Quinton595
- Joined
- Apr 6, 2024
- Messages
- 51
- Likes
- 11
Hello everyone,
I will shortly be buying some HD800s. I love them for their clarity, detail, and open-ness. I am trying to figure out what DAC and Amp to use with them, though, as I currently don't own an Amp, and am borrowing a DAC (Grace SDAC).
I've tried to do my reading, but I keep coming across a lot of contradictory and outdated information.
I've always had my heart set on some Schiit products, but for no real, substantive reason. I just like the way they look, and know their catalogue well.
I AM open to other brands, but only if they look as good, and as clean as the Schiit products. My stack will end up sitting directly in front of me, a foot away, under my monitor, so I'll be looking at it 24/7.
Anyway, I was originally considering the Lyr+ and the Modius Dac. Roughly $879, and it gets me a Tube amp, a Solid State Amp, and a discrete, balanced DAC.
However, after reading, it seems a lot of people don't hear much difference between the tube and solid states, because the tube stage is very clear, and not "tubey". And the solid state itself doesn't seem to be very good, as far as raw measurements go. Also, when in solid state, the tube is still powered, so you're still burning through its lifespan.
So then I started to consider the Jotunheim 2 with its integrated DAC card. Much cheaper, at $599, and it gets me a balanced Amp, and A Multibit DAC.... but then I started reading, and everyone hates the Multibit DAC. Okay, so I can buy the solid state DAC card instead.... except that one apparently tests horribly too. Amir's reviews, for example, really shake my confidence in it.
The thing is, I can't find any reviews or testing on the NEW ES9028 DAC card. So I don't know if these issues have been addressed.
Okay, so how about a Jotunheim 2 and a Modius DAC?
Well, then there's also the Valhalla 2 OTL tube amp. Okay, that one tests abysmally, per Amir, but seems to be beloved by actual users?
Then there's the smaller cousins of everything, the Modi and Magni
Then there's other brands like the JDS Labs Atom stack...
Oh, and I'd one day like to be able to add a speaker amp to the stack, so I need something that disables speaker outputs when a headphone is plugged in...
Can you tell I'm overwhelmed?
It appears that I don't have particularly discerning ears. I don't seem capable of hearing a lot of the subtleties that others describe in the audio world. For example, the soundstage on the HD800s sounds, to MY ears, exactly the same as the soundstage on the HD6XX. This is apparently heresy, as the difference SHOULD be night-and-day.
So, a big part of me wonders if I'm going to even hear some of the complaints people have about given systems. They say the Jotunheim 2 is too bright with the HD800s, or that the Valhalla's technical performance is too low... but will I even be able to hear a difference? Should I just buy based on looks?
Thank you all for your time.
