Some find they get a wider sound stage with less or no toe in. But all depends on how the speaker is designed.
If you look at these speakers for example, they offset the tweeters to the wrong sides. They do this to enhance soundstage width. They recommend no toe in. I have a friend that has them. Not my cup of tea.
Tell your friend he can experiment; reverse their position, and still no toe-in.
* A wide dispersion speaker with good off-axis response is a very interesting mechanical device to experiment with...regarding toe-in.
Our room's parallel side walls are its matching partners for the kind of sound reproduction we'll be collecting @ the MLP.
If we try different toe-in say every six months and live with it for that time period, and then change it for another six months...it could become revealing the type of music and recordings that adapt better to this toe-in or that one. ...We can do that for twenty years, with always a different amount, in the same exact room, or we can switch rooms or even houses or even loudspeakers.
How much space should be around a speaker, like from it's nearest surface? Zero, because the floor is making contact with the loudspeaker's footprint, bottom plate.
Ok, about then from the front wall? ...Side walls? ...Ceiling? ...And is each speaker better @ certain amount of toe-in, or is it a personal sound preference?
Do we go with pleasant measurements and from judicious room treatments, and do we also use our ears to assess and evaluate our personal sound pleasantness?
Do we hire an expert with sophisticated acoustical tools and equalizers and trust his scientific expertise without sweating the small stuff and live happily ever after, or do we use that money to buy music recordings we love with our own sound adjustments? We'll never know for sure till we experiment with all possibilities, that we try all the loudspeakers in the market, that we test every room, tra-la-la... If we keep a realistic head on our shoulders we balance "our sound" with what we have without stressing too much.
I remembered living in different homes with different speakers and experimenting with toe-ins almost everyday. I was twenty, and younger, and older too.
Now, some folks have speakers that weight 750 pounds each. And those same folks are not twenty but sixty, seventy and over eighty. Unless they take a lot of hormones and viagra pills, most of those folks you won't see them much experimenting with toe-ins. Better to hire a construction engineer with a forklift in your room.
Alright, let's fall back to science fiction now, our true passionate audio hobby. Methinks that offset tweeters in speaker's front face are a good start to experiment with no toe-in @ all...firing straight @ the room's back wall.
And, it all depends; side walls proximity, distance between the two speakers, ...to the listener, and if it's a dedicated stereo room only or playing dual roles as a multichannel music room too...like with a pair of surround speakers and a center channel speaker. ...Say five full range exact same loudspeakers (20Hz-20kHz).
What's the toe-in of each of them five speakers now? ...The center channel is easy...straight @ the MLP, and is it the same with the main front L & R speakers plus the pair of L & R surround speakers...all firing straight @ the MLP?
Play with toe-in.
