Marantz cinema 50 sub frequency limitation
mimoza
Hello
As you can see if you plug a sub to the sub pre out the frequency output is limited
If you plug the same sub to a LR preout you can have the sub full frequency range
It is annoying while using for exemple dirac bass control as the sub is limited by the avr, I have not found a way to fix this when using Dirac bass control, I this mode most setting are disabled
