D
Deleted member 48726
Guest
That's not true. Patience is needed and different angles on the topic.You cannot reason someone out of a belief that they were not reasoned into.
but it's good value - it competes with cables in the £100K to £150K price bracket.Kind of cool looking.
But the price makes me angry.
But we’re not expecting different results, are we? Maybe in the context of people accepting them? I think this forum has proven that repeating the mantra works: Ever more people become sceptical. It works, just slowly. In any case, the joke is on the believers: they keep buying different cables, expecting them to sound differently.."Insanity is doing the same thing over and over again and expecting different results." Not from Einstein
No, it’s a box with a tiny radioactive cat in it. Don’t open it though, it will let the Quantum outwhat's in the plastic case in the middle?
shakti stones?
I could!Well...I just replaced a $4,500 pair of interconnects in my system with a pair of $40 interconnects from Amazon. (The expensive interconnects were loaned to me since I needed an pair when I got another preamp - no I wouldn't buy expensive cables).
Wanna guess if I heard any difference?
Come back and post when your system is resolving enough.Well...I just replaced a $4,500 pair of interconnects in my system with a pair of $40 interconnects from Amazon. (The expensive interconnects were loaned to me since I needed an pair when I got another preamp - no I wouldn't buy expensive cables).
REFERENCE Speaker Cable is an essential building block for a Connoisseur Level music or film system. It delivers extended and well-defined bass energy while creating a quiet interface between some of the most challenging speaker and amplifier combinations. Custom machined, highly polished gold-plated, tellurium copper spade lugs transfer power effortlessly through heavy, precision wound OFHC stranding.
REFERENCE Speaker Cable is handcrafted in the USA and is a significant performance upgrade compared to Ultra Speaker Cable because its networks components are more precisely matched to the cable’s inherent electrical properties and length. In addition, Reference level cables are the first products in the Transparent family to be custom calibrated for the specific electrical output characteristics of your components. REFERENCE Speaker Cable delivers deeper, tighter bass frequencies and transfers music with more refinement than ULTRA Speaker Cable
REFERENCE Speaker Cable is available in 2 versions: High Z for high output impedance and Low Z for low output impedance amplifiers, but the customization doesn’t stop there. Connector configurations and polarity to fit precisely and easily with your specific amplifier, speakers, and system layout. Contact Transparent or a Transparent dealer to determine which version is the best fit for your amplifier and to discuss the details of your system connection.
The elegant carbon fiber composite network carapace on each channel allows electromagnetic fields to expand fully and freely. The thin and stiff-walled CFC network carapaces accommodate a greater mass of epoxy resin to reduce resonance and vibrations to a much greater degree than ULTRA Speaker Cable. Isolation feet stabilize the custom-machined acrylic carapace platform to reduce resonances, and the acrylic platform fasteners bore deeply into the epoxy resin-loaded carapace to further reduce the effects of resonances and vibrations
REFERENCE Speaker is handcrafted in the USA and is upgradeable to XL, OPUS, or MAGNUM OPUS Speaker Cable.
Warranty registration not only extends the Transparent Warranty to a lifetime limited warranty for the original owner, it provides the owner with complimentary recalibration in the event that a component change requires network adjustments.
If only it came in red. Oh well.View attachment 340232
I like this cable
Well, at least that one is true But if I cloud, I would still not spend the money on them."You are jealous that you can't afford these expensive cables."
Those 3 arguments are the most used amongst the loudest pseudoscientists. Whenever you hear anyone of those arguments, it's a tell tale sign that there is no point of having the discussion, it's time to just move on.Well, at least that one is true But if I cloud, I would still not spend the money on them.
Regardless, as far as arguments go, the only true one is also the weakest. The size of a bank account has no capacity to change the nature of reality in any meaningful way
