A slightly different CS43131-based device: the recent HiBy W3-II. It is a USB+Bluetooth battery-powered dongle, similar in concept to the Qudelix 5K--see here on the left, next to the Q5K:
Compared to the Q5K, the W3-II is slightly longer, narrower, and thinner. It has rounded sides and also includes a clip like the Q5K.
The W3-II is an update from the previous W3 which was build around an AKM 4377. There is a single CS43131 as DAC/amp, and a Qualcomm QCC5125 for USB & BT.
Through USB, you get up to 16bits/48kHz and for BT streaming, you get an adequate list of audio codecs: SBC, AAC, aptX, aptX HD, LDAC, and UAT (the HiBy proprietary "near-lossless" codec). The output is the usual 3.5mm with Mic and remote support. There is also an integrated Mic if needed.
The HiBY Blue app, available for both Android and iOS, offers the usual configurable parameters and includes a 5-bands GEQ:
The W3-II is on sale at the HiBy store for $49 (+shipping). For that price, you get a Qudelix 5K "Lite", built around the CS43131.
It should be fine for most IEMs and easy-to-drive headphones. I assume, like the Q5K, SINAD should be "acceptable" but not great, hampered by the QCC5125--not the greatest chip as USB bridge.
On the other hand, these QCC51xx chips have a quite powerful DSP, and a diyAudio member shared an interesting tool, called "HYT TOOLS":
https://www.diyaudio.com/community/...c3034-qcc3031-programming.374322/post-7523235
It's an Android APK, and it does work with the W3-II connected through BT (I have not checked whether it works or not with the Q5K...). You can rename the device, control the volume & mute, and it also gives you full access to the EQ section of the W3-II.
I did not try to rename the W3-II, being afraid I would permanently loose access through HiBy Blue.
The QCC5125 EQ settings are only exposed when something is playing (same as with HiBy Blue GEQ), but what you get access to is quite impressive:
On the W3-II, "BANK 1" is configurable (it's the only one, the other Banks appear to be the Hiby presets), with 5x full-featured PEQ filters: LPF1 (low-pass type 1, F adj.), LPF2 (low-pass type 2, F&Q adj.), APF1 (all-pass type 1, F adj.), APF2 (all-pass type 2, F&Q adj.), HPF1 (high-pass type 1, F adj.), HPF2 (high-pass type 2, F&Q adj.), LS1 (low-shelf type 1, F&G adj.), LS2 (low-shelf type 2, F&Q&G adj.), TILT1 (tilt type 1, F&G adj.), TILT2 (tilt type 2, F&Q&G adj.), HS1 (high-shelf type 1, F&G adj.), HS2 (high-shelf type 2, F&Q&G adj.), PEQ (peak, F&Q&G adj.), and BYPASS (no filter).
The only problem… There is apparently no way to save the changes you made--they get reset after a power cycle !!!
But still, with this APK tool companion, the W3-II becomes a "geeky", "lite" version of the Qudelix 5K... and it's CS43131-based, so I'm not completely off-topic !!!
