Andysu
- Joined
- Dec 7, 2019
- Messages
- 3,120
- Likes
- 1,650
My THX home cinema inspired by the Empire Leicester Square.
Always wanted THX pro cinema which is different ballgame to home consumer THX.
Always wanted a Dolby Stereo CP200 which is regarded as the best cinema processor made even still to this day found only in Selected Theaters.
Always wanted JBL professional cinema.
What I couldn't get at reasonable prices is the JBL Urei 6290 amplifiers, some people are asking way too much for them that is discontinued and no longer supported by JBL Harman international, unless really good and can service the parts with new components. So I went for more powerful and class-D amplifiers that are cheaper.
JBL 4647 with JBL 2226 15" bass drivers the cab boxes was mega ultra cheap so I grabbed all five cos I knew I could have a better five screen matrix.
JBL 2380A horn with JBL 2445 compression driver which is not all far off from the ones I heard with a JBL 2360A thou are about usable down to 250Hz.
Only thing I don't have is duel 35/70 projector even thou offered 35mm Vic V, with red Dolby digital LED and low powered lamp house for £250.00 years ago and the Vic V, in it's day was 35 grand.
Still issue with 35/70 is the colour fading and then stuck with a dud that will still play unlike Waner bros HD-DVD discs that are useless! Storage of film prints must be kept in ideal temperature conditions, and frankly my dear, I just don't have the space room for film prints and often some sellers are bit greedy in the prices so it is a no from me.
Laser 4k projection on 120" acoustical transparent screen will suffice it starts up fast and powers down fast as well.
The other side of it most some Laserdisc with theatrical mixes beats any blu/4k disc, day and night. So least I have media disc formats and even some few VHS leftover.
Laserdisc is still in use here and very little use 4k gets played now cos of the studios making it a laughing stock with bad transfers just so they can ridiculously Milk consumers, which I don't find amusing at all. HD-DVD is no no from me, won't be buying anymore HD-DVD it is a dead format. VHS doubt I be buying any VHS only what I have kept over the years will suffice for some playback (very rarely here). Laserdisc/DVD is still a format I will buy depends on the rarity of the item, bluray/4k is format I have steadily backed away from due to applying upmixes for Dolby Atmos just so studios can yet again Milk consumers who don't know what to look for and listen for.
But does all this make my life any happier? No it doesn't it is just an immaterial entertainment and that is all it is and will be. I rather have cats to pet than my home THX cinema.
Sooty 2009-2020 dearly and sweetly always will be missed.
Magic
Bear
Main Cinema processor system and consumer AVR with some players in the room - Laserdisc players are kept in the kitchen so the noise floor will be silent when they are in use.
DOLBY STEREO® CP200 a must have if your an original Star Wars fan thou I personally find Star Trek movies sound better. Dolby Stereo CP200 was released March 1980 and was discounited around early 2000's and servicing or parts for it a little later so it stood test of time cos it was best processor ever made for 35/70. It took me months to find the rest of the units to fully complete the CP200 and it stands at least 28" high.
Dolby CP200 control unit
Dolby CP200 processor unit with Dolby A-type cards and be switched around for Dolby SR cat 280t cards.
Dolby CP200 accessory unit also has extra Dolby NR card slots
Dolby CP200 MPU-1
Dolby CP200 PS1B power supply
Dolby CP500 in the lower part of the rack
Dolby SDU4 x2 for five screen matrix - of inner channels left-centre right-centre / inner channels can also be used as stereo for non-sync music to set the cinema tone just like, well is the cinema or can be used as stereo on outer channels L R.
Dolby CP45 used for main surround fader for side-surrounds or surrounds and can be used as decoder for Below Surround that places sounds below the seating.
Sony SDDS DFP-D3000 great for use as auxiliary processor and even has a built in matrix surround decoder and many more channel formatting to switch channels around which the Denon AVC-X8500H can't do.
Behringer MDX4600 x2
Behinger DCX2496 x4 and fourth is in amplifier rack
Two of the DCX are used for Left Centre Right the second DCX used for Left-centre Right-centre and SW left and right at front of the room
Third DCX used for extra SW that is middle placed behind the screen and other at back of the room and can be switched to play the SW with the other JBL subs or used for Surround Bass Extension to give a lot more lower end to the surrounds. Also bass shakers for Irwin rocker seats, seat-buckets and on the floor as well.
Behringer DEQ2496 for use with Dolby Stereo Lt Rt
Main rack for the 38.000kw THX sound system - Laserdisc players are in another rack tower with Lucasfilm Ltd THX Sound System crossover/monitor 3417 very rare to get one of these now.
Behringer EPQ304 for use with JBL screen HF horns
Behringer inuke D3000 for use with JBL SW 4645/C
Behringer NX3000 for use for JBL screen bass drivers and some JBL 4682 TCB SW
Behringer NX D3000 JBL control SB-2 with control 1 for Below Surround matrix
Behringer DCX2496 used for the side surround channels each has its own feed to the Crown CTs8200 so I can make quick Re-EQ turning depending on the movie mix playback to cut back on mid or highs or give it a bass boost or a gain level increase to suit the movie best playback possible.
Dolby SA10 for use with Atmos decoding and expansion of the substandard Atmos x6 channels up to 12 channels playback depending on the encode/decode of the mix. This gives me new channels that are placed between each height 1, 2 and 3 that I call DOG channels Dolby Overhead God and some Extra channels that are placed on the floor that sounds like a vertical circle effect for each zone.
Crown CTs8200 use for side surround arrays just like at a cinema. Back surrounds. Other CTs used for Overhead surrounds up to x9 Overhead surrounds are used here with Extra channels as well that are placed on the floor. JBL 8330 mkII JBL 8330A JBL control 1,
Alesis RA300 bass shakers for seat buckets - other RA300 for floor shakers
Up to 157 speakers 38.000kw THX.
Magic
Bear
Dolby CP200 MPU-1
