When 12 Gauge Wire is Not 12 Gauge
Descartes
For loudspeaker cables almost any reasonable electrical or audio cable will do. You don't need the good bulk cable manufactures like Belden, Canare or Mogami. Those are for interconnect cables.
Agreed, except if one wants cables to last a life time then Mogami W3104 with 4 conductors 12AWG are outstanding or the W3103 with 2 conductors 12AWG
Speedskater
Cleveland, Ohio USA
Yep, with some hi-fi cables, you never know how long they will last.
But, connectors and installing connectors might be a bigger consideration.
nebunebu
This makes me wonder, how does a regular lamp wire measure?
Is there any benefit to have a solid core vs stranded wire?
somebodyelse
Depends what you mean by 'regular lamp wire' but probably good enough for short runs. I'm guessing it's parallel or slightly twisted pair, similar to most generic speaker cable, so resistance is the parameter to look at.
It shouldn't, at least within the range of 'normal' speaker cable sizes, environments and non-faulty insulation.
Sal1950
The Chicago Crusher
Central Fl
Just depends on how thick it is.
All else equal, the thicker, the lower the resistance, the better it will be.
Not really, solid core has the problem of being stiff and inflexible.
Otherwise they will be the same if the measured resistance is the same.
tyreman
Cambridge On. Canada
I have been using the Belden 12 gauge gray sheathed 5000UE (I think it is listed as) with bananas soldered on each end for a number of years.
Previously had the their Belden 14 gauge to did a bunch of a/bing with the 2 types never really heard a difference
Sal1950
The Chicago Crusher
Central Fl
Probably never will unless the distance is like 500ft :p
