- Joined
- Aug 31, 2018
- Messages
- 305
- Likes
- 689
- A new series of exterior design with tempered glass panel, both high-end feeling and durable!
- Cirrus Logic's latest audio decoder chip CS43131, with carefully designed circuitry, achieves an unprecedented 0.00013% (-117dB) distortion performance!
- The new third generation XMOS XU-316, PCM support up to 32bit /768kHz, DSD support up to DSD512.
- USB support MQA full decoding;
- Bluetooth 5.0 digital audio input, external antenna, farther transmission distance.
- The clock system uses independent ultra-low clock jitter, ultra-low phase noise for the audio clock.
- Built-in high-efficiency power supply chip for the decoder to provide sufficient energy, and the use of multiple groups of low-noise LDO power supply.
- The use of a large number of audio-specific audiophile resistors and capacitors.
- The use of 1.29 "OLED display.
- Fully balanced design, and has a true balanced output.
- With 6.35mm, 4.4mm balanced headphone output.
- Equipped with full-featured remote control and preamp function.
- All aluminum CNC precision machining chassis to effectively reduce the thousand disturbances.
- Inputs:USB / Optical / Coaxial / Bluetooth
- Output Level:RCA 2.0Vrms XLR 4.0Vrms
- THD+N(UN-WTD):0.00013% (-117dB)
- Dynamic range (UN-WTD):RCA 120dB XLR 132dB
- SNR (UN-WTD):131dB
- Bluetooth:BT 5.0 ( support SBC)
- USB transmission:Asynchronous
- USB compatibility:Windows 7 / 8 / 8.1 / 10 Mac OS X10.6 or Later / Linux
- Bit depth: USB:1bit ~ 32bit
- Optical/coaxial:16bit ~ 24bit
- Sampling rate: USB:44.1 ~ 768kHz DSD64, DSD128, DSD256, DSD512
- Optical/coaxial:32 ~ 192kHz
- Power Consumption:3W
- Standby power:<0.1W
- Size:70x73x165mm (WxHxD)
- Weight:0.54Kg
Click for more:https://hifi-express.com/products/smsl-m300-se
