Setting up an active crossover using Roon
manisandher
Royal Leamington Spa, UK
Recently, quite a few people have asked me how I've gone about setting up active crossovers just using Roon alone. I thought I'd start a thread to discuss the process. I'm just going to dump a number of screenshots, which are hopefully fairly self-explanatory (if you know Roon, at least). We can then go into more details should people have further questions.
Process to follow shortly.
Mani.
ahofer
New York City
EQ/DSP and multi-point casting?
manisandher
manisandher
WARNING: I am assuming that you have played around with digital or active analogue crossovers before, and that you are familiar with the characteristics of your drivers (optimal bandwidth, power handling, etc.). Accidentally low-passing a tweeter with a high power beyond its capabilities may permanently damage it.
I'm going to take you through how I set up the active crossovers in my office system. The chain is:
Music Server (with Roon Core) -> ethernet -> Win 10 PC (with Roon Bridge) -> USB -> MOTU UltraLite-mk5 -> 6x Neurochrome 286 mono amps -> 3-way speakers
The speakers are a pair of old Impulse H2s, popular in the UK in the '90s. They are particularly good for going active because they have 3 sets of binding posts on the rear. They have a recessed horn-loaded mid, and a rear horn-loaded bass. Roon's DSP allows time alignment, which I found particularly useful.
I've ripped out the internal passive crossovers, and have hardwired each driver to a pair of binding posts. So, each mono amplifier's output is connected directly to a driver.
1. Set up channel mix
Here, you assign the 2 input channels to the DAC's output channels:
I have assigned input channel 1 to the UltraLite's output channels 1, 3, 5, 7, and input channel 2 to the UltraLite's output channels 2, 4, 6, 8. I have reserved output channels 1 and 2 for headphone listening, where I want to bypass the crossovers.
Also, you can see that I'm level-matching by setting the gain/attenuation for each driver. I've determined this by measuring each driver nakedly using a 20Hz-20kHz sweep. You may have you own preferred way of doing this (e.g., REW, etc.).
2. Set up LF channel
Set up the low-pass filter:
Assign to output channels 3 and 4:
3. Set up mid channel
Set up pass-band:
Assign to output channels 5 and 6:
4. Set up HF channel
Set up high-pass filter:
Assign to channels 7 and 8:
5. Set up time delays
And that's pretty much it! Feel free to ask questions.
And the end result (taken with my old phone, so not great SQ quality):
Mani.
manisandher
manisandher
ahofer
New York City
What do you mean by 'multi-point casting'?
Multiple endpoints. Never mind, I've never used multi-channel before and that's where you separate each driver's EQ. Cool. I presume you could do subs that way as well, but I don't think you could adjust time/phase delay.
manisandher
manisandher
I have subs in my 4-way main system. It's the exact setup as above, but with output channels 1 and 2 assigned to the subs. Yep, I'm adjusting the time delay there too.
Dathzo
Set up pass-band:
Mani.
Great, thank you! This is very informative! I have ordered mi Motu MK5, but delivery times are long. I will certainly get back to it. I understand you also have the Okto Pro. Which of the 2 DACs you prefer @manisandher?
Savi
Really nice to share. One day I would like to try the same setup.
There is also a excellent thread with rpi4+camillaDsp solution, any opinion on pros and cons of the two solutions ?
Maybe it is a stupid question but with this setup you are limited to listen music with roon ? Ones a week I use my speakers to watch a movie, or to listen to a podcast... You confirm that there is no solution for this ?
Thxs
manisandher
manisandher
I haven't compared them directly, but would be amazed if they sounded very different from each other. One major difference though is that the Okto works plug 'n' play with Linux, whereas the MOTU doesn't (at least with kernel 5.10 and earlier). And of course, that the MOTU has an ADC!
Mani.
manisandher
manisandher
I haven't tried that. I have to say that I've been able to achieve everything I wanted just using Roon, so haven't looked elsewhere. It's a very straighforward solution.
Yes, that's the limitation in using Roon's DSP - you have to use Roon.
Mani.
Dathzo
Mani.
Thanks a lot! I’m aware that one user from the Roon forum (Burkhardt_Petermann), had some issues with the Okto and Linux (RPi), so may be tricky in some cases, perhaps different firmwares. But it seems that the Motu is a great unit for its price at this moment.
Thank you again!
Nspace
This looks interesting. However without wanting to derail this thread, maybe someone who has gone to this length may explain what is fundamentally difficult to yet stopping the use of in the box software to do the crossover interfacing before Ultralite Mk5...
One would think that with nowadays CPUs, RAM, etc. induced latency wouldn't be significantly different with or without this extra software step, provided everything would be done internally without no additional conversion.
Then is the potential issue of "Accidentally low-passing a tweeter with a high power" as you put it manisandher, which would require careful set up, and possibly some emergency measure? in case something gets off limits.
Am I missing something? Or is just a case of finding the vst-container/standalone software to be added before Cuemix?
dadregga
I've been using this for about a year in a MCH 5.1 setup into a HDMI AVR input as well (bypassing AVR sub crossover and room correction stuff with Roon crossver + Roon DSP using REW filters) - works fine.
People object to the cost, which is understandable, but Roon has a pretty remarkable DSP engine, and if you use that + the multi-room endpoint stuff + room correction, the cost begins to look more reasonable - and it means I need fewer boxes (since I already have a home server) and a simpler output chain.
ClassicalDJ
DFW
I have been experimenting with Roon’s procedural EQ in a similar setup using a Linux-based endpoint connected via HDMI to my AVR, however I’ve not been able to overcome a rear channel mapping issue for 5.0 files (5.1 files seem to work fine, however “subjectively” something does not seem quite right when compared to just using the AVR’s crossover with no other room correction enabled). Have you been able to successfully map 5.0 channels in your setup?
dadregga
Yep! I'm using a miniPC Intel with Volumio's OS installed for the Roon bridge endpoint. Channel mapping for the HDMI out worked out of the box, which I validated by playing back a series of test files with per-channel callouts in 4.0/5.0/5.1 format thru Roon.
I used these: https://www.quadraphonicquad.com/fo...lac-with-various-channels-sample-rates.24032/
there are many other sets, but that will quickly sort out whether you have a mapping problem.
Even if the mapping was incorrect, you can remap any channel to any other channel your output device exposes in Roon, so it should be possible to fix any channel mapping error even if the hardware isn't wired up correctly.
ClassicalDJ
DFW
Yep! I'm using a miniPC Intel with Volumio's OS installed for the Roon bridge endpoint. Channel mapping worked out of the box, which I validated by playing back a series of test files with per-channel in 4.0/5.0/5.1 format thru Roon.
Even if the mapping was incorrect, you can remap any channel to any other channel your output device exposes in Roon, so it should be possible to fix any channel mapping error.
Thanks! I'll use these to troubleshoot and hopefully fix my issues.
On a related note, do you use any Procedural EQ steps unique to the file type (5.1, 5.0, 4.0)? For instance, I have inserted a Mute LFE step at the beginning to filter out any "real" LFE information from 5.1 SACD rips (from my understanding the main channels already contain the full frequency range) and avoid excess bass volume. Also if I had 4.0 files (I don't currently) I might consider using less channel trim than for 5.0/5.1: -12dB (25%) vs. -14dB (20%) per channel.
dadregga
I do not, no.
Yes, I'm familiar with the debate about this. The issue is that:
1. I have a mixture of SACD and non-SACD rips, so I can't simply mute LFE in all cases, because it is not always true that the LFE is 100% redundant with information in the other channels, for all recordings/masterings.
2. My understanding is that it is also not always true that the LFE is 100% redundant with information in the other channels, for all recordings/masterings, even for SACD - it simply varies by disk and there is no consistent standard.
So, I just don't worry about it, and haven't found instances where it bothers me. I imagine you could do something like "always mix the LFE channel into the other channels via Procedural EQ, then after that step, apply the sub crossover".
ClassicalDJ
DFW
I do not, no.
Thank you for your advice and the very helpful testing files. I've been able to solve my channel mapping issues (turns out the LFE channel mute was one of the culprits, and an unnecessary step anyway as I had already left LFE > LFE off my channel mapping step).
anphex
Berlin, Germany
Thank you for pointing me to this thread. Really nice stuff and surprisingly simple!
Looking at Roon makes me worry about flexibility since it forces me to use Roon. At least I would love to have something OS-wide.
So I dug a little more into Equalizer APO for Windows and voila - it has a nice little nifty option called "copy" where you can copy a channel to another channel, which is basically a bus send. With the option "mixing stage" you can set that to pre or post fader and your options basically become limitless! FIR-EQ and delay are incredible simple to make with REW there.
Another option - currently probably the only option - is getting this stuff for your whole hifi system with a MiniDSP flex eight. But it's currently not available in Germany. Also, it's unbalanced, which isn't so great in the long term.
Thank you again for this guide and this inspiration. Maybe I'll do a threat exactly like yours for E-APO.
manisandher
manisandher
