- Joined
- Jan 20, 2019
- Messages
- 341
- Likes
- 499
Currently listening to the old 80s CD of Sting's Nothing Like the Sun. Fabulous recording and wonderful sounding CD. The CD has excellent dynamic range and even in the quietest parts, there's absolutely zero audible hiss.
The basic point is that 16-bits provides massive dynamic range. Unless you're hearing the quantization noise from your 16-bit digital source, there's zero reason to need higher bit depth. I guess it is possible to hear this quantization noise with headphones blasting and the right source material. With loudspeakers, I cannot see how you'd ever hear this quantization noise.
In addition, harmonic distortion can be almost completely eliminated with dithering, so really lower quantization noise level is really the only benefit of higher bit depth.
If you're not hearing quantization noise hiss, HIGHER BIT DEPTH DOES NOTHING!!!
I'll stick with my 16-bit/44.1KHz bliss.
