Sonore MicroRendu Hardware Teardown and Review
RayDunzl
Central Scrutinizer
Riverview FL
The "sound" of the difference file above is "white noise" or close to it.
manisandher
Royal Leamington Spa, UK
Do you think this 'white noise' could have had an audible affect on the original 'digital' files, #2 and #3 (recall my descriptions of the differences I thought I heard)?
Mani.
RayDunzl
Central Scrutinizer
Riverview FL
It would seem to be in both files, and not represent a "difference".
Assuming it could be heard at all.
manisandher
Interesting!
Any news on how the 'analog' files fare?
Mani.
Blumlein 88
Trival, but transport B is clocked about 27 ppm faster than perfect speed, and transport A is about 8 ppm faster clocked than B. Not that those will create anything you could hear.
RayDunzl
Central Scrutinizer
Riverview FL
Analog:
There's a slight level difference between 8 and 9 - about 0.062dB - maybe.
The difference file (after amplification) sounds like the source music.
Adjusting the level doesn't eliminate difference.
Beyond that, inconclusive.
When comparing analog you have to expect to see some differences when looking closely. Values of analog components cannot match perfectly. Look at two of anything with a microscope and they won't be "the same".
A 90dB microscope would have about 31,622 power magnification, in terms of energy, 90dB is 1,000,000,000 times magnification.
Unexpected:
The channels are reversed in 8/9 compared to original, files 2 and 3 are not reversed. Maybe you swapped cables around and missed.
Glitch in both 8 and 9 at 0.045 seconds from the beginning of the data, not in 2 and 3.
Blumlein 88
Just listening to amplified difference of 8 and 9 there is a shift to a brighter sound. Usually the result of timing shifts from the clocks not quite being the same speed. You get an upward 6 db tilt per octave in the residual. Otherwise seems no reason they would sound different.
RayDunzl
Central Scrutinizer
Riverview FL
For analog captures we need a control so that we can understand the chain/pipeline better. A simple one may be capturing the same data twice. We can then look at the differences that may be due to drift, temperature, etc.
RayDunzl
Central Scrutinizer
Riverview FL
For me, now that I have begun using DSP to correct aberrations caused by the speakers and the room, I' may have made some adjustments to things I consider "material" to accurate playback. Maybe I'm no longer too worried about minute differences since I impose gross differences before I listen.
Output of a sweep tone (frequency response) from the preamp's right channel, before (green), and after (red) DSP (room correction).
Phase:
fas42
Australia
If anyone has the time, skills, equipment and/or inclination to analyze file #2 and file #3 on a digital analyzer, feel free to do so. Otherwise just taking a listen to them should suffice, provided your system is of reasonably high quality. Of course your system will add it's own character to all 3 files as they're played back, but this character will be added equally, and you should still be able to determine which of #2 or #3 sounds closest to #1 - I can easily do this on my Ponoplayer!.
Only just tuned into this thread addition, but thanks for putting it up, Mani. Agree, one version is quite superior as a closer match to the original - quite a bit of life and sparkle has been lost in the poorer version.
Blumlein 88
Well diffmaker when it works is good. On the track 8 vs track 9 it shows null depth 93 db left/97 db right. That is essentially going to be the system noise floor.
Amir is right about a control. When I do such things I usually run the same gear twice. Compare something to itself a few minutes later. Chances are transport A differs from transport B by no more than transport A will differ from transport A 5 minutes later.
fas42
Australia
And have just read though to your subjective evaluation, Mani - and agree! This is just via laptop in-built speakers, with almost no optimising of the playback that I sometimes do.
I note some members are hard at work getting a handle on it - good to see!
For those who are not picking it, when listening - with the inferior version, your brain is working harder to reconcile the copy with the original; if you pay attention to the level of "stress" in your head you can feel the analytic side of your mind "working" to make the copy match. With the original, one can completely relax, and the sound just flows ...
RayDunzl
Central Scrutinizer
Riverview FL
90dB relative...
That would be like hearing a penny drop onto the pavement from a one -inch height while standing next to your running lawnmower.
Even that might not be a full 90dB difference.
I have 4 standard staples still stuck together but broken off the strip.
Here is what the microphone picks up, from 5 feet (measured) away, and off axis, when I drop them from 1/2 inch onto my desk:
My normal loud music listening would register 80-85 dB across that chart, and I don't think I'd hear the staples hit the desk sitting over by the mic (at the listening position), and that would be only a 5odB relative difference.
Of course, I won't win any Golden Ear awards.
fas42
Australia
Silly boy, me - I missed the post about 8 and 9 being available - getting hold of them now ...
fas42
Australia
OK, listened to versions 8 and 9. Again, no contest - 8 has a piece of cloth draped over the mic, that's the subjective impression. All the attack elements in the sound have been dulled, it's boring to listen to.
RayDunzl
Central Scrutinizer
Riverview FL
I hear no difference 8/9.
Time for fas42 to try an ABX, I think.
RayDunzl
Central Scrutinizer
Riverview FL
Sal1950
The Chicago Crusher
Central Fl
Well, it would probably fall upon even deafer ears than mine...
Thanks for the huge effort you put into this Ray. From aggressive measurements like this we continuously learn about how sighted listening bias creeps in to cloud our impressions.
Great job!
