Vintage Audio: Measurements of Arcam Black Box 3 mk1
LTig
Europe
As requested by @andreasmaaan here I made some measurements of an old DAC: the Arcam Black Box 3 MK1 which I bought new in 1991 (without MK1, see below). It retailed for around € 780 then (converted). Here are the front and the back:
It supports 44.1 and 48 kHz samplerate with 16 bits - that was the standard back then ...
Somewhere later around 1997 I fell victim to op-amp rolling and replaced the original op-amps (LM627CN) by OPA134PA. Two can be seen on this photo of the internals on the right PCB (audio mother board).The LF411 is used as DC servo. Two others are hidden on the backside of the left PCB (digital audio board). The result is my version MK1:
The measurements are done with REW, using an RME ADI-2 PRO fs, an old Edirol UA-25 and a brand new SIGLENT SDS 1202X-E (2 channel 200 MHz digital scope).
Lets have a look to the output level (measured with the digital scope):
The left channel (yellow) delivers 2.50 Vrms, the right channel 2.35 Vrms, a difference of 0.5 dB.
For the THD, IMD and Jitter measurements I used the RME only, feeding the Toslink input of the BB3 with 44/16 sinus signals.
32 times averaging reveals remains of the power supply:
This is not 16 bit performance.
The actual IMD is not that bad, but there is a lot of spurious stuff. With 32 times averaging we can see that it is not noise:
EDIT: while repeating the measurements with the fixed power supply and back in original state I realized that I did not enable dither during the IMD measurements. With dither enabled the result is much better: the spikes are still there but reduced in amplitude by about 10 dB.
Jitter suppression looks really awful (using J-Test signal):
And this stuff covers the full spectrum:
At last I measured the frequency response. Here I used the Edirol to feed the BB3 with 44/16 signals and used the RME with 384/24 to cover a wide band spectrum. REW did not allow me to display the full spectrum (the RME meausres until 180 kHz) so I can show only up to 100 kHz. First white noise with heavy averaging:
Oh oh - this does not like like a good reconstruction filter. I would expect a lot of aliasing here, so let's check with a 19.1 kHz sinus (same as JA uses in his tests for stereophile), 64 averages:
The aliased image of the 19.1kHz tone at 0 dBFS is suppressed by 72 dB. This is much more than the white noise result suggests (beats my why) but it should be at less than -90 dB.
Conclusion
We should be glad that we live in modern times where 100 € buy you a DAC which measures much better than this vintage gear. I would not say that the BB3 was high-end (that would have been Proceed or Wadia which were at least twice as expensive), but it was not cheap either.
Please remember that this unit is not in the state as it left production (it's MK1!). Without reinserting the original op-amps and a retest we cannot be sure that the THD and IMD measurements reflect the original performance. The jitter and aliasing problems however should not be affected - but we never know ...
EDIT: corrected the type of the original op-amps (from LM327 to LM627CN).
restorer-john
Nice post. Well done. :)
What load did you have when measuring the output level BTW? Sometimes, level differences can show up when the outputs are unloaded and even 10K can bring them back in line.
Interesting to see the old SAA-7321- the first Bitstream low cost dual channel chip being used one per channel in differential mode as Bob Stuart's Meridian 203 did also around the same time.
Blumlein 88
Yep very nice post. Good job on the testing.
About the white noise vs 19.1 khz imaging result, it is because of the nature of white noise. A full on white noise signal will display lower due to FFT gain. At 256k FFT over 176 khz bandwidth (of the RME) it is about 42 db lower in level than 0. So if you use it as your reference the imaging in the ultrasonic region is the difference shown plus about 42 db with noise. So you get something in the 70's I'd say with your graph. Closer to the 72 db you get using 19.1 khz. So it does all make sense.
restorer-john
Please post some impressions of the new DSO, it's a worthy challenger to the venerable Rigol DS1054Z in many ways and arguably better in some parameters.
sergeauckland
Suffolk UK
Very interesting and thanks for making and posting the measurements. What interests me about this is that whilst undoubtedly modern DACs, even quite cheap ones, measure much better, I've not seen any blind listening tests between a good ~30 year old DAC and something modern that would indicate that the old DAC is sonically inferior. Have there been any such tests published?
I still use a Meridian 206 CD player, a Technics SL-PG590 and a Squeezebox Touch, all with their own internal DACs, and have failed to hear any difference whatsoever when level matched.
S.
Duckeenie
Wow! I used to own one of these back in the days before family commitments curbed my spending. Nice to see my ASR recommended £60 DAC blows it out of the water. :)
Can't believe the 90's are viewed as vintage already though. I'll except no argument you made a mistake there. :D
sergeauckland
Suffolk UK
I struggle to see anything after 1980 as 'vintage'. Vintage has tubes in it, or at a push, geranium transistors (and zenobia diodes)!
S
restorer-john
Back in the the early 90s, we were calling 60s and 70s gear, vintage, so it makes sense that nearly 30 years later, 80s and 90s gear is now officially vintage too. :)
LTig
LTig
Europe
The 42 dB shift makes sense, but why would it apply to the pass band only and not also to the stop band?
LTig
LTig
Europe
I'd be replacing the bridge rectifier diodes for what appears to be the 5V digital supply. The board looks a bit toasty... Or did you spill your beer on them? ;)
No beer, Sir :)
Just before I closed the unit I also noted the toasty board. Maybe I should replace the diodes before I sell the unit.
LTig
LTig
Europe
Will do, but first I have to become familiar with it. This is my first digital scope (it replaces an old Tek 465, 2ch 100MHz) and there is only a quick setup manual. I guess I have to download the full manual and study it. One thing I can say already: the display feels like an analog scope with a long fade out time (when enabled). I once had a very old HP 130 from 1965, 2ch 500 kHz (yes, kiloHz), with a fade out time of 40 s!
I have very little experience with digital scopes yet. In the office we have a Tek 2465 (4ch 300 MHz) and an early digital scope (4ch 500 MHz), but in those few situations where I needed a scope I always used the 2465 because I know how to set it up and just concluded that it will be faster this way than starting to read the manual of the digital scope. My younger colleagues prefer the digital scope though, because if its default button :facepalm:
LTig
LTig
Europe
I see it as vintage digital audio gear. CD came in 1983, the first consumer DACs AFAIK a few years late. Seen from this perspective a DAC made in 1991 is really old (28 years), ergo vintage.
restorer-john
Same here. My analog scope (vintage Trio 60MHz) is still my go-to scope. I can operate it virtually blindfolded as I've owned it and a few others for many decades and they never let me down.
The DSO is still a learning curve several years on. They make you lazy too- all the math is done in the scope. That said, they are amazing tools.
captain paranoia
It's just practice...
I spent months in front of an HP8568B when developing RF synthesis technology for the early days of Vodafone. My fingers used to fly around the keys to take measurements, without thinking. 30-odd years on, I'd struggle to set the centre frequency...
LTig
LTig
Europe
Just the scope, that is 1 MOhm. Looking at the schematics I cannot see that a lower resistance would change the levels.
I just bought a metal box and some stuff (0.1% resistors) to build a multi purpose adapter which allows me to change the load or add attenuators. When it's done I can test with different loads.
