WANTED: Happy members who like to discuss audio and other topics related to our interest. Desire to learn and share knowledge of science required. There are many reviews of audio hardware and expert members to help answer your questions.
Click here to have your audio equipment measured for free!
I have two SVS SB-1000. Read a review which the buyer says the amplifier was good for 3.5 years, before the amplifier failed. He had it replaced, and it worked a few weeks before it failed again.
This is a question that has no real answer, because no one knows what people have subjected their subwoofers to and no one outside SVS has large scale data either. I have an SVS SB12 NSD from 2008 that still works about as well as it did 16 years ago.
I'm not aware of any evidence that would indicate they're significantly more or less reliable than any other comparably priced subs.
I have 4 SVS subs, two of them for maybe 5 years. No problems.
I had an issue with the SVS Tri-band link and one call got escalated immediately and they were ready to send me a replacement, when I realized it was my fault, not their gear.
I have no complains about the reliability or failure rate of that specific sub amp. I own two and for the ca. 1-2 years I have used them, they never failed.
But I can complain about the quality of their DSP/amp section, and if you're going to buy one, I recommend you that you test it before in a quiet environment. For more information see here:
Hi, I own two SVS SB-1000 subs since a little over one year ago and since day 1 i have been experiencing a constant rumble/noise whenever the sub is on as explained here: https://www.audiosciencereview.com/forum/index.php?threads/problem-with-sub-noise.32681/ It is present in the two subs i...
Maybe components quality today is not as high as it was 16 years ago... Unfortunately this is a common issue not only to electronics, but to all the household appliances today.
For the number of subs from SVS out there, sure there's a failure story here and there but nothing particularly unusual.....not quite like the issues Epik or Elemental Designs (?) had at least.
My experience with computer tech makes me suspect that person has a power problem in their home or municipal line, surging or sagging or both. If you regularly have electronics break on you then you might look into if your municipal power is steady or not, otherwise I wouldn't stress too much about one person's trouble. Just too many possible causes including them doing something really dumb with it and blaming the amp.
I was about to make long post preaching about the benefits of sine wave replicating uninterruptible power supplies, but honestly who knows what went wrong with that situation. Here's the summary of my thoughts on power issues: If you worry about the longevity of your electronics and suspect home/municipal power problems, smooth/pure/"natural" sine wave type UPS's are worth getting. Might be expensive for high watt audio equipment though. However, if electronics in your home typically last a long time without issue I wouldn't worry about it.
On my second svs in ten years. No problems. Like anything electronic there will be a failure here or there but I haven’t heard of more problems from one sub builder over another.
