For numerous reasons (including my blood pressure) I do not post here at ASR--and I generally ignore the misguided sideshow, but Amir's latest blunder is just too good to pass up:
https://www.computeraudiophile.com/...-a-dacs-output/?do=findComment&comment=704222
And:
https://www.computeraudiophile.com/...-a-dacs-output/?do=findComment&comment=704286
Alex Crespi
Uptone Audio LLC
OK, back from the trip and had a bit of time to answer this. I am going to provide two answers. One high level that is easy to understand and should completely do away with this argument. The second answer, will be a deep dive into power supplies, emissions control, safety, etc. that explains why the problem is created with ISO regen and not otherwise.
First, here is the argument from the first link above:
In a nutshell, he is saying that because ISO regen uses a switchmode power supply and so does the Audio Precision (how he knows the latter is beyond me seeing how he doesn't have one), and that switchmode power supplies have a "required Y capacitor" that what I am observing with respect to increased mains frequency and harmonics in the output of the DAC as measured by my Audio Precision Analyzer, is unavoidable. He is also pointing to an iFi post which was measurements of their power supply (and not the DAC) as proof point of this.
Here is the diagram for how I measured the Behringer UMC204HD as is:
Right away we see the flaw with the statement Alex is making. There are plenty of switchmode power supplies in my playback and measurement chain. The Behringer was powered by the USB power of my desktop workstation. This is a custom PC I built with a switchmode power supply. I don't pretend to know what power supply configuration is used in the Audio Precision Analyzer. I do have a laptop connected to it that controls the analyzer over another USB bus and the laptop was connected through yet another switchmode power supply to mains.
So if switchmode power supplies have "required Y capacitors" and anything upstream of the analyzer would create mains harmonic noise, it should have been there all along. But it was not at nearly a significant level until I changed to this configuration:
In this configuration, yet another power supply made by a half-decent Chinese/Taiwanese company called Meanwell is added in the middle of the chain. This is powering the ISO Regen which in turn generates a new USB bus power. In this configuration we managed to increase the mains related harmonics as I showed before:
By now it should be obvious that the
mere fact there are switchmode power supplies upstream of the DAC/USB bus does not at all say that the measurement scheme is faulty. The only change here was insertion of the ISO regen and it created the heightened noise products in the output of the DAC. Clearly what Alex is saying regarding design and operation of switchmode power supplies is incorrect (I will dig into this in the later detailed post).
But let's say for the moment that he is right. Nothing about that means that we can't measure the output of the system with the Audio Precision Analyzer.
The AP acts just like any other audio device. It has an analog pre-amp, power supply for the same, and other bits to capture that stream. There is no law against such an audio having a switchmode power supply. Class-d amps for example mostly have switchmode supply. Is Alex saying that in such configuration ISO Regen does screw up the fidelity of the system? If so, why is that not indicated in the specification for the device?
Last but not least, I suspect the last thing anyone would think of when reading about a device that says it provides isolation, that it actually creates current leakage of its own!
Summary
There is nothing wrong with the testing as performed. Had UpTone bothered to measure the performance of their system with DACs, they would have likely found this issue and hopefully would have re-looked at their system architecture and chose a different design. AC mains current leakage, ground loops, etc. are part and parcel of unbalanced, RCA connections. Fact that adding yet another power supply to what is already a complex configuration causes more mains related distortions should not be surprising. Simplicity sometimes is our friend and ISO regen moves away from that.
