I decided to make this guide for 200mm fans. I haven't seen other guides based on 200mm fans.
Current Pricing (USD) | Thickness | RPM Range | Claimed Lifespan (Hours) | Claimed Airflow | RGB | RGB/LED Area | PWM | Bearing | Rated Current | *Notes | |
Thermaltake 200mm Pure 20 Series | $14 | 30mm | 800 Max RPM | 30,000 | 130 CFM (Rounded) | No | No | Sleeve | 0.2 A | ||
Phanteks PH-F200 | $15 | 30mm | "850 ± 250 rpm" | >100,000 MTBF | 110.1 CFM | No | No | Unknown | 0.25 A | ||
Uphere P200RGB | $18 | 25mm | "500-800±10%" | 30,000 to 35,000 | 78-129 CFM | Yes (5V ARGB) | Ring: Unknown | Yes | Hydraulic | 0.3 A | Doesn't need to be PWM because 0% to 30% range is basically no change |
AereCool Silent Master | $19 (Blue LED) $20 (Red LED) | 20mm | "800±200 RPM" | Unknown | 76 CFM | No | Middle: Unknown | No | Sleeve | 0.42 A | |
BitFenix Spectre 200mm | $20 | 20mm | "700±10%" | Unknown | "47.4±10%" CFM | No | No | Unknown | "0.16±10%" | ||
Cooler-Master Master Fan MF200R RGB | ~$27 | 25mm | "800 RPM ± 150" | 175,000 MTTF, 25,000 L-10 Life | "90 CFM ± 10%" | Yes (12V RGB) | Middle: Unknown | No | Unknown | 0.3 A | |
Cooler Master MasterFan MF200R ARGB | ~$31 | 25mm | "800 RPM ± 150" | 160,000 MTTF | "90.3 CFM ± 10%" | Yes (5V ARGB) | Middle: Unknown | No | Unknown | 0.3 A | |
Cooler Master SickleFlow 200 ARGB | $30 | 25mm | "0-800 RPM (PWM) ± 10%" | >160,000 Hours MTTF | 102.8 CFM | Yes (5V ARGB Gen 2) | Middle: Unknown | Yes | Sleeve | 0.2 A | |
Noctua NF-A20 | $33 (Brown) $38 (Black) | 30mm | 350-800 RPM | >150,000 MTTF | 86.4621 CFM (Rounded) | No | Yes | SSO2 | 0.08 A | ||
corpuwn 200mm | $37 | 25mm | "500-1500 RPM ±10%" | Unknown | 112.88 CFM | Yes (5V ARGB) | Middle or Ring: 24 LED | Yes | Unknown | 0.35 A | |
Thermaltake Pure 20 ARGB Sync Case Fan TT Premium Edition | $41 | 30mm | "500 ~ 1000 R.P.M" | 40,000 | 129.54 CFM | Yes (5V ARGB) | Middle: 9 LED | Yes | Hydraulic | "Fan 0.26 A , LED 0.32 A" | |
Thermaltake Riing Trio 20 RGB Case Fan TT Premium Edition | ~ $80 to $110 (Deadass) | 30mm | "500 ~ 1000 R.P.M" | 40,000 | 123.53 CFM | Yes (5V ARGB) | Middle: 24 LED Ring: 12 LED | Unknown | Hydraulic | "12V : 0.27 A , 5V : 1.9 A" |
