A Raspberry Pi as a music server
milus
The Pi Zero 2W is a winner and the 2W+ (if and when they release a version with 1 MB of RAM) will be a home run.
Unfortunately that is not possible :rolleyes::
new-raspberry-pi-zero-2-w-2/
"Frequently-asked questions
Will there be a version of Zero 2 W with 1GB of SDRAM?
No. 1GB LPDDR2 monodie are not available, and producing a SiP with two stacked SDRAM dice would be very challenging."
TheWalkman
Thanks for raining on my parade, Milus!
Seriously, after using the 2W for over a month on several different projects, it’s a winner with 512M. A great offering, indeed!
mdsimon2
Detroit, MI
I snagged a Zero 2 W yesterday when I was placing an order at Adafruit for something else, I'll give it a try with CamillaDSP and a few USB DACs.
Also for those looking for RPi4s although availability is sparse I still see them popping up at a few of the usual places. Pishop.us has 4 GB and 8 GB models in stock currently.
Michael
I did some very brief testing with the Pi 2 Zero W and CamillaDSP on Ubuntu Server 21.10 32 bit. Seems to work fine with my MOTU M4 although CPU usage is a bit high at 55% for a simple configuration of 2 channels in / 4 channels out with balanced async resampling and volume control but no other processing. Also tried a MOTU Ultralite Mk5 but got some weird digital artifacts (I experience the same on a RPi 3B+), CPU usage here was also very high due to additional channels at ~85%.
So short story seems OK for 2-4 channel DACs, but more than that may be pushing it.
Michael
shoto
Can anyone advice or know good guides on basics of using Rpi4 as a DAC source?
Specifically using Rpi as a 'Network DAC', Windows PC or laptop is used as normal but the audio output is somehow send to the Rpi over network and to play automatically? Or how about same thing but over bluetooth?
If this is not possible, too difficult or has too much latency to work well (for videos etc.) then what about the Rpi with local storage and playback but controlled over the network or bluetooth, either with PC or mobile?
want to learn about what options there are.
Volumio allow something close to the first option. PC controls Volumio Rpi over network, Rpi access PC storage over network.
wont be as seamless as a 'network DAC' but still ok for music if no other option
getting closer again to the solution: https://volumio.github.io/docs/User_Manual/Stream_audio_to_volumio
TheWalkman
Shoto,
If I understand your question, this is really easy.
If you want to use a Pi as a streamer you can use Volumio to stream from a NAS or what I do is load my music files (~250 - 300 CDs) onto a microSD card and store them onboard the Pi along with the OS and Volumio image.
In the configuration shown, I’m using wireless networking.
You don’t need a Pi 4. I’m using a PiZero W2 which has more than enough power. A Pi 4 is a major overkill for this application. (I just checked my Pi and the average CPU loading is 14% with a system temp of 42’ C. It’s not even breaking into a sweat doing this!)
I use Samsung High Endurance SD cards so no worries about longevity. A 64gb card costs around $14 and I still have 30 gb of free space.
I can also stream radio stations from Volumio as well as stream audio from my phone or tablet via Airplay.
My setup today is a Pi Zero W2 => Topping E50 DAC (via microUSB to USB B cable) => Topping PA 5 amp => Elac Reference DBR62 speakers.
(That’s the Pi Zero W2 on top in the Flirc case.)
I typically control this from an iPad or iPhone. (I can do the same from my laptop but never do.) The Topping DAC has a remote as well to control volume and source.
Works great.
shoto
Shoto,
Works great.
I set up volumio today. The idea of Rpi was daunting, thinking command line, tedious setup, troubleshooting etc. but volumio could not have been easier or quicker to set up, does exacty what I need, everything explained clearly in manual... and all free!
TheWalkman
shosto,
Glad to hear the install went smoothly.
I don't think you're alone: my sense is a lot of folks are intimidated and write the Raspberry Pi off before even attempting it. There are many great tutorials (beginning at the Volumio website) that do a great job of walking you through the steps and it really isn't very difficult at all.
It's also mind-boggling what you can with the Pi besides streaming. For $50 and a second hand monitor, keyboard and mouse, you have a fully functioning, well documented computer system that I could have only dreamed of when I was a kid. (That was in the days when in Altair or Imsai seemed like something off of StarTrek!)
I can't tell you how many hours of pleasure I've gotten from streaming via my Pi. I find it much more convenient than streaming from my phone or tablet, particularly for extended listening.
Enjoy!
KaLam1ty
If you have the time, a happen a few spare microSD's, I'd highly suggest also trying some of the other recommended solutions just to get a comparison. Easy enough to have a separate images you can pop in-and-out and test.
Volumio, MoOde, piCorePlayer, ... ton of options for good reason: They all have their merits!
My personal choice goes to piCorePlayer.
It's basically an image that packages two programs: Squeezelite (a music player) and Logitech Music Server together. It's a bit more finnicky to set up, but I found the Web-UI to be infinitely more responsive on low power/mobile devices vs. the latter two when handling a large library. It does very well with caching data and large album artwork. Ton of fun plugins as well and it's very mature and robust.
If the stock UI is off putting (..which it is...), I highly recommend using the lms-Material skin plugin, as the default is very dated. It feels very intuitive to use, very much like a typical Android music player app with right-click support for PC and hold-drag options on mobile.
Bonus props if you know basic HTML/CSS3, as it's easier to futz with the interface a bit, vs the aforementioned. (Note: The font normally isn't 'monospace', "Consolas". I just changed it to be that way. I believe the default is "Roboto"). To give any idea though...
infurnus99
I am currently using my pc as my music player using f2k. I use monkeymote to remotely control my library from my living room using my phone. I am planning to switch into a dedicated music streamer using a pi4. My setup is e30 > l30 > ath50x > amp > speaker. All the files are downloaded and in dsf format. Was wondering if I can build a server for it (as I have spare pc sitting in my garage) and control the playback using my phone.
Question:
- What os should I run on my pi?
- How many gb of ram should i opt my rpi?
- How should I setup the server?
MCH
I personally plug a hard disk drive to my router and it works as a NAS from which i can stream to any pi streamer in the house (i use bubbleupnp in my phone as a remote control and Moodeaudio in the pi) but i don't know if any router can do that.
Alternatively also on the cheap you can build a LMS with another pi (see post above yours) or even simpler, i guess you can just plug your HDD to your pi and play directly from it without a separate server (i don't do it but i am sure others can advice).
Hope it helps.
Ralph_Cramden
Well, not exactly. They charge a monthly fee if you want to use their Qobuz plugin, and several other features. If you are looking for an excellent product for Pi that’s totally free, look at PiCorePlayer/LMS.
drerd
Hello guys,
Is there any chance I could run Home Assistant + a hifi music player on same RPI ?
I have a RPI4 that runs Volumio , but I want to make a unit that has multiple dockers : Home Assistant , Volumio( or any other hifi player) , VPN , portainer .
0bs3rv3r
moOde on a Pi supports UPnP/DLNA.
Raitsa
Finland
Moode (Debian based) and Raudio-1 (Arch based) are excellent free choices as well, both updated and improved all the time.
Ears of Tin
Big thumbs up for rAudio. It has everything I need - streaming from NAS or attached HDD, Bluetooth send and receive, internet radio, Radio Paradise, equalizer, CD player support, tag editing, song lyrics, artist bios, OTA updates, DLNA, samba sharing. These are standard features on many players but rAudio is the most ergonomic UI I've found.
I recently switched secondary system from Volumio to piCorePlayer/LMS which is also great. My fat fingers didn't work well with Moode, too many volume control accidents. For full disclosure I don't subscribe to any premium streaming services like Tidal or Qobuz.
Matty1
Hi. Newbie here and to RPi music server. I purchased a RiP 4 and a new digi2 pro. Nothing works. Speaking with Daniel, and looking at hifiOS it recognises the digi But no sound. Connecting via toslink no red light ever comes on. He can’t pin it down but he thinks it’s hardware, either the Digi or Pi. Most likely the pi. Any thoughts or experience with this?
thanks
Ears of Tin
thanks
You can test just the RPi by removing the digi2 and testing for sound from the headphone jack.
MCH
are you using the official power supply for the pi? if not, what are you using?
i had problems with a different pi+dac hat and turned out it was underpowered
