JBL M2 Reference Master Monitor Review
synthetic
Owner of the M2s here. Erin was kind enough to send me the data and I took a stab at equalizing it to look like the marketing spin-o-ramas.
This makes the early reflections and sound power curves also look a lot more like the Harman spin-o-rama than what Erin measured.
I speculate that they are using a different set of filters for the production version. Luckily with the way the m2s are designed we can easily change the target, and thanks to Erin we now have the data to do so.
BrokenEnglishGuy
I think the thing is what it can do 86dB SPL with minimal distortion it also does at 105dB. If you don't need a lot of oomph, probably not the right speaker.
Also, just eyeballing graphs, I think Erin's vertical axis is more spread out vs ASR, so jaggies look more extreme.
that make sense to me...
Newman
I've included my video and a couple of the more important takeaway graphics below.
Were you driving it with its bespoke amplification and settings?
These measurements are good, but not what I would consider state-of-the art. I'm kind of disappointed.
Well, if the bespoke amps and settings were not used, it would be like measuring a Genelec with the internal EQ turned off.
Ata
Adelaide, Australia
Owner of the M2s here. Erin was kind enough to send me the data and I took a stab at equalizing it to look like the marketing spin-o-ramas.View attachment 149372
How did you do the EQ, by hand in REW?
cany89
Seems to me the biggest differences to 708 are:
1) SPL capability jump from high to basically without limit in a domestic system
2) directivity control extends lower in frequency (wider woofer and baffle)
3) directivity control breaks down lower ib the treble (big compression driver and exit vs tiny CD and exit)
So an achievement for sure, but I suspect most 70x owners will not be much happier with M2 than what they already enjoy.
As a 705 owner; I was just asking myself what if? My wallet looked at me like oh hell no! And then you dropped your comment lol. Just in time!
thewas
Well except that this nails flat DI from 800 to 8000hz in a way that not even Genelec or the D&D 8c do.
Personally I prefer the total DIs behaviour of the D&D 8c more, smoother and controller better till 150 Hz
while on the JBL M2 the directivity is significantly drop below 800 Hz like on a typical big loudspeaker
abdo123
Brussels, Belgium
who doesn't need a lot of oomph though? Dynamics are everything if not even more important than the FR itself.
I mean i would not buy this to put it on my desk but it's one hell of a speaker for anything else.
abdo123
Brussels, Belgium
For me the D&D looks less controlled, at 1500Hz you have a non-linear hump, followed by a drop in directivity followed by rising directivity again, then another drop at ~13KHz .etc
the D&D is narrower in directivity, but not more controlled.
I still think it's the better speaker, because it was obviously designed with a Klippel with much higher resolution, not to mention the low frequency directivity.
but overall i would say the M2 is more controlled.
thewas
Our definitions are different then, for me the D&D controls the directivity better as it does it in almost all the important audio band, meaning I personally prefer directivity down till the base tones with a little drop in 13 Khz then having 2 different directivity regions like the M2.
Koeitje
Except those can't play nowhere near as loud as the M2. The M2 does THX reference levels on its socks.
Anyway, you can't really compare these speakers. They have totally different use cases.
thewas
Sancus
Huh? What does any of that have to do with anything? I was just referring to the technical achievement of a genuinely flat DI curve, that's all. Nowhere did I say I was comparing speakers in total or for any particular use case.
Yeah it's an open question what you should do if you can't actually achieve perfectly controlled DI 20-20khz. You either have to have a gradual slope, or a sharp change somewhere. I dunno which sounds better overall, but I also suspect it's the D&D 8C.
