Low and high pass Filter with wiim pro plus and fosi v3
Tui
Hello,
I am new to the hobby. I own the wharfdale Diamond 12.2, a fosi v3 and a wiim pro plus. I want to ad an subwoofer with Low Pass Filter. I dont know how to also add a high pass Filter to the system? Maybe with the PEQ from wiim? Or do i have to add another device ☺️?
Thank you for your Help
staticV3
Hi @Tui! Welcome to ASR.
The easiest way to achieve this would be with a studio subwoofer that has built-in low pass and high pass filters. Here are some examples:
-Presonus Sub 8BT (200€): variable LPF & fixed 80Hz HPF
-ESI Aktiv 10S (240€): variable LPF & fixed 100Hz HPF
-KRK S8.4 (300€): selectable Xo (LPF&HPF) 70/80/90/100Hz
You would then connect everything like this: WiiM->Subwoofer->Fosi->Wharfedale.
The sub would handle splitting up the audio to itself and your mains
Reactions: Tui
