Absolute Polarity - Myth or "Important"?
  • Thread starter Deleted member 23982
  • Start date
KSTR
Berlin, Germany
Timbre change from polarity flip is readily audible to almost everybody with almost all music that contains asymmetric low frequency waveforms, like electric bass guitar. With speakers, with headphones, at any level, so distortion of the transducers is NOT a false clue.
Actually, I use polarity flip as my go-to warm-up test when doing ABX blind tests... on a bad day I may not get my ususal row of several 10/10 and then I know it makes no sense in proceeding.
EDIT: Snippet of one of my test tracks attached.
It is also well established for decades why we hear asymmetric waveform differently when polarity-flipped.
But a polarity flip also can have impact on soundstage impression (notably phantom source apparant size) and other aspects of reproduction.
How to check recording for "correct polarity"? With classical music or other stuff that was recorded pretty much directly from just a few microphones you may use segments with instruments soloing or standing out that have asymmetric waveforms, like trombone/trumpet... if you have a know good polarity reference track...
Bottom line: there is zero argument about this issue. The impact is small but undebatable. For most music recordings there is no correct polarity, so chose what sounds best to you, or simple don't be bothered. For classical there are lists where the polarity of many recordings is stated in case it still bothers you.
  • Lowlin(Snippet-Mono).zip
KSTR
Berlin, Germany
What is the easiest way to check polarity from digital file in the music player to speaker? I have no idea how the equipment changes polarity of the signal on its way to the speaker.
For multiway speakers with normal crossovers there is no overall correct polarity as the speaker rotates the phase all the time. You can only have restricted frequency regions where the polarity is right. Some manufacturers use the convention that the lowest way -- the woofer -- should have positive polarity (for less cumbersome integration with subs or other speakers in HT setups).
A step signal (signal going from 0 to 1, and back to 0 after about a second) is good test signal, if the cone goes outward the polarity is positive for the woofer.
A more general test signal that works at any (or a specific) frequency range is an asymmetric waveform, the simplest being a sine plus its second harmonic at a certain phase offset, and then check that with a microphone on an oscilloscope. How do you know the polarity of the mic is correct? Ballon (paper bag) explosion ;-).
There also are hardware devices the PA guys are using. Nowadays we even have phone apps for polarity checking but I haven't tested any of these.
solderdude
The Neitherlands
Blue is correct polarity? it looks a tad smoother around the "edges"
Blue is left, red is right channel.
Look at the scale on the left it is around -180 degrees.
The squarewave scope shots below are perhaps clearer.
Below the square waves from Edition XX (which are in phase)
Holmz
Australia
What are normal crossovers?
There were a bunch of speakers designed to have low order crossovers where the phase was not flipped along the stack of drivers.
In DSP land and active crossovers, it gets a lot easier.
Thomas_A
Sweden
Thanks. I am aware of the x-over part but was thinking that the 80 Hz-3 kHz region, midwoofer, should be in correct polarity. A step signal should be possible and look at the woofer movement. Will try someday.
KSTR
Berlin, Germany
Speakers with linear phase crossovers are few and far between, not more than 1% or so. "Normal" refers to what applies to vast majority (the definition of normal).
restorer-john
The polarity switch is also audible using headphones.
As in the activation of the switch? Sure, there will be a minor 'click' when a D/A converter inverts the polarity.
raindance
Usually a polarity switch on small signal gear switches in an extra amplification or buffer stage to flip polarity, and it can sound different because of the extra electronics in line with the signal.
restorer-john
Just throw a asymmetic clipped sine through your system and look at ('scope) the signal at the loudspeakers. Or an impulse.
If your system preserves absolute polarity, it will show. (doesn't mean that in can be inverted and inverted again all the way through).
I swear I've heard absolute polarity issues in the past, but with decent gear (speakers/headphones), and music, not test signals, it's really a non-issue for me.
Lambda
Are you saying you can listen to some music and say "oh this sounds like the phases is inverted"?
I can' t. but maybe you ears and especially your memory how it supposed to sound is better.
Also i can think this effect has to do with Asymmetrical non linear distortion.
In your speaker and also in your ear. so some ears have more Asymmetrical distortion than others.
in particular "Stiffness of suspension" eardrum is also not linear and symetrical.
KSTR
Berlin, Germany
Testfile of sensitivity to absolute phase and phase rotation.
If you hear a steady-state tone you're phase-deaf. If you hear a cyclic timbre change pattern you're not.
  • PhaseTest.zip
tuga
Oxford, England
With music that I am familiar with I can sometimes hear when polarity needs flipping.
Some tracks sound like they’re a bit congested and in my head (with speakers) and tonally somewhat off (mostly the bass).
tuga
Oxford, England
I had played with polarity inversion many years ago when I owned an Audio Alchemy 3-box CD player.
Recently I gave it another go with HQPlayer and was surprised by how much difference it makes with some tracks
D
Guest
Hi Guys
I’m not sure if this will help but it is to do with ‘phase’
Hope it helps.
Oh i have such a test track too for 3d spacing, its " Burn the Witch by Radiohead " really a good one to test for it with those "echo-effects", and yes phase had an impact to it too, tho for me its still a "general impact" that affects everything, more or less (with my speakers atleast)
i will give waterloo a go later too :)
Edit: if i would guess i would say the main vocals of waterloo sunset are with inversed polarity, is that right? (to create (or extend) this kinda "all over the place" effect)
Thomas_A
Sweden
Nope. I was referring to the signal itself.
Wolf
Indiana
A simple AA battery across rour speaker will cause motion of the woofer as it is not blocked by capacitance in most cases. Forward means the battery is correct, and reverse means the battery is in reverse. This gets the bass in phase with non-inverting gear.
An easy Impulse response measurement, with tweeter disconnected, will tell if the system/gear is inverting or non-inverting, once you've done the battery test.
Depending on the slopes and summation of the speaker xover, you cannot rely on the tweeter to be normal or reversed, as the connection is preferably whichever keeps the speaker in phase through the xover.
If you have a full-range single driver speaker, the impulse will tell you.
Even supposed 1st order inherent designs may have the tweeter reversed to get good summations due to the inherent tweeter rolloff being second order and 3rd order with highpass in place.
