VMV D2R Stereo DAC Review
Rate this DAC:
    Votes: 14 6.3%
    Votes: 55 24.8%
    Votes: 122 55.0%
    Votes: 31 14.0%
Guilherme_BR
My setup:
- Sharp Roll-OFF
- Low OSR + HPC OFF
Information:
Today I put the PI2AES module back on the Raspberry Pi4. The I2S input of VMV D2R works with the I2S output of the PI2AES module. I could not use the I2S interface of the VMV D1SE with the Pi2AES module.
I'm using High OSR and HPC off. With i2s, I hear distortion and volume drop when HPC is ON. I checked and I am using the same i2s phase in the streamer (sd9). With usb I do not hear that, but Still prefer HPC off.
gizmo90
Las Vegas
I did a blind test with the help of my wife with Sanskrit MKII and the VMV I did not pass. My ears aren't as good as I thought or DACs basically all the sound the same. I'm starting to think a lot of this stuff is in your head. I sold/selling my expensive cables too. I feel free! Used the money to get my wife and daughter some gifts, put some money into savings and got the Sanskrit MKIII. :)
Yamaha A-S1100, Wharfedale Lintons for the test.
Save your money for the speakers you want.
Celentano
sometimes the bottleneck is in the chain after the DAC and that can be the reason that "DACs basically all the sound the same". Can you advise what is in your chain after the DAC , please? If the rest of the equipment is not super duper resolving than the DACs can sound the same way.
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
Congratulations for actually taking the time and making the effort. Most don't bother, and just keep chasing after silly stories.
The best advice you could give.
BDWoody
Chief Cat Herder
Moderator
It's more like, if you don't use even basic controls when you are doing your comparisons you are almost guaranteed to hear differences.
Why would you expect them to sound different?
renaudrenaud
Tianjin
My setup:
- Sharp Roll-OFF
- Low OSR + HPC OFF
Information:
Why don't you use the USB port? Best transmission protocol, asynchronous with XU316 (is it the one used in the DAC) and ultra low jitter guaranteed.
renaudrenaud
Tianjin
You cannot understand. It's an emotional personal way to receive the music. The most expansive gear give you this emotion. Not a 100$ DAC on inexpensive flat monitor speakers from Focal, Genelec or I don't know which brand. Is there any active monitor speakers with tube amplifier inside?
renaudrenaud
Tianjin
I don't understand clearly why subjectivists come here to give us lessons on equipment. Plenty of forums are here to describe the merits of, let's say, TotalDac for example.
renaudrenaud
Tianjin
An example of emotion you can get from best equipment. Buy the TotalDac first and then read the measurements:
Guilherme_BR
Going back and forth between SU10 and D2R, I believe the measurements reflect the perceived sound performance, with SU10 being clearer and more detailed.
Celentano
The real music material does not contain pure sine waves and not a product of two or three frequencies. How about importance of impulse and squire/saw shape of wave reconstruction? Sine wave reconstruction is sure also important but how about other types of waveform? Also it is important how our individual brain is interpreting the information from the electrical signals coming from hearing receptors in our ears...
BDWoody
Chief Cat Herder
Moderator
Which measurements exactly?
Do you understand how very small those measured differences are?
Try it with some basic controls.
Which has nothing to do with the claims being made.
What does it contain? Are you trying to say your music has square waves?
How well do you understand the measurements done and what the numbers mean?
gizmo90
Las Vegas
I was using the USB on a laptop for the tests.
I think the bottle neck in my case is the speakers. The Lintons are wonderful speakers, but I don't think they are the best thing around obviously.
I think the Sanskrit is a good match for me and my system. The D2R is great I just didn't really need it apparently. It did look pretty sweet in my hifi rack I will say that! :)
Beave
In the first sentence you state that the "real music does not contain pure sine waves...," as if to imply that testing using pure sine waves is insufficient.
In the very next sentence you ask about the importance of impulse response and square/saw shape? Well, let me tell you, if music doesn't contain pure sine waves, I can guarantee it also doesn't contain impulse functions or square waves or sawtooth waves.
So what exactly is the point you're trying to make? Your entire premise contradicts itself.
Rotel
I am still looking for the perfect setup and environment (to use a wall diffuser or not) for the D2R DAC.
The sound is cleaner with the Pi4+PI2AES modul I2S interface than the Pi4 USB interface. Sometimes it is too clean and detailed.
PI2AES measurements:
voodooless
Netherlands
The whole review is pointless for your usecase:
Unfortunately I can’t measure the I2S output as the APx555 does not support differential/LVDS I2S, but as shown in my DDC video, the performance is absolutely stellar, and it did show measurably lower jitter in a J-Test than the already great performance coax output did. If you have I2S, definitely use it.
The I2S is straight from the Pis' I2S pins, only LVDS is added. The jitter on that will be quite horrible compared to the other outputs that go through the SPDIF transmitter and are PLL smoothed. The conclusion reached above doesn't make sense and only shows how irrelevant jitter is on transport!
Celentano
Reading all this all makes me just smile... :) I do not want to comment .... I just keep smiling... I would imaging for how long you would listen for a pure sine wave say around 1 kHz... I would appreciate if Amir can comment on all this... He is very educated person and I would definitely honer and value his opinion and his take.
