Toslink switch and TosLink/Coaxial SPDIF converter - Review and measurements
Rja4000
Liège, Belgium
I measure-checked 2 digital Toslink devices :
Toslink switch + Bi-directional TosLink/Coaxial SPDIF converter
I needed to extend my digital inputs capacity for home living room and another location.
So I purchased
- a 3 inputs - 1 output small TosLink switch - with remote. (30€ - Audiophonics)
- a bi-directional Coaxial/TosLink SPDIF converter (26€ - Amazon.fr)
Both are pure digital SPDIF devices.
No DAC or ADC here.
As you may see on the picture, those are VERY small devices.
Even the remote is tiny, compared to the XLR connector that holds it straight.
The TosLink switch has 3 inputs and 1 output.
Input may be selected through the remote or the front switch.
The Coaxial/TosLink SPDIF converter has a coaxial SPDIF (RCA connector) and a Toslink on both sides: Inputs on one side, outputs on the other side.
A switch allows to select which of the 2 inputs you play from.
Both outputs are then receiving the signal (More on that later)
Both devices are powered with 5V and come with corrsponding USB connector.
The convertor came with a 5V adaptor, but with a US plug, so not really usable for me.
I wanted to validate those devices for transparency.
So I've set-up some measurements using a RME UCX II (digital source) and the RME ADI-2/4 Pro SE.
As Amir is doing, I measured performance on the analog side, after the DAC receives the digital signal through the device I wanted to test.
If they are transparent, we should see no difference in measurements.
1. Testing with the RME ADI-2/4 Pro SE as a DAC
First, I've performed measurement with my ussual tool, the RME ADI-2/4 Pro SE as a DAC
I measured the analog loopback (DAC + ADC) of the RME ADI-2/4 Pro SE when fed with a digital signal coming through those devices.
Warning: This will be boring !
So you may want to jump to the next paragraph directly ;)
SINAD
Because I wanted to check the functionality, all SINAD tests here were perfomed at 192kHz.
First, through the TOSLink switch
NB: I tested the 3 inputs, and there is no difference
Then through the Coaxial>TosLink SPDIF converter
Then the same converter but in the other direction: TosLink > Coaxial SPDIF Converter
And, in case you were wondering, the RME ADI-2/4 with SPDIF input (analog loopback)
Jitter
To save some time, I cascaded the 2 devices:
> SPDIF Coax > Coaxial/TosLink SPDIF converter > TosLink > TosLink Switch > TosLink > RME ADI-2/4
JTest UCX II - RCA - RCA-TosLink Converter - TosLink - Toslink Switch - TosLink - ADI-2-4_crop..png
then
> TosLink > TosLink Switch > TosLink > Coaxial/TosLink SPDIF converter > Coaxial SPDIF > RME ADI-2/4
JTest UCX II - TosLink - Toslink Switch - TosLink - RCA-TosLink Converter - RCA - ADI-2-4_crop..png
Multitone
Multitone tests were performed at 192kHz.
Same here
> Coaxial SPDIF > Coaxial/TosLink SPDIF converter > TosLink > TosLink Switch > TosLink > RME ADI-2/4
MT32 UCXII - RCA - RCA-TosLink converter - TosLink Switch - Toslink - RME ADI-2-4_crop..png
Then
> TosLink > TosLink Switch > TosLink > Caoxial/TosLink SPDIF converter > Coaxial SPDIF > RME ADI-2/4
MT32 UCXII - Toslink - TosLink Switch - Toslink - RCA-TosLink converter - RCA - RME ADI-2-4_cr...png
Just perfect.
I told you this would be boring :D
2. Testing with the Topping E30 II Lite as a DAC
I've been challenged on the fact that the RME is almost a "perfect" tool.
So there is a risk the test is not relevant, since the RME would fix any issue with the incoming digital signal.
That looked like a valid concern.
So I took a DAC I had at hand that I knew had some issue with Jitter on SPDIF input:
The Topping E30 II Lite I reviewed here.
So... here we go again.
This time I started with
Jitter measurement
Direct input in the DAC
RME ADI-2/4 Pro SE optical output > TosLink > Topping E30 II Lite > Analog output (L) > RME ADI-2/4 Pro SE
As you may see in the Topping E30 II Lite review, Jitter performance on SPDIF has some issue.
Not catastrophic;, but not stellar either.
First, for reference, with none of the devices we want to test in the loop.
Here, I kept the measurement of the highest secundary peak, to allow some comparison.
NB: This figure doesn't mean much by itself - don't compare it to a SINAD value !
Through the Coaxial/TosLink SPDIF converter
> Coaxial SPDIF > Coaxial/TosLink SPDIF converter > TosLink > Topping E30 II Lite > Analog output (L) > RME ADI-2/4
Here, we see a difference ! And this is not good.
The second peak (and all other peaks) raised by almost 12dB.
Is that a concern ? I don't know.
Let's try the other direction
(More important, since that's the one I, personnaly, plan to use ;))
> TosLink > Coaxial/TosLink SPDIF converter > Coaxial SPDIF > Topping E30 II Lite > Analog output (L) > RME ADI-2/4
In that direction, we have less degradation of the result.
At least that's good.
It's still an average result, but it didn't become much worse than what the DAC can do.
Through the TosLink switch
> TosLink > TosLink Switch > TosLink > Topping E30 II Lite > Analog output (L) > RME ADI-2/4
Same here.
Not worse than what the DAC can do.
SINAD measurement
Let's check the impact of this on SINAD, if any.
(As above, SINAD measurements here are at 192kHz)
Our reference here.
SINAD 192kHz BH7 E30 II Lite TosLink through converter (RCA input)_crop..png
Not much impact.
SINAD 192kHz BH7 E30 II Lite TosLink through converter (TOSLink input)_crop..png
A bit more distortion, maybe. Still excellent.
We see again a slight decrease in performance.
That remains very good, though.
Interestingly, the performance here degrades in the opposite direction than the Jitter above.
Why ? No clue.
Multitone measurement
That's our reference.
Same thing: a bit more noise, but result remains excellent
The other direction
Nothing to complain about
A bit degraded still, but anyway still very very good.
We have seen some degradation with using a less performant device.
The Jitter test - which was meant to be very sensible to Jitter and other digital domain issues - shows some degradations, for the SPDIF converter (especially in the direction from Coaxial to TosLink).
Nevertheless, that doesn't really show in any of our classical analog measurements, which all score very good.
So it's probably benign.
3. Functionality
ADAT capabilities
Following a question of @Blumlein 88 , I'm happy to say that the small switch also works with 8 channels ADAT @48kHz
I've done a quick setup as follows:
PC generator > to 8 Dante channels (Dante controller) > to 8 ADAT output channels (RME 12Mic-D routing) > TosLink > TosLink switch > TosLink > UCX II
And we see the 8 channels in TotalMix
Port replicator capability of the SPDIF converter
The convertor always has both its outputs active.
When feeding the Coaxial/TosLink SPDIF converter with a TosLink input at 192kHz, the Coaxial output works perfectly, but the TosLink output's clock sometimes gets out of sync.
I didn't experience this issue at 44.1kHz, 48kHz and 96kHz though.
So it's acting perfectly as a converter, but it may give some issue to duplicate the output at high sampling frequency.
4. Conclusion
This review I thought would be quick and easy, and at the end, it took me almost the whole day...
But we learned a few interesting things.
After testing with the RME only, I wrote "Those devices are adding or substracting nothing to the signal they receive".
After further look and check with the more Jitter-sensitive (and way cheaper) Topping E30 II Lite, this is not absolutely true.
There are measurable performance degradations.
I still think we may trust those devices to do exactly what you want them to do.
So I would rate them as
Good for the job
(with this specific config)
Also, it's important to note that, even if those devices are not perfect, they absolutely don't prevent a well engineered device to perform perfectly through them.
So that's not -not only- those devices' "fault" if the Topping is giving some lower results with them.
Good engineering is not only about good raw figures.
It also gives you more freedom.
Blumlein 88
These could be useful to me. How about the names and maybe links to them?
Also could you confirm if either works with ADAT? That would be really handy.
R
Rja4000
Liège, Belgium
RandomEar
Very useful info! And impressive to get to 120 dB SINAD using RCA for less than 20$. That's as good as the best DACs around - I'm surprised.
Small oddity: The text describing the signal chain for the last two images is identical. Is that correct?
morillon
Hi
Toslink switch + Bi-directional TosLink/RCA converter
So I purchased
- a bi-directional TosLink/RCA converter (26€ - Amazon.fr)
The RCA/TosLink converter has a RCA and a Toslink on both sides: Inputs on one side, outputs on the other side.
As Amir is doing, I measure performance on the analog side, when the RME ADI-2/4 receives the signal through the device I wanted to test.
So you may want to jump to the conlusion directly ;)
SINAD
Then through the RCA>TosLink converter
Then the same converter but in the other direction: TosLink > RCA Converter
Jitter
> RCA > RCA/TosLink converter > TosLink > TosLink Switch > TosLink > RME ADI-2/4
then
> TosLink > TosLink Switch > TosLink > RCA/TosLink converter > RCA > RME ADI-2/4
Multitone
Same here
Then
Conclusion
The conclusion is quite obvious.
Those devices are adding or substracting nothing to the signal they receive.
So you may blindly trust them to do exactly what you want them to do.
Just one comment though:
When feeding the RCA/TosLink converter with a TosLink input at 192kHz, the RCA output works perfectly, but the TosLink output's clock sometimes gets out of sync.
I'm sorry..
but experiments using the rme's digital inputs (except perhaps in extreme cases) are of no interest...
their powerful "steadyclock fs "input processing levels absolutely everything... so it is normal that you observe...nothing...
You need practically unprocessed inputs to be able to make interesting observations.
I have a lot of respect for your efforts...but there they were in vain
(This is a situation that sometimes comes across on ASR, typically also in observation in the digital domain...and which must be clearly explained to avoid misunderstandings, or irrelevant measurements-observations..I had even one day gently asked “gentleman rme” if it would be possible to disengage him for this type of observation..
but it was not well understood I think)
R
Rja4000
Liège, Belgium
I'm happy to say that the switch works with 8 channels ADAT @48kHz
R
Rja4000
Liège, Belgium
This is not a DAC. Just a digital converter. The DAC is the RME ADI-2/4 Pro SE or the Topping E30 II Lite, at the end of the chain.
Corrected. Thanks.
Blumlein 88
This is pretty terrific. Thanks.
R
Rja4000
Liège, Belgium
You may have a point here.
I'm checking... with what I have at hand.
morillon
it's even sure.... ;-)
if it's to observe the efficiency of the powerful steadyclock, and even more obvious if the observations in the digital domain... it's good... everynum source is good..miraculus ;-)
but if to observe the jitter etc behavior of digital sources etc.. it will work not so...
(]to observe the impact of these switches etc. it will be better to observe them in the digital domain...
these are observations that can be very biased by the receiver's input processing bias... the more "bad", the more interesting it will be...)
RandomEar
This is not a DAC. Just a digital converter. The DAC is the RME ADI-2/4 Pro SE, at the end of the chanin.
Corrected. Thanks.
Ahhh, now I see: It's Toslink to S/PDIF over coax. OK, in that case, I would expect it to perform like it did. Every outcome other than "bit perfect" would be bad.
I would recommend to not call the connector "RCA", though. While the coaxial S/PDIF connector is mechanically compatible (identical?) to a regular RCA plug, the term RCA is commonly used to refer to the analog variant. It's not technically wrong to call that coax plug "RCA", but it's gonna lead to misunderstandings - like in my case ;)
R
Rja4000
Liège, Belgium
As you may read with the additional measurements I added, there is an impact with a (very) cheap (but still very good) DAC.
Not very big or significant, but there is one.
morillon
the most effective way to observe digital is to do it in digital...
I'll try to clarify by example:
I have several digital acquisition cards and no need to use a DAC ouput etc
some from the professional world like the rme are heavily processed in input and offer, like the rme, practically constant results whatever the quality of the incoming signal...
but I also have a general public card that is very poorly processed in digital input..
it allows observations, comparisons jitter mesurment that are truly differentiated according to the quality of the sources..
conclusion for this type of observations of digital sources only the modest one is useful and allows us to sort things out and avoid major misunderstandings.... .
MRC01
Pacific Northwest
Thanks for the useful review. I use similar devices and never measured them as they are digital-only so I didn't expect them to make any difference. The jitter differences you measured will vary depending on how well the receiving device is designed.
I ran across this one too.
Or this one that has two outputs that work at the same time. Maybe good for feeding subs and main speakers or some such.
The first toslink/coax adapter that I tried a couple of years ago worked just well enough to realize that it didn't work. It would work fine for a few minutes then start to fail. So don't use this one:
Then I replaced it with this one, which works reliably up to 192-24:
They look the same but in functionality they are not!
The ViewHD device mentioned above is another I tried for a while. It caused some intermittent issues so I replaced it with this one, which works reliably:
morillon
I didn't test for that, so I can't comment.
I'll start using them in my system, so we'll
you clearly show that these observations are very determined by the processing at the input of the acquisition...
constant with rme..
more variable with the topping...just that my point...
(we are in complete agreement in rme directly via steadclock...on topping its ana output to ana rme?)
small example
stop for me...
