A Cardioid mid Coax 3 way speaker
I built a 3 way speaker using a Sica 5.5C1.5CP coaxial driver in a passive cardioid configuration helped in the lows by a Wavecor SW 215 subwoofer in sealed box configuration. This will use a DSP crossover although there is potential for a passive crossover version as well. Here are some pics and other details
Initial prototype for testing cardioid mid. The space behind the Sica coax driver is filled with 50mm thick melamine foam sheets cut to shape
Final CAD design:
Build progress
Driver assembly (The space behind the coax is filled with melamine foam sheets and covered with a sock cloth for now)
Measurements
A linear phase crossover: V1 (Reference axis is 20 degrees off axis)
Vineeth Kumar V
This speaker is now alive and singing.. :D
I tested this crossover first
Here is the reference axis (20 degrees off-axis) measurement I made of the speaker from 50 inches away.
It is almost exactly as per the predicted response in VituixCAD.
The blue line is what I took as the reference based on Vituixcad
Burst decay
1698833925613-png.1229754
So far I like it a lot.. But honeymoon days.. :D I Need to listen a lot more..
The vocals sounding special is one of the first feelings I got, while listening.
I am missing a bit of bass that I am used to with my big speakers but maybe more tuning & placement tweaks are needed.. :)
More updates in the coming days as I listen more.
If anyone is wondering how the speaker looks like (sounds like ;) ) while it is singing, and also wants to get some vague idea about the cardioid directivity, see the below video. Of course, these kind of recordings are pointless and the sound balance will just depend on what you play this video on & recording artefacts, but still... :)
nerdemoji
wow.... im lost for words
voodooless
Netherlands
Very unusual design, but it seems to suit the project well and the end result clearly speaks for itself! Very well done!
@amirm, promote to front page?
voodooless
Netherlands
melamine foam
Also known as Miracle Sponge, available as a cleaning sponge. May not have very defined properties, but will probably work just as good and costs almost nothing.
I didn’t know this stuff was useful as sound absorption material. Great stuff!
voodooless
Netherlands
One small point of critique might be that I wonder how long it will take before you'll start seeing the MDF seems? Generally, if not plastered over liberally, they will become visible through the paint after a while.
I made a similar-shaped enclosure (without the extrusions), many, many years ago, and opted to plaster it with fiberglass to get it super smooth, and then spray painted it with metallic paint. All without using CNC ;) Never again... :facepalm:
BTW, what amps and DSP are you using for this?
Vineeth Kumar V
A friend of mine built these cabinets & painted them as per my design. He is a professional in this. I have similar layered MDF cabinets made by him for my main system about 1.5 years back and painted in black. To this day, it looks like the way it was when it arrived here. Here is a pic of it today (the top module in below pic)
So I hope these cabinets will remain as such too for some time to come :)
At the moment, I am using a Marantz PM 5005 for the woofer.
For the Sica coax mid, I am using this: https://www.audiosciencereview.com/forum/index.php?threads/allo-volt-d-amplifier-review.15539/
For the Sica Coax tweeter, I use this: https://www.allo.com/sparky/volt-amp.html
This system, at the moment, is designed for use with my PC. So, for implementing DSP, I am using Equalizer apo on my PC along with a 6-channel audio interface:
This gives me great flexibility to implement even full bandwidth FIR filtering for each driver :)
Vineeth Kumar V
Here is how this project evolved :)
All Thanks to mabat's ATH software
Prototype-1
1683044060436-jpeg.1170481
Polars
1683045824668-png.1170488
BEM sim-1
1683083565604-png.1170649
predicted polars'
1683083630955-png.1170650
Real world: measured polars
1683083672941-png.1170654
BEM sim-2 (with damping)
1683083798055-png.1170655
Predicted polars
1683083860705-png.1170657
Prototype-2
1683122669736-png.1170757
Measured polars
1683122460632-png.1170755
Prototype-3
1683133795544-png.1170828
Measured polars
1683133842026-png.1170829
This is where we decided that this concept is worth pursuing :)
Next came CAD design iterations
Design-1
1683467500380-png.1171890
Design-2
1683644328016-png.1172574
Design-3
1683646240892-png.1172580
Design-4
1683651675776-png.1172598
Design-5
cardiod_speaker_side-png.1172856
Design-6
full_speaker-png.1173651
Design-7
red_black_front-png.1173731
Design-8
cardioid_poor_mans_full-png.1174911
Design-9
img-20230520-wa0014-jpg.1175810
With this I fell in love and decided to build :D
Sokel
Prototype-1
Polars
BEM sim-1
predicted polars'
Predicted polars
Prototype-2
Measured polars
Prototype-3
Measured polars
Design-1
Design-2
Design-3
Design-4
Design-5
Design-6
Design-7
Design-8
Design-9
A little TAD-ish,I love it!
Great built!
voodooless
Netherlands
I'd be interested in distortion measurements as well. Let's see how well the little coaxial can hold up in this cardioid setup?
Vineeth Kumar V
I will take it. But at the moment, I don't have an SPL calibration for my mic. I use a sonarworks sound ID reference XLR mic for measurements.
With relative SPL measurements based crossover design etc, I is ok. But for distortion I need to do SPL calibration. I am waiting to get something to do this first. The comes the distortion measurements :)
MCH
Foam speakers! Cool, I never thought it was possible.
I wonder if it would be feasible to 3D-print a mould coat it with something with the right chemical resistance and low adhesion and generate the foam inside. Not easy but would allow to make several identical speakers easily.
Question: I guess the drivers are heavy, how do you achieve a good structural stability, is there a "skeleton" inside? I can't see well in the pictures.
Vineeth Kumar V
The final speakers are made of 25mm thick MDF. Only the prototypes were made of XPS foam :)
Reactions: MCH
