‘Slow’ playback of 192/24 flac
Phorize
U.K
Hello. I have a chord qutest with a Cambridge audio np30 acting a a transport. They are connected by coax, rca out/ bnc in. I have bought 3 192/24 albums. Over Dlna (Debian server/cat 6) they play back very slowly, as a 45 record on 33 rpm might. There is also some distortion.
The same files playback properly over dlna to vlc on my iPhone.
Any thoughts about what is causing this phenomenon and how to respond? I am contemplating buying an Allo Digione anyway as np30 is deprecated and running a very out of date software stack.
Ron Texas
If there is another way to connect the two units try it.
Blumlein 88
From the page on your Cambridge, it only does 96 khz. It would be odd, but maybe it is playing 192 as 96 khz? That would be 50% normal speed.
You could downsample them to 96 khz, and see if they play normally which I'd expect they would.
https://www.cambridgeaudio.com/usa/en/products/archive/np30
Audio Formats:
WAV containing uncompressed PCM 16-24 bit 32-96kHz FLAC containing losslessly compressed PCM 16-24 bit 32-96kHz Apple Lossless (ALAC) 16-24 bit @ 12/16/22.05/24/32/44.1/48/96kHz AIFF containing uncompressed PCM 16-24 bit 32-96kHz Microsoft® Windows MediaTM Audio (WMA 9 Standard) 32-320kbps MP3 (CBR or VBR) 16-320kbps, AAC, HE AAC and AAC+ (CBR or VBR) 16-320kbps Ogg Vorbis 32-320kbps (88.2kHz sampling frequency not supported)
Phorize
Phorize
U.K
Phorize
Phorize
U.K
Thanks. It would be odd as I’m assuming that the output of the np30 bypasses the internal dac(which does indeed only handle up to 96/24) and passes the stream directly to the rca or optical output and in to the external dac. You might be right though. It might be a queue for me to finally upgrade my transport but I’ll see if I can figure out what is happening out of interest.
Blumlein 88
Well under digital outputs on that page I linked earlier is this:
DIGITAL OUTPUTS
S/PDIF Co-axial and TOSLink Optical 16-24 Bits, 22.05-96kHz
Now digital out does bypass the internal DAC, but it still must have the chips to support higher sample rates even for digital out, and apparently it stops at 96 khz.
Phorize
Phorize
U.K
Thank you-well spotted. I’m slightly embarrassed that I didn’t RTFM properly before posting. If I’d done that on the openbsd mailing list I might not have survived:)
Looks like I’ll be ordering a Digione today!
Blumlein 88
I don't think we'll dock any points from you here. :)
