Schiit Tyr mono amplifier
Matias
São Paulo, Brazil
New mono amp from Schiit - 1.6k usd each.
8 Ohms: 200W RMS per channel maximum
4 Ohms: 350W RMS per channel maximum
Matias
Matias
São Paulo, Brazil
Just waiting for the text "Audio Precision Report for Tyr" to become a link to the PDF.
Vini darko
Dorset England
won't there be magnetic coupling issues between the transformers? Surely this will harm the precious soundstage stuff or whatever.
Edit: one is a choke not a transformer. However it should still be in a different orientation to the transformer.
DSJR
Suffolk Coastal, UK
Gawd that case looks sc****!
Dvass13
I want to like it, but that's a pretty hefty price tag. And a pretty hefty package as well. I, too, will wait to see how the Soncoz amp turns out.
DHT 845
55 lbs. 12 lb choke. 160,000uf filter capacitance. 24 150W Toshiba output devices. 7 internal power supply rails, including HV boost rails that uses unique discrete CFP regulators. Sounds like overkill? It is. Tyr is our most insane amplifier ever, designed for driving difficult speakers without breaking a sweat.
Nice.
My solid state monos 20 years ago had 200.000uF / channel capacitance and ab. 200W
Just sold my last solid state monos. Now I own only 845 triode 20W monos with no-compromise mods, nothing else on planet earth sounds as good for me :) I know, subjective bs.
Rottmannash
Nashville
Just noticed the monobloc Schitt Tyr has been released for sale @ $1599 per. Looks interesting. Specs:
Power Output:
8 Ohms:
Frequency Response: 20Hz-20Khz, -0.1db, 3Hz-500KHz, -3dB
THD: <0.01%, 20Hz-20KHz, at 200W RMS into 8 ohms
IMD: <0.01%, CCIR, at 200W RMS into 8 ohms
SNR: >125db, A-weighted, referenced to full output
Damping Factor: >200 into 8 ohms, 20-20kHz
Gain: 22 (28dB)
Input Sensitivity: AKA Rated Output (Vrms)/Rated Gain. Or, 40/22. You do the math.
Input Impedance: 47k ohms SE, 47k ohms balanced
Inputs: RCA for SE input, XLR for balanced input, rear panel switchable
Topology: Nexus™ discrete differential current feedback gain stage, no coupling capacitors or DC servos with Continuity™ constant transconductance output stage, all BJT output
Oversight: microprocessor-controlled monitoring and management of critical operational points, including DC offset, with standby mode and relay shut-down for overcurrent, thermal, and other faults
Power Supply: 600VA transformer with 600VA choke input to main rails, plus boosted, regulated supply to input, voltage gain and driver stages, plus separate, isolated and regulated rails for microprocessor management.
Power Consumption: 750W maximum
Size: 16” x 13” x 3.875”
Weight: 55 lbs each
Matias
Matias
São Paulo, Brazil
And its chapter here:
Rottmannash
Nashville
jae
Nice.
Is there a dislike button? ;)
Jokes aside, I have no idea who is supposed to be buying this product.
Rottmannash
Nashville
There is an large group of audio enthusiasts who worship at the Schiit Altar. They will post multitudes in various fora about the newest upcoming product they release. Someone on the Schitt thread "Schiit Two Channel Clubhouse" has already placed an order.
garbulky
Nice.
And what are those tube amps called?
