miniDSP U-DAC8 8-Channel USB DAC Review
This is a review and detailed measurements of the miniDSP U-DAC8 multichannel USB audio DAC. It was kindly purchased and drop shipped to me by a member. The U-DAC8 came out a few years ago but still seems like a current device costing US $255 from the company direct.
The U-DAC8 embodies simplicity and fitment for function:
A USB port in for data and then in the rear, 8 channels of output:
minidsp U-DAC8  8 channel USB DAC Back panel connectors input output Audio Review.jpg
And an external adapter double the size of a typical phone charger.
Wiring will be messy though with that USB connection in the front. Would have been nicer to have a slightly larger box and put the USB in the back.
The U-DAC8 was plug and play with Windows 10, exposing 8 concurrently channels. You could build a PC home theater or multi-channel source with it easily.
Most PCs come with 5.1 output so getting up to 8 channels out of U-DAC8 is a plus. As would be expected performance improvement.
DAC Audio Measurements
As usual, we start with a 1 kHz tone at full amplitude and see what we get out of the DAC:
OK, this is not good. Distortion products are way up there as is enough noise to give us a very low SINAD of 78. This puts the U-DAC together with the rest of the students that have gotten a failing grade from us:
The U-DAC8 uses AKM's AK4440 DAC chip. It does everything internally which the U-DAC provides from creating the required supplies to output buffers. Its specifications state a "THD" of 93 dB. We are 15 dB short of that at 78. miniDSP's own spec is 0.006% which translates into SINAD of 84. So whether we take my measurements or theirs, we are way short of the performance of the chip.
I tested the other channels and they produced identical output.
Dynamic range was decent:
Intermodulation distortion versus level was well below my reference DAC:
Linearity showing was not as embarrassing as I expected it to be:
Multitone test shows that as frequencies go up, non-linearities increase substantially resulting in more distortion products:
We will revisit this in a bit later. For now, let's look at jitter:
Noise level is very high as it is but then it rises around our main tone at 12 kHz. I re-ran this test (not shown) at lower frequency and it did that there too. We call this noise modulation although usually the entire noise floor lifts, not just around our main tone. Audibility of this is not as bad but still, something we don't want to see in a high quality implementation.
Real awful response was awaiting us in the form of THD+N versus frequency:
minidsp U-DAC8  8 channel USB DAC THD+N vs Frequency Distortion Audio Measurements.png
What on earth is this? Not only do we have fairly high levels of distortion/noise, it is also frequency dependent. To make sure this was not a measurement anomaly, I tested that trough around 700 Hz versus 1.5 kHz next to it:
Distortion is definitely higher at 1.5 kHz, demonstrating that the previous graph was correct.
Even DAC reconstruction filter response was disappointing with low attenuation out of band:
The right side should be down at -90 dB and lower.
What a shame. I walked into this review excited that we would have a clean and simple 8-channel DAC that could let us build our own Audio/Video Receiver in a PC. Performance though is quite disappointing. As a minimum we should have seen performance similar to the AKM DAC chip specs. Where the shortfall is, I can't say given the simple design here. As much as I hate the crapware that comes with PC/gaming sound cards, they have much better performance for much less money than the U-DAC8. I hope miniDSP goes back to the drawing board and builds a proper version of this DAC.
Needless to say, I cannot recommend the miniDSP U-DAC8.
As always, questions, comments, corrections, etc. are welcome.
I threw a bone at one of the panthers and it hit him in the head. No, it was not the headless one. Seems like he needs glasses as he used to be able to grab it mid-air. I am still searching to find an optometrist that specializes in pink panthers. When I do, I need lots of money to pay for the visit and eventual contact lenses (can't imagine the panther walking around with glasses -- the rest of the panthers would tease the heck out of him). So I appreciate generous donations to cover the cost using : https://www.audiosciencereview.com/forum/index.php?threads/how-to-support-audio-science-review.8150/
JohnYang1997
China
??? The tight match between the two channels actually surprised me a bit. Normally when we get this level of bad performance there is difference between two channels. How come??
Because everything is on-chip and hence higher precision:
A few caps and you have the whole solution!
How they managed to degrade the performance so much, is a puzzle.
Trdat
Yerevan "Sydney Born"
So I am presuming you will get better performance with the UDIO8 and purchasing a well measured DAC from your list for each channel?
Could the UDIO8 also possibly have issues with it?(I ask cause not sure how that works in conjunction with a well performing DAC). Or might just be better to get a descent multichannel DAC in the first place...
restorer-john
Does the Khadas tone board and this minidsp use the same AKM DACs? Is that the reason for your comparison, beacuse there are some striking similarities in THD+n v Freq, albeit it a much higher level?
In terms of measurement points, the above graph also suggests there are only three measurement points above the 10KHz point, is that correct? Is that sufficient in your opinion for 50% of the audible spectrum?
RayDunzl
Central Scrutinizer
Riverview FL
Good catch!
restorer-john
Has the Khadas tone board simply paralleled 4 D/A converters for each stereo channel if it uses the same chip?
RayDunzl
Central Scrutinizer
Riverview FL
headwhacker
KTB use an ESS DAC chip. I belive the mobile version of 9038
digicidal
Sin City, NV
Suddenly a number of AVRs and AVPs did a little victory dance (or at least a sigh of relief). I understand that the principle application is different, but still if you count the cost of the PC and amplification in the package... this would be bested by a number of them for the same cost - and that's without taking the significant amount of additional features into account. :confused:
I wonder (hope) that the nanoAVR HDA is better. At least it's a more complete package with DSP & HDMI switching - and all the cables connect on the same side. For $130 more I'd think it's the better deal though slightly different application.
Blumlein 88
This looks similar to results from the ViewHD HDMI switcher when using the SPDIF output to feed a good DAC. Which makes me think this is all in the clocking. The switcher optical output fed to a Tact RCS 2.0 DAC in red and the same Tact DAC being fed via optical from the Musical Fidelity V-link is in green. 48 khz sample rate in both cases. This output was very similar, but worse in some ways if using that switcher's DAC analog output. To me this points to the clock being the problem. So what is doing the clocking in this uDac8?
Vovgan
Moscow, Russia
Ah, such dismal performance from the manufacturer of the (probably) most popular measuring mic (UMIK-1) for audio enthusiasts is a shame indeed.
As an aside: Is my understanding correct that even if their UMIK-1 has a hundredfold worse performance (THD+N for ADC), there would still be absolutely no concern for using it for the purpose of room measurement?
AudioSceptic
Northampton, UK
50% linear, but only the top octave. Isn't this why we use log scales for frequency (and dB are log anyway for the Y-axis).
pozz
Слава Україні
Editor
The UMIK-1's self noise is very low, although the overall quality is not exceptional. See this discussion: https://www.audiosciencereview.com/forum/index.php?threads/noobie-question.9799/#post-263381
miniDSP in general hasn't produced great measurements:
ElNino
Those jitter measurements probably aren't good news for the MiniDSP MCHStreamer digital transport, which seems to the basis of this design's digital interface.
I agree with the speculation that this could be related to clocking. The thing I've never understood about the MCHStreamer is how it's designed to accept digital inputs (S/PDIF) but can't slave its clock to its inputs, unlike the MiniDSP USBStreamer, while also not having a dedicated ASRC onboard.
daftcombo
Willing to see more miniDSP measurements now.
Thanks Amir!
trl
King of Mods
Iasi, RO
Maybe there's something inside we can spot. I wonder if those non-shielded ribbon cables would be at least partially responsible by the bad measurements.
Also manufacturer's webpage: https://www.minidsp.com/products/minidspkits/minidac8
trl
King of Mods
Iasi, RO
