A good super flexible speaker cable terminated with banana terminal ?
Jaxjax
I usualy just run ProCo & some Mogami for all my cables in main system as I run pro gear there. ProCo doesn't seems to have speaker cables that are separate banana jacks on speaker side, only 3/4 spaced solid unit which the Audio Physic spark III speakers Im using in bedroom are not, there like 1"1/4 or something. Im using a 2075 pro yamaha amp that is 3/4 spaced though. I just want very flexable pre terminated that are fair priced as I'm NOT a over price snake oil buyer of any cable. I figured I'd get a decent answer at ASR. I need 10' each side max. I'd rather not use clear coated lamp cord even though I know it works just dandy. Something round & flexable like rubber coated wire ,
Kal Rubinson
Industry Insider
NYC
I suggest you look at what is offered by BlueJeans Cables and either order from them or find a cheaper vendor for comparable cables.
Midwest Blade
Mogami 3103 from Performance Audio at $2.86 per foot, is a great buy for a flexible and capable audio cable. These are unterminated, I used Blue Jeans locking bananas to finish the ends. Blue Jeans “10 White” is another good choice which you can get terminated with a couple of different options. I have pairs of both, you can’t go wrong with either. You do not need to spend more as we all know.
phoenixdogfan
Nashville
I like Canare 4s11 available terminated in your choice of connections. Available at B&G Photo Video for around $60 per eight foot length each.
iLoveCats
USA
The Canare 4s11 with sonic welded locking banana plugs from Blue Jeans Cable is a great product. It lays really well and the connections are secure.
