analogonly
- Joined
- Oct 8, 2023
- Messages
- 18
- Likes
- 32
1) User name chosen to be unnecessarily provocative. In addition to vinyl collection not being digitized anytime soon, also have numerous CDs and looking to get into storage and streaming options, but slowly.
2) Need a new CD player or transport and don't want to waste a lot of money--less than $1k (the lower the better). Suggestions?
3) If #2 is a transport, I will need a DAC--same $ concerns and limits.
4) Storage and streaming recommendations? What sort of budget will I need to plan?
Now for the controversial parts:
5) Currently using all tube electronics--Audible Illusions Modulus 3A preamp and either Yamamoto 08(S) amp (SET 45 output tube, lucky if it makes 1.5 watts into a reasonable impedance loudspeaker--in this case a custom built Foster FE206ESR/TA90AEX backhorn) or Quicksilver Silver Monos (90 wt KT 88s into MartinLogan Quest [original model]). Assuming reasonable flat frequency response (probably a fair assumption) and stated power (never a fair assumption), my usual complaints with electronics are timbre and dynamics (both micro and macro--not to be confused with "loud"). As I age, my tolerance for fussiness and tube aging has diminished. I would also like to downsize, but remain future-proof for these "mature" technologies. Yes, I consider class D amplification to be reasonably mature, albeit only lately. My concern here is that many of the loudspeakers that I may change to in the future (the raggedy frequency response of my high-efficiency backhorn is no longer tolerable and the MartinLogans may be physically too large for a downsized home) are low efficiency and/or low impedance. So, electronic considerations are:
a) CODA CSib or Gryphon Diablo 120 (or its presumably upcoming replacement) if integrated. Would the Buckeye Integrated, when available, be a bridge too far for me?
b) CODA 07x or Benchmark LA4 line stage if not integrated.
c) Buckeye NCorex500 amp. Other options? See my loudspeaker choices for the potential problems.
d) Phono stage--probably one of the ones highly rated by ASR for MM. Haven't chosen a cartridge yet, but as my ancient Grado gave up the ghost, leaning to the Audio-Technica VM750SH.
6) Loudspeakers:
a) Passive--Soundlabs (size room dependent) or Magico (probably A5 but would prefer A3 if they incorporated A5 technology). Any idea why the S3 has better vertical dispersion than the A5?
b) Active--obviously removes the need for an amplifier--ATC 40a or Neumann KH310. Yes, I am aware that they are massively mispriced relative to each other and that the KH420 is competitive price-wise with the ATC 40a and a much more capable loudspeaker. I am also considering it and need no advice in that direction. I am interested in thoughts on comparing ATC 40a and KH310 without reference to price.
c) Subwoofers--probably none due to downsizing. If any, probably a Rythmik swarm.
Final note--I have no interest in digitizing my analog source (yes, I know that many of my records are digitally mastered; I also have many pre-CD era records). So, no advice regarding anything that mandates an ADC or DSP that affects the signal from cartridge though and including the loudspeakers. Fine if it only affects the digital side of the chain.
Thanks to all who respond with helpful advice. In the interests of comity, I will not respond to any replies using the terms "golden ears" (which I do not profess to possess), "boomer" (I am), or other snark used by a subset of members here.
6) Loudspeakers:
