unpluggged
- Joined
- Jan 5, 2023
- Messages
- 469
- Likes
- 697
ADAM T series are DSP-basedthe analogique T8V
Which question exactly? All I can see in your posts is trolling and ranting, starting with the slander in this thread's title. Other members made great efforts to help you and explain why your concerns are not very well substantiated, but you seem to insist on your prejudiced attitude and misconceptions, as if trying to expose some conspiracy.the question remains the same
What I think is that most likely you don't have them on the exact same spot, so bass boost from room gain is different and resulting in different extension, or that the HS8 have a more V shaped curve so when you set volume based on the vocal range in the mids you apparently have more bass in the HS8 which was the result of poorer neutrality.Thanks for the links and the curves ! I've download rew, I can't find where are the curve data on WebPlot... i feel dumb on this
I previously post the A7X curve because I didn't knew where to find the data for the A7V. THat's the reason why I was wrong and thought there was a low-cut comparing to the HS8. But I'm impressed by the curve you posted, the A7V have nothing to do with the A7X, realy close to the HS8. So I realy have to try to calibrate them as soon as possible. Can I try with a good microphone? Even if it's not the perfect sound id reference microphone, in the meantime.
I didn't delete my post , I must have been editing, adding this :
That's why I wonder if I shouldn't buy analog speakers, so as not to suffer from tech-fashion of the moment who will evolve ( making the material loose is value ). Doesn't it make sense to use a DST directly on the computer? Like on this video where he set the analogique T8V
At least for me you seems like you don't understand the technical part in the first place, everyone goes through this at some point, especially auido is known to be full of snake oil, plus from the language you are reading in the Adam page I guess English isn't your native language so perfectly understand the wording weirdness.I appear like trolling a lil bit, maybe to generate a debate. Sorry for the form. Thank you for the time you pass answering. Maybe i'm afraid about taking wrong decision by following the youtube and magasine recommandations, that are ruled by an important marketing influence. I have no landmarks. So i'm here to confront the rude question i'm asking to my self, testing arguments without detour. Sorry if i'm to much familiar.
The question was, don't you think that integrated dsp could cause come lost of quality, higher price, and possible devaluation of the product? Your answer is no. Maybe someone can bring an opposing argument. I also want to know if I can use sound Id DSP directly on my computer with the same advantages?
I have a reponse from amdam audio, about the relevance of using "a4v+ sub8" instead of "a7v". I post it here maybe it could help someone, or confirm the thinking of others :
« Did you try to solve the lack of low end by adjusting the frequency response of the monitors with our A-Control software or by trying the UNR voicing? The DSP is a pretty powerful tool to customize the sound of your monitors.
Switching to the A4V's with a Sub8 will give you a more powerful low end while the high end resolution remains the same. However, the A4V's are voiced a bit different then the A7V's to compensate their small size. This results in a less defined mid range, you will hear more details in this frequency area with the A7V.
As long as high listening levels are not too important for you, the Sub8 would also work as an extension with the A7V's.
Well, getting a UMIK 1 isn’t expensive and a lot of guys here including me feels like it’s best investment ever.Ok thank you for the answer (Indeed I use google translation a lot...) For the integrated DSP I needed to be reassured and that's done. Another advantage I see in it is not having to pay for the sonar license once the setting has been saved...
SO. I just tried what everyone recommended me from the beginning: test a sonar calibration. The result is stunning. Yet I used a Neuman KMS 104 microphone, so the curve is distorted. But the potential is there. It's night and day when it comes to bass depth. I think I can maybe do without a sub...
I can consider keeping this system by buying the dedicated calibration microphone. The last thing that's going to cross me is if " should I get better with calibrated KH120 A" ...while I can exchange...
I also regret not having tried sound ID on my HS8 to have a real comparison
I want to Commend you for remaining cool, calm and respectful throughout this entire process. You did not respond to the aggression and kept on giving great technical advice to a new member who was coming across aggressive and hostile. How you handled this and eventually disarmed him was a great read and lesson. This is how it should be done more often. Thank you for your efforts and contributions.Thanks for taking the time to read and post. I'll try to answer in detail.
Yes, people compare speakers all the time at home. Without some knowledge of your hearing, what happens to measurements, how speakers work, the reports mean very little.
In the kind of speakers you are comparing, popular studio monitors, the abilities are generally similar. There won't be big, obvious differences. Particularly not in the bass range for speakers that are close in size.
Here is where the problem in your thinking is: speakers do not play by themselves. Speakers in a room is one system, one object.
In your first post, you said you bought A7V. A7X is a different, older speaker. Here are comprehensive measurements of it: https://www.fidelity-online.de/kompakte-studiomonitore-von-nubert-adam-und-sls/
Here are anechoic (no room influence) plots. This is just the speakers themselves, the frequency responses at 0 degrees, if you faced them directly. I extracted the data using this web app: https://automeris.io/WebPlotDigitizer/tutorial.html and then loaded it into REW.
The plot you posted appears to show in-room measurements and has significant smoothing.
Smoothing reduces the resolution (ability to see detail) of a measurement. See below.
You can match the low end but not exactly. With skill you can get it within a few dB by using EQ.
DSP is hard to implement and expensive. Using it takes skill, and a measurement microphone. If by "low cut" you mean adjust the very lowest frequencies a speaker can produce, there are still physical limits for the speakers. Below 100Hz is subwoofer territory. 8" is far too small.
I think the KH120 II + KH750 + MA1 is an excellent combination and very easy to use. KH80 is a little small.
This is a little complicated, but... small rooms do make things more complicated, and square rooms do have problems... however, in reality the speaker is in control from several hundred Hz up and dominates the response. And then all walls flex and introduce phase shift to some degree. This means that you will never have a worst case scenario since that usually assumes perfectly stiff walls.
Also, for most people, their room is never ideal. It is usually compromised in some manner. That's ok, and with good speakers it is far less of a problem.
Edit: You deleted your post. That's too bad. I'll let my reply stand. Good luck.
I want to clarify something.Thanks for the links and the curves ! I've download rew, I can't find where are the curve data on WebPlot... i feel dumb on this
It is extremely useful when trying to compare graphs without having the underlying data.30.72523740954198, 71.07586571504096
31.216070912474738, 71.86888712661909
31.631083216544134, 72.61961406291303
32.31727859414681, 73.53423209093312
32.97167016973322, 74.51531286582832
33.567985751851246, 75.58022733280464
34.1267605147548, 76.44462067142479
34.580469937422485, 77.22971186888712
35.156098574577484, 78.04652392281258
35.899003894397254, 79.05366111551677
36.5770058548528, 80.11630980703146
37.30885243363565, 80.97277293153581
38.05534207579559, 81.92439862542955
38.81676776528755, 82.80200898757599
39.593428348200334, 83.69019296854349
40.38562865004844, 84.4832143801216
41.193679595410664, 85.14935236584721
42.01789832996242, 85.86835844567804
43.000353072590514, 86.62701559608776
44.15131811567122, 87.38831615120276
45.48301885263834, 88.1036214644462
47.16532205638333, 88.86069257203278
49.39672948426646, 89.58498546127413
52.59486801258821, 90.19777473385722
56.55752721145686, 90.56112272607119
60.818745348102894, 90.74856415062601
65.40101677161188, 90.80623843510442
70.32853062454834, 90.80623843510442
75.62729853391129, 90.7889361497609
81.32529192271991, 90.86102900535892
87.45258966707617, 90.85814529113499
94.04153687816495, 90.7456804364021
101.12691564737901, 90.68223872347585
108.74612865590655, 90.55535529762335
116.9393966180306, 90.60149472520607
125.74997060041382, 90.56689015451903
135.22436033817178, 90.50921587004062
145.41257975298112, 90.47461129935357
156.3684109692788, 90.47172758512966
168.14968822225305, 90.38521615841205
180.8186031563361, 90.36214644462068
194.44203312582576, 90.34484415927716
209.09189423068395, 90.30735587436618
224.84552095114256, 90.3217744454858
241.78607438514314, 90.4486578713383
260.00298124364707, 90.4774950135775
279.5924059211999, 90.41693701487517
300.6577581337441, 90.28716987479875
323.3102388034317, 90.20642587652898
347.6694270720704, 90.2525653041117
373.8639115419771, 90.20642587652898
402.03196907645497, 90.08530987912431
432.3222947431867, 90.10261216446784
464.89478675381577, 90.37656501574028
499.92139054327987, 90.8321918631197
537.5870064446906, 91.18112128421407
566.7507031482437, 90.7745175786413
581.9205843434946, 90.1401004493788
593.5638716717438, 89.42109436954799
607.4424725526637, 88.6333597673804
638.2848002542285, 87.81871049912287
679.6098683922995, 88.20116309807031
711.7624424080224, 88.86069257203278
735.6557487427687, 89.73565952947396
757.8447420631544, 90.57784826856992
798.9572576949589, 91.02540071612238
845.085805524593, 90.46259582342057
893.8776283972613, 89.67293874510369
961.2251195247906, 90.04493787998943
1026.8434616673533, 90.10485505330867
1075.42377507852, 89.2709489822892
1133.764717899293, 88.83954533439069
1191.3305690637262, 89.65635738831615
1251.8192728870656, 90.30158844591836
1346.1351889540044, 90.0391704515416
1447.557156362548, 89.53452046235552
1556.620566887227, 89.64121788864057
1673.90115036635, 90.11703073558743
1800.0180138958592, 89.78251988561267
1930.5307772869774, 89.15358181337564
2031.679774997449, 89.08802537668518
2109.1465872727213, 89.83558022733281
2223.5662265816245, 90.19777473385722
2391.0965483603304, 89.79405474250837
2571.2491200993704, 89.42205560762262
2764.974940951436, 89.31247446711365
2973.2966612717555, 89.38745103693557
3197.313981040179, 90.0420541657655
3438.2094550169927, 90.45442529978612
3697.254735277024, 90.2525653041117
3975.8172840755033, 89.93824045370438
4275.367592481867, 90.00456588085454
4597.486942887657, 90.13144930670704
4943.875756365659, 89.38168360848773
5281.3710259981235, 89.5761741122566
5641.9055188306575, 90.26986758945523
6066.984041662792, 90.02763559464591
6524.089288439536, 89.93247302525654
7015.634251094214, 90.21796073342466
7544.213723797569, 90.2958210174705
8112.618000497776, 89.96707759594358
8723.847604475215, 89.96131016749574
9381.129127667326, 90.16605387739409
10087.932263376853, 90.18335616273761
10847.988122276734, 90.13433302093097
11665.308928399298, 90.07377502222863
12544.209199081657, 90.39098358685987
13489.32852067356, 90.68223872347585
14505.656040237138, 90.78316872131306
15598.556802526598, 90.50056472736885
16773.80007127696, 90.33042558815755
18037.58978430599, 90.34484415927716
19332.659097916556, 90.81892677768967
20720.71226065064, 91.58195756133901
22281.874483305597, 91.99721240958355
23802.953816049223, 91.6908978764649
25427.870118982828, 90.89274986182204
27343.68409936028, 90.87833129070243
29403.841400284702, 91.42912070747123
31619.217291693487, 91.37144642299282
33666.36976740854, 90.6436690457309
35375.74844243762, 90.01774857444961
36684.20897212247, 89.36293946603226
37541.95237473621, 88.61749933914882
38293.10596875395, 87.81390430874967
38994.85901142889, 86.83320116309807
39448.110159246025, 86.14327253502512
40016.58412906126, 85.61459159397305
Longevity also don't seem to differ much, modern chips using in the low power range can survive decades, which outlast or is similar to electrolytic caps or so in the passive components, yes the exact DSP chip should be out of production by the time it breaks and passive parts can be repaired, but unless the speaker is spiritually connected to you I don't see how many ppl would try to spend megabucks on the restoration of old speaker when it breaks 20-30 years later, most just replace with some new toys.
WPD extracts data from images. I used Greenshot to clip the graph from the Adam pdf: https://www.adam-audio.com/content/...dio-monitor-measurement-report-v2-english.pdf
For the dsp part let’s think it this way and it will be easier to perceive:
Your pc supposedly have a lot more processing power than the dsp chip inside, but unless the speaker like the genelec 80x0 uses active analogue cross over (which is a chip without those dsp power), you have the limitation from the passive crossover and the tolerance issue of them, and you still get the digital induced latency and noise into the not completely noiseless passive crossover, so in reality there’s more issues combined, with unsure advantage
Don't jump fast from one solution to another. It'll end up costing you money.OK thk for answering. I as more talking about the evolution of connectivity that could make the integrated DSP lost his value. When an analogique system remain flexible, because minimalist
In addition the adam audio are linked to an external software provider : sound ID. My concerns are confirmed on this software, I'll talk about it below.
Ok thank you I will try the process. Not easy at the first approach
Ok I understand when you say that possive filters from the crossovers cause some noise. But can you explain what you mean about their « limitations » ? Aren't they limited to their widest possible operating range, by definition ? Or maybe you talk about the "cut frequency" management between 2 bands ?
About de double conversion DAC ADC DAC, we admit that it cause less degradation than passive filters. But we can admit that the speakers should be connected digitally to avoid this pointless double conversion ? If there would be no gain doing this in term of quality, there would be at least a gain in term of cost and relevance?
Problem of using SOUND-ID :
after the first impression, in which I really wanted to believe that it improved the sound, I had serious doubts. I re-recorded the already calibrated sound, and the result shocked me: sound-ID almost didn't change the curve !!!! The basses are worst !
Before :
After :
After several searches, I finally came across a youtuber who is not corrupted by big brand gifts and a minimum of independent. He comes to the same conclusion.
The good / bad news is that he manages to correct the curve using mini-DSP
Mini-Dsp : Blue Curve
Sound-ID : Green Curve
I believe him because I see the problem from my eyes
So tell me if I'm a bad conspirator or if there's a serious problem with this?
I will return my speakers and probably use HS8s with a mini DSP, or find out about such an efficient system without hardware.
If you are running Windows try Equalizer APO with the Peace interface. Or if you have a DAW then use an PEQ plugin on your master bus.
Try REW with your current microphone to assess room sound.
For bass, try the moving microphone method rather than a single sweep.
Ok it says the curve shouldn't be flat, related to how the curve generally leans towards the bass/treeble.This video is worth watching.
for active crossover advantages I think Genelec did quite well here: https://www.genelec.com/key-technologies/active-crossoversOK thk for answering. I as more talking about the evolution of connectivity that could make the integrated DSP lost his value. When an analogique system remain flexible, because minimalist
Before :
After :
not sure about Sound ID as I've never tried that, but from Adam's marketing webpage it seems Sound ID would instruct you to point mic to the acoustic center of both channels at quite a few spots around the listening position to create a profile for correction, I guess it's trying to not over correct and will depend quite a lot of points measured precisely for it to be useful, trying with a single point likely wont do muchOK thk for answering. I as more talking about the evolution of connectivity that could make the integrated DSP lost his value. When an analogique system remain flexible, because minimalist
Before :
After :
that looks quite ok actually, but in sound ID can you go with some target curve? this seems will sound a bit too brightOk interesting. FInaly don't think that the type of filters will be the most important argument for me.
For the internal DSP test and mesurement I did a big mistake. I disabled the DSP setting while unplugging the speakers.
SO I did it well for this time, and I can see Sound ID work.
Before :
After :
THe response is more flat. But there are less wide range.
