Rotel DT-6000 Review & Measurements (CD Player / DAC)
VintageFlanker
Paris
Hi folks,
I am back for another review. Today's one is about the Rotel DT-6000 CD player and DAC. The latter is self-qualified by the company as a "DAC Transport", which sounds a bit unusual. It has been launched in 2022, as part of the Diamond Series line, on the occasion of the Rotel's 60th anniversary (which was really in 2021). The Diamond Series is supposed to fill the gap between the regular 15X2 midrange line and the higher-end Michi electronics. There are only two products: one integrated amplifier, the RA-6000, and the player measured here, the DT-6000. It comes at a fairly high price tag, costing 2299€ as the time of this writing. This sample has been kindly loaned to me for the purpose of this review by Masimo France (formerly Sound United), which is the distributor of Rotel products, at least for EU market.
Rotel definitely remains a traditional, old-school manufacturer. It should be one of the very last companies to still make FM tuners by 2023, as they have very few, if none, raw DACs or standalone streamers listed in their product line-up. As such, they also have a long tradition with classical optical players. While keep releasing CD players in the era of streaming is certainly kind of hazardous, I personally do have a loving relationship with the Red Book format, and would still be in pursuit of buying such a product. Besides, while I am familiar with their amplifiers, I look forward to seeing how a D/A converter from this iconic brand would perform. This unit in particular features an ESS ES9028PRO chip, and would be, as such, the first Sabre implementation in a Rotel product, which previously used Wolfson, AKM and now, TI chips.
The DT-6000 design is quite a departure from the rounded corners we used to see with their previous CD Players and Amps, such as the 1572 or 1592. You got here a much more rectangular drawing. This Player simply looks magnificent. These sides, made of polished metal, are just amazing and there is a very nice grained painting (that you cannot see on pictures) on the top steel. In brief, the build quality is top-notch. The player is rather big (41cm wide, 32cm deep) and heavy (8.1kg) and feel very solid in hands.
You get quite a few buttons on the front, and basically, every command you would need without using the remote. The disc tray seems to be quite sturdy, and works smoothly and silently. The CD playback is also pretty fast, with no disk that I could not read, even the most scratched ones. Definitely a strong quality device overall, for the few weeks I used it.​
The rear first seems very conventional, with both XLR balanced and RCA single-ended outputs. What is not that common, however, is to not see digital outputs at the back of a CD player. Yes, these S/PDIF ports are inputs only, for both optical and coaxial. There is also a USB-B input, that works through and XMOS chip and a dedicated driver. The USB-A is only here for software update.
Since Masimo allowed me to open the unit, you get as bonus a (uncommented) teardrown :​
Measurements
Disclaimer: Measurements you are about to see are not intended to be as precise or extensive than what you get from a 30k€ AP. There is obviously both hardware and software limitations here, so not quite apples to apples comparison with Amir's testing. Still, this data is enough to have a pretty good idea if the gear is bad or not, stellar, broken, or sub-par...
- Instruments : RME ADI-2/4 PRO SE. E1DA Cosmos ADC (Grade B), Minimum phase filter. E1DA Cosmos APU 60dB preamp is used for DR measurements. Output voltage is measured separately, using a DMM with a 0dBFS 1kHz tone.
- Software : REW V5.20.14, Multitone Loopback Analyzer 1.0.80 and RMAA 6.4.5 PRO,
- Method : 8 runs for each test, then I choose the closest to the average. Bandwidth and sampling rate to be specified for each test.
Note: Prior to this publication, I showed my measurements to Masimo, who put me in contact with Rotel to discuss the results.
I started my tests with the USB-B input and XLR balanced outputs.​
Rotel DT-6000 - Summary
Tests
Manufacturer's specs
Results (L & R)
Rating
Noise Level (REW)​
-115dB (stated as SNR)​
-116.0dBA​
Excellent
Dynamic Range (REW)​
99dB​
110.1dB​
Very Good
THD (REW)​
0.00017%​
Very Good
THD+Noise / SINAD (REW)
-103.1dB
-105.3dB
Very Good
IMD SMPTE (REW)​
-98.4dB​
-99.5dB​
Good
Stereo crosstalk (RMAA)​
-115dB​
-115.3dB​
Very Good
IMD+Noise @10 kHz (RMAA)​
0.00149%​
Good
Multitone 32 TD+N (Multitone)​
-88.9dB​
Average
Note: I now use a new column for published manufacturer's specs (when some are available), that gives an interesting comparison between what is advertised and what you buy at the end.​
Total Harmonic Distortion + Noise (SINAD) - 24b/44.1kHz
Frequency Response - 24b/44.1kHz
Noise Level - 24b/44.1kHz
Dynamic Range - 24b/44.1kHz
Intermodulation Distortion SMPTE - 24b/44.1kHz
Intermodulation Distortion SMPTE Versus Level - 24b/44.1kHz
THD Versus Frequency - 24b/48kHz
Jitter - 24b/48kHz
Multitone 32 - 24b/192kHz
Intermodulation Distortion + Noise (sweep) - 24b/44.1kHz
Crosstalk - 24b/44.1kHz
Alright. My first thoughts here were about the surprising correlation between advertised specifications, and my measured results. For almost every part, the DT-6000 performed according to specs, or a touch above. You may assume that this should be the norm, but it is not. Apart from some manufacturers we often see measured here on ASR, a lot of products on the market are sub-performing in regard to exaggerated numbers. In this case, I am pleased to observe such cohesive (while good but not great) benchmarks.
Now, if I take a step back, I could admit that the performance is not quite there for the high price tag. The SINAD is effectively good, but a lot of cheaper DACs will give you better numbers. Should it be audibly transparent? Most probably: yes. Yet, I have got a couple of issues (say, three, really). First is the USB-B input that shows both strange sidebands in my THD+N FFT, for which I would not mind, since it doesn't affect the THD, not to mention in an inaudible way. The second concern is... a terrible jitter performance. While the noise floor seems acceptably low, the main 12kHz sine wave seems to be kind of desynchronized in every J-tests I have run. I shared this results with Rotel, and they told that they will investigate on it. Sadly, the poor Jitter performance is not related to my specific sample, as you may see in
SoundStage's (Audio Precision) measurements here. Since they did not measure the USB-B input, tho, I will come back to the matter when commenting S/PDIF inputs. At last, I am not satisfied to see, for a product released in 2022, such an "ESS Hump" with IMD VS Level, that most Chinese manufacturers already fixed a long time ago. These aside, the Rotel DT-6000 is doing alright, for a product from a traditional manufacturer, that stayed out of the "SINAD Race" we witness here on ASR.
What about unbalanced RCA outputs?
RCA
Rotel DT-6000 - RCA Summary
Tests
XLR
RCA
Output Voltage @1Khz​
4.540Vrms​
2.127Vrms​
Noise level (REW)​
-116.0dBA​
-111.8dBA​
Dynamic range, dB (REW)​
110.1dB​
109.6dB​
THD (REW)​
0.00017%​
0.00020%​
THD+N (REW)​
-105.3dB​
-104.3dB​
IMD SMPTE (REW)​
-99.5dB​
-99.1dB​
-115.3dB​
-113.5dB​
IMD+Noise @10kHz (RMAA)​
0.00149%​
0.00160%​
-88.9dB​
-88.6dB​
Overall, very consistent results. It is rare to observe such a small drop in performance from XLR. While single-ended obviously catches more hums, it keeps the noise at reasonable levels, and both THD and IMD remain almost on par with XLR. Good.
Let's see if coaxial and optical have the same "issues" as USB...
S/PDIF
Jitter - 24b/48kHz
Jitter - 24b/48kHz
Overall, both coax and toslink are performing equal, meaning, a hair better than USB-B. Not regarding raw numbers, which are basically the same, but by looking at the shape of the 1kHz sine wave, that definitely shows a cleaner picture.
Back to Jitter, we do have here a much more stable presentation, with somehow a "readable" 12kHz tone... and a ton of sidebands around it. It still is not a good performance, even if considering the absolute level ultimately too low to be audible. As said earlier, these tests are unfortunately backed-up by AP measurements from SoundStage, that show mostly the same picture. However, when I showed these specific results to Rotel, they reacted very professionally and took the problem quite seriously. They said that their team would investigate and could work on a fix. Could this be done by firmware update only (hypothesis: a DPLL setting too aggressive) ? I hope so. In any case, there was a proposal for testing an eventual updated sample when the investigation would be done.
Now, wait. I just realized that the initial purpose of a CD Player would eventually be to play... CDs.​
CD Playback
For these last tests, I spent a short time to burn several disks to then decide which tones I would use. Since I would not be able to synchronize sweeps, there were not an option. The continuous tones, repeated for a long period (allowing me repeatability of testing) worked great. As CD is obviously limited to 16bits, I generated my files from both REW and APx Tone Generator, which are basically the same test tones I use for my 24bits testing. The tones are generated 16bits dithered, 44.1kHz.
Total Harmonic Distortion + Noise (SINAD) - 16b/44.1kHz
This is basically the maximum I could measure from my 16bits dithered file, and as, such, as transparent as it can get for a CD Playback. I remember @amirm finding almost the exact same picture in his review of the Marantz SA-10.
Just for experiment, I tried with a still 16bits PCM file, but this time generated with a 24bits dither:​
While it gives better SINAD numbers, it makes the harmonics unreadable with a very busy and blurry noise floor. I would stick to the 16bits dithered for next CD player reviews.​
Noise Level -16b/44.1kHz
For some reason, my Noise Level test is as good as what I get from 24b/44.1kHz through digital inputs.​
Dynamic Range - 16b/44.1kHz
Dynamic Range is as expected.​
Jitter - 16b/44.1kHz
While not looking that good, this is indeed a texbook perfect 16bits J-test picture, the same I may get when measuring the tone directly in the digital domain. Its ENOB even surpasses 16bits. So, the DT-6000 may do a great job with Jitter after all. It is just a pity that other digital inputs are somewhat flawed on that matter.​
It is not so easy to come with a wrap-up about the Rotel DT-6000. As a pure audio product, I really liked it. It is extremely well-built, it looks gorgeous, and it sounds good. When focusing on specifications, I would say that I praise Rotel for selling a product that performs right on specs, even when it should the very minimum from any manufacturer out there. Now, what about the performance? Essentially good, absolutely transparent for CD playback on one side. On the other hand, mostly sufficient for 24bits contents in audible thresholds. Now, is it technically perfect? No. There are some issues that should not be observable for a product at the price point. Nor that there would be any excuse from such an established company to make some compromises in designing a D/A architecture. As such, I could not give my "competent" rating to the DT-6000. The Jitter disparities come to mind at first, and their results are not acceptable at this point. Is this specific flaw audible? Not from what I heard, honestly. I also assume that most potential buyers for this Player would intend to pair it with the RA-6000 Amplifier, and I highly doubt that they would be any kind of disappointed, or disturbed by any irregularities in the analog signal. That is for sure, but what we are evaluating here are raw objective results. And in that regard, it falls short of its potential.
On a positive note, I am glad to know Rotel being aware of these measurements, and recognizing that the Jitter behavior would need for a rework. I really hope that they could come up with a fix, as I said, preferably by firmware update. If it is a DPLL adjustment as I suggested, I am sure that they could solve it that way. I sure would be glad to re-test an "updated" sample if Rotel makes the proposal. At last, I would like to thank Masimo France for sending me this sample, always knowing the risk of a bad measuring product that they actually sell. Their efforts for transparency are, again, much appreciated.​
Flanker rating: Good Enough
Matias
São Paulo, Brazil
Great review! Thanks
Rja4000
Liège, Belgium
This shows a lot of abnormal spikes which are not harmonics nor mains related.
Level is very low, but still.
This CD transport doesn't have a digital output ?
That's too bad, I think.
By the way, did you check your test CD with another player with digital output ?
Matias
São Paulo, Brazil
We now need someone to do speaker reviews in Europe and we're done!
Let's organize a funding campaign for VintageFlanker, if he has the space and is willing.
VintageFlanker
VintageFlanker
Paris
Hope there's more coming up soon! ;-)
Do you have something in mind in particular? :p
Does somebody have a personal klippel in UE ?
Yes. Dr. Wolfgang Klippel. ;)
I did! For another long time-delayed review, I measured my Shanling EC3:
When comparing to the Rotel, I got almost the exact same figures, but here through digital output at 0dBFS. As such, the DT-6000 is doing 100% perfect, but in the analog domain (I mean, at least for CD playback).
JayGilb
West-Central Wisconsin
While examining the images, I noticed this small metal contact in the rca analog outs and was curious if this is the only metal making contact with the positive plug ?
restorer-john
I'll give a try burning a test CD.
That's also something I have for a long time on my waiting list.
You can 'try' to burn whatever you want, but it will not be a valid test CD. It's just some random guy, with some test tones burnt on a CDR. It's not a standard test CD.
The only valid test CDs were pressed with extremely precise tolerances, reflectivity, pit/land specs and eccentricity.
Track down the original Sony YEDs, the Denon, The CBS CD-1, The Philips 3 disc set and/or the Pierre Verany 2 disc set.
Rja4000
Liège, Belgium
Which is why I wanted to check results with digital output.
But that will still be short of a proper test CD.
But where to find one ?
restorer-john
I could burn you a copy of any of my reference test CDs but that does not make it into another reference CD. CDR copies are not remotely the same.
Put searches into Ebay and wherever you look for discs and wait.
You should be able to find a copy of the CBS CD-1 used by everyone (stereophile etc) and it is a reference. Make sure it is absolutely mint- not even a graze on the surface.
morillon
what you describe in detail seems to me to be mainly for observing, adjusting the lazer focus part etc....in any case these the use of some of them ...or for torture test the reading etc
but for just the observations of what the conversion stages etc. produce does not seem so sensitive to me..
the cd is correctly engraved.. not damaged etc should be enough..
