Pythagoras was wrong about the maths behind pleasant music | New Scientist, Nature
EERecordist
Mathematics
Pythagoras was wrong about the maths behind pleasant music​
It is said that the ancient Greek philosopher Pythagoras came up with the idea that musical note combinations sound best in certain mathematical ratios, but that doesn't seem to be true
By Chris Stokel-Walker
28 February 2024
Pythagoras has influenced Western music for millennia
Bilwissedition Ltd/Alamy
An ancient Greek belief about the most pleasing combinations of musical notes – often attributed to the philosopher Pythagoras – doesn’t actually reflect the way people around the world appreciate harmony, researchers have found. Instead, Pythagoras’s mathematical arguments may merely have been taken as fact and used to assert the superiority of Western culture.
Read more
How the history of maths is much more diverse than you think
According to legend, Pythagoras found that the ringing sounds of a blacksmith’s hammers sounded most pleasant, or…
“consonant”, when the ratio between the size of two tools involved two integers, or whole numbers, such as 3:2.
This idea has shaped how Western musicians play chords, because the philosopher’s belief that listeners prefer music played in perfect mathematical ratios was so influential. “Consonance is a really important concept in Western music, in particular for telling us how we build harmonies,” says Peter Harrison at the University of Cambridge.
But when Harrison and his colleagues surveyed 4272 people in the UK and South Korea about their perceptions of music, their findings flew in the face of this ancient idea.
In one experiment, participants were played musical chords and asked to rate how pleasant they seemed. Listeners were found to slightly prefer sounds with an imperfect ratio. Another experiment discovered little difference in appeal between the sounds made by instruments from around the world, including the bonang, an Indonesian gong chime, which produces harmonies that cannot be replicated on a Western piano.
While instruments like the bonang have traditionally been called “inharmonic” by Western music culture, study participants appreciated the sounds the instrument and others like it made. “If you use non-Western instruments, you start preferring different harmonies,” says Harrison.
Read more
Mathematicians have finally proved that Bach was a great composer
“It’s fascinating that music can be so universal yet so diverse at the same time,” says Patrick Savage at the University of Auckland, New Zealand. He says that the current study also contradicts previous research he did with some of the same authors, which found that integer ratio-based rhythms are surprisingly universal.
Michelle Phillips at the Royal Northern College of Music in Manchester, UK, points out that the dominance of Pythagorean tunings, as they are known, has been in question for some time. “Research has been hinting at this for 30 to 40 years, as music psychology has grown as a discipline,” she says. “Over the last fifteenish years, people have undertaken more work on music in the whole world, and we now know much more about non-Western pitch perception, which shows us even more clearly how complex perception of harmony is.”
Harrison says the findings tell us both that Pythagoras was wrong about music – and that music and music theory have been too focused on the belief that Western views are held worldwide. “The idea that simple integer ratios are superior could be framed as an example of mathematical justification for why we’ve got it right over here,” he says. “What our studies are showing is that, actually, this is not an inviolable law. It’s something that depends very much on the way in which you’re playing music.”
Journal reference:
Nature Communications DOI: 10.1038/s41467-024-45812-z
Somafunk
Scotland
Interesting read, I used to play/dj in key and cued up the next song with that in mind using CDJ’s so quite easy as I could sort my collection by key beforehand or do it on the fly depending on room/crowd mood.
Mixed in key
rationaltime
I call BS on this. Without knowing anything about chords, your ears tell you Pythagoras was right.
While people can play or listen to whatever they choose, the uneducated or unsophisticated ears
appear to choose music that follows the Pythagorean rules of harmony.
sigbergaudio
Norway
Isn't that exactly what the study has found not to be true? Do you have a reference (except Pythagoras himself) countering this finding?
sigbergaudio
Norway
Here's a gong chime orchestra, skipping through it I guess it's easy to get a feeling that they didn't tune their instruments and that the vocalist can't really sing - but it's probably more a cultural thing / what you are used to, which likely supports the study.
I bet these guys think our music / our harmonies sound equally weird. :)
Sokel
There where debates even back then about pleasantness.
What we think sounds western is only the surface.
For example Lydian and Phrygian scales where well known.
Have a listen to both (under the "Ancient Greek Lydian" and "Ancient Greek Phrygian" ) and their chromatic and enharmonic genera,the later won't sound western to you.
Just picking is never accurate.
MaxwellsEq
I think New Scientist has somewhat oversimplified the original ancient Greek position.
E
EERecordist
Yes, I just heard a Gamelan concert my friends are musicians in. I count as friends classical Indian musicians, Tuvan throat singers, and recordists of Indonesian and North African music. I've recorded Stockhausen, though I can't read some of his scores and a friend wrote an atonal waltz. Music is always expanding its boundaries, and music that evolved in other countries can be quite different. Brian Eno has moved on to what he calls 4th World Music.
Anton D
Wow, all around!
Thanks for such a great thread!
