Yes digital or analogue inputs and the Hypex amps have built in EQ.Does this speaker have an internal DAC that reprocesses the analog signal or can its internal amplifier be driven directly by an external DAC?
It's required for the DSP. What's your goal here, as you can pass the signal digitally and eliminate reprocessing?Is the best solution achieved by arriving at the manta in digital or is it possible to bypass the internal DAC and convey an analog signal without reprocessing?
ok! is it known which DAC is used for these speakers?È richiesto per il DSP. Qual è il tuo obiettivo qui, dato che puoi trasmettere il segnale digitalmente ed eliminare la rielaborazione?
I don’t know the dac implementation in the Mantas I can ask, you can’t bypass the internal dac that’s the same for every contemporary active loudspeaker.
Dacs are done, absolute state of the art performance is available very inexpensively, just look at any of Amir’s dac measurements.
I certainly like the convenience of the AES/EBU inputs and pass-through on each speaker!
SPL Horizontal Radar charts are available for Manta?
Keith, Would you rate them number one in your stable of speaker choices at that price level currently?Mantas are superb speakers imho
Robo you would have to make that decision for yourself!Keith, Would you rate them number one in your stable of speaker choices at that price level currently?
Unfortunately none of these speakers are in New Zealand. What are the Roland M3's?Robo you would have to make that decision for yourself!
Seriously if you considering a contemporary active design they have to be on your list, along with the 8Cs and Roland’s M3 although I haven’t heard those here yet.
