Nonlinearity induced bifurcations and chaos in loudspeakers
Zapper
Hi. I skimmed the second article you linked. I did an MS thesis on chaotic dynamics in electronic circuits many years ago, so I get the general drift of the paper. Chaotic responses generally entail multiple stable or quasi-stable states. An example is an umbrella - it is normally concave downwards, but a gust of wind can snap in concave upwards. When driven by a large alternating gust, like in front of the monster subs you want to make, it may oscillate chaotically between the two states.
The paper didn't describe the physical mechanism behind the chaos but I suspect it's due to cone breakup. In fact, it's very similar to the umbrella I described - the cone can flex so much that the mechanical restoring force resisting bending starts to decrease and may even go to zero and reverse direction (in which case the cone could get stuck in the deformed condition). The large amplitude signal is forcing the cone to to flex in breakup modes with highly nonlinear restoring forces, and this generates the chaotic response. This has actually been used by guitarists seeking a very grungy sound, driving a speaker deep into breakup, or even cutting the speaker cone to assist breakup. Maybe the chaotic response is the source of the unique sound of speaker breakup.
In any event, the THD of the speaker will be very large before any chaotic response occurs, so the chaotic response will occur in some region between "sounds like cr*p" and "oh sh*t the speaker's on fire".
kemmler3D
San Francisco
These music styles don't require clean neutral subwoofers, they need to be very loud and go low (40Hz minium, mostly lower) and distortion is an inherent part of the sound, even in the music itself.
Not sure if that's true in this case. Did you listen to the samples in post #12? I wouldn't say they're really 240 BPM or anything, more like ~120-140ish with a lot of extra kick drums. In effect you have almost a droning bass with a lot of transients as you go. In order to differentiate each drum hit in a live venue you're actually going to need really clean response and a reasonably accurate impulse response, at least not afflicted with a lot of group delay.
For this particular genre of music I'd prioritize phase response and flat FR a lot more than I would for most dance genres, because otherwise the fast rolling kick drum effect will be spoiled. If you can still manage high SPL at low frequencies, then it would probably help but I don't get the impression it's the top priority here.
Nice, nothing wrong with a bit of old gabber but sadly it doesn't get much play time at the parties i usually go too :(
Breakcore is the odd one out of the genres i mentioned and not quite as fast as the others.
Haha yep i am indeed old enough to remember the dubstep era, i actually still quite enjoy it. More-so the chunkier UK style rather than the squeaky skrillex stuff but it do still hear it played out somewhat regularly here.
I'll link a few assorted tracks to clarify some of the styles that i've found issues with, its often common in these genres the bass line will be kick-bass-bass-bass but at 200bpm, the in between bass bits can really start to blur together especially at the lower frequencies where there is often high group delay on some box types.
https://soundcloud.com/wachumarecords%2F12-mirror-me-unalloyed-gold https://soundcloud.com/bilycore%2Fbilycore-kromacore https://soundcloud.com/theongoingarcanum%2Flaw-of-the-jungle https://soundcloud.com/jiazihulive%2Fjiazihu-vallak-macabre-tale-release-soon-in-va-cyberroots
Weirdly, not the same psycore as the old psycore, a whole new branch came out from the psytrance scene about 6-7 years ago as a darker faster version of darkpsy+hitech and has basically no connection to the previous genre by the same name from the hardcore electronic scene. But yeah breakcore ain't new.
Yep i think that's the only real conclusion to come for unless i try to rebuild the simulation formulas with my own inputs.
Luckily if the hornresp sims are anything to go by the displacement is actually fairly low in the 30-100hz region where most of the music is.
Yes, this is quite different than the sort of music I had in mind. Honestly my reaction was not super positive, (dark ambient sounds with 1/16th note kick drums? okay)... some was OK and reminded me of Autechre if they fell in love with fast bass drums. That said, it would make a very different impression if I had had some LSD or a lot of shrooms in the past couple hours. So, probably fit for purpose? :D
Waxx
Wodecq, Hainaut, Belgium
The thing is, the people does not care about that, it's the vibe of the music in combination with the drugs they take that is what they want. Accuracy is not a factor there. I don't think you've ever been to a rave with this kind of music if you ask such questions to be honest. When i was sound engineer i was probally the only guy in the room that was not totally wasted from dope (i only smoked weed, even no alcohol). That is how it was and still is today. Most are on coke, speed (amphetamines) and/or ket (ketamine), or combinations with or variations of those drugs. They want the energetic vibes and going party all night, not an accurate sound to listen to.
kemmler3D
San Francisco
I've been to my share of raves... did you listen to the samples?? Obviously you need a certain amount of bass to get the party going, but going for a TL / horn design and sacrificing transient response is not the way forward for this particular genre. If I am guessing right, these folks are not primarily on coke, speed or ket, they're on psychedelics. Totally different vibe. But I guess OP can enlighten us as to the chemical tendency of his audience. :D
Waxx
I don't know what raves you go to, but the breakcore and psycore raves i went to most people were on ket and or speed, also in recent times. I like the music, but i'm a bit fed up with the druggy crowd (I may be a bit old for it also), so i don't go that often anymore. Psychidelics is more for goa, tribal or psytrance, not for the harder styles that go above 150bpm. Even on acid raves, speed and ket is way more common than psychidelics.
kemmler3D
San Francisco
Fair point, but listening to OP's examples of this new stuff, I couldn't really imagine (people) listening to it on anything but psychedelics. My hot take is it's a bunch of dark ambient with constant 1/16 note kicks and kick rolls over it. Describing it as high BPM is sort of misleading IMO, I would personally struggle to dance to it properly. But I'm more of a disco house guy so maybe don't listen to me. ;)
Z
Zink
Australia
Some thoughts in case you haven't already considered them as well.
You can reduce lowest mode inside by having the transducer midway of long dimension, or in case of multiple transducers put their acoustic center mid of the longest dimension. Non-parallel walls just randomize modes, and internal divider panels can make even longer paths and lower modes and so on, not really addressing any of it. They could be effective on short wavelengths, but also any damping material is. Perhaps there is something to exploit like 1/4 wave resonators, but in general the lowest mode would be loudest and hardest to tame so most problematic one. Anything that fits inside the box has quite little effect to it due to huge wavelength, hence putting transducer midway of long dimension is a good start for a good sounding closed box. If it is a problem in the first place.
If you imagine such box where woofer is middle of long dimension, for a given volume it could be relatively slim in depth and have relatively big square baffle with 1-4 woofers on it so that their acoustic center is center of the baffle. But then there is the utility, like standard truck dimensions, ply sheet sizes and so on. On the other hand, borrowing from big horn systems you might be able to get some extra output by maximizing baffle area and assemble a huge wall with the boxes. Not sure if there is enough benefit on such low frequencies though in any reasonable number of boxes and with big wall you might end up interference issues higher up in frequency requiring more processing. You'd have to make manifold kind of thing to house the driver magnet out but not sticking beyond the "baffle" robbing the volume inside, only few panels sizes and no angled panels for easy assembly though. And so on.
Thanks i will keep this in mind some useful ideas. If the driver was embedded too far inside the box is there chance it would start to cause a bandpass effect?
Cone breakup would indeed be a good explanation for the chaotic modes. The 2021 paper linked in the OP makes speculations regarding the overall stiffness of the driver in a given box but unclear to me if cone breakup modes are part of the given formula and seems to imply the occurrence is related to an imbalance between the air and nonlinearity in the suspension Kms(x). Some quotes from the article:
The experimental results suggest that the considered loudspeakers shows bifurcations and chaotic regimes, depending on the amplitude of the current. The theoretical reason for that was the nonlinear effective stiffness Keff(x), probably a consequence of the viscoelastic properties of moving parts
It is interesting to note that the theoretical explanations for the bifurcations and chaos in woofers reported in the literature, are not well established. Therefore, the adopted expression for Keff(x) in Eq. (11), even not being free from criticism, is inside that scope. But the fact is that, whatever the explanations or models, the new term due to the coupling with the sealed enclosure raises the effective stiffness of the woofer + enclosure system in relation to Keff , being now a decreasing function of V0. Therefore, the system becomes stiffer for smaller sealed enclosures, acting against the appearance of bifurcations and chaos. Moreover, beating frequencies involving f0 and its harmonics with woofer + enclosure resonance frequency f res are excited toward chaos for larger volumes and toward regular dynamics for small volumes. These conclusions, even far of being complete, are in the correct direction.
The reach of the model (3) should be evaluated noticing that the enclosure acts as a pressure reacting agent mostly affecting system’s stiffness. That is, it results in terms of the form A(x)x more than in terms of the forms B(x)dx/dt or C(x)d^2x/dt. In that sense, any other type of nonlinearity out the form A(x)x is not directly influenced by the presence of the enclosure itself. Even then, the proposed procedure for estimating the ideal volume can be promptly adapted to wider situations, taking into consideration other relevant types of nonlinear effects.
Our study also permits some predictions about what to expect in the case of vented enclosures. With effect, in this case the restoring force due to V 0 tends to be less effective when compared to the sealed enclosure. Therefore, the situation is shifted to a situation closer to that where V 0 ¼ 1, where less compression is expected but also with more distortions. In this sense, maybe our study points to an explanation for the common popular opinion that woofers installed in sealed boxes are generally more precise and musical than when in vented ones, which tend to be more efficient.
Seems that perhaps if a transducer had a completely flat Kms(x) would play a large part in reducing the phenomenon.
I'm not going to deny it's a very acquired taste and not super popular but there is a dedicated little bunch of people who can't seem to get enough of it!
You are spot on with this it's mostly a psychedelic lsd+ketamine crowd, hardcore genres don't really get played at all at these parties no hardtek, raggatek, hardstyle, hardcore or hard techno stuff at all really it's mostly psytrance and this technical fast-ish dark ambient sound psycore, DNB does make an occurrence at these events too.
Having been to a bunch of these parties and having a dozen close friends who are producers in the genre we regularly critique the sound systems and the consensus for sure is for a accurate easy listening sound with dynamic clean bass effects at high volume. The dancing style is generally more of a groovy sway rather than a jump around rave type situation.
