sound (like Dolby and DTS) to more than 2 channels.(I was wrong. they can do Dolby up to 8 channels, but not Atmos, and not DTS).
There is no apps or drivers you can add that will do it. They can decode to stereo (2 channel), but not to multichannel (more than 2).
JRiver cannot do it. Dirac and Roon cannot do it.
My guess is the same is true for Macs.
A Shield Pro can NOT decode it.
And Minidsp Flex HT, and SHD can NOT decode it.
My guess is Apple TV cannot decode it.
Some of the confusion comes from
- decode vs passthrough.
- multichannel that does not need decoding, like a musician creates 5 tracks of PCM - that does not need decoding.
These are interesting links for Atmos with PC:
So you understand that your graphic card can decode everything but atmos and that gets passed thru to an avr. The work around for an htpc that go thru a multi dac are a pain. I use windows and madvr in MPCBE to play my 4k disc. It's an incredible picture that allows you to use tone mapping. I was confused by you saying that your htpc cannot decode dts or true HD. I believe Nvidia cards have been able to decode those for at least the last 15 years. Honestly, I used to have to re mux my movies because I couldn't afford a better card that would play DTS in the old days.Wow. That is super helpful that you explained it so clearly and completely. JRiver needs you to help them write the help instructions. I will do Scenario 2. I would never go over 5.3. I will begin with 2.2 and future possibility of 3.2. or 3.3. Thanks very much for the help.
