Decided to try ABX'ing 24/96 vs 16/44 copies of Skyfall. These are as purchased, so not the 24/96 downsampled.
Foobar -> Cambridge Audio DacMagic XS -> Lexicon LEP1 IEM with stock filter (which is an AKG K3003)
At first, I couldn’t tell the difference at all doing the practice A and B. The DacMagic XS has audible hiss so it’s not the most transparent DAC but finally I was able to find a passage where there was a difference. This is where I had the songs looping.
A - feel the Earth move and *then*
B - feel the Earth move and then
A had a bit more attack, seemed a bit more emphasized whereas B was smoother. More “natural” possibly although I have never heard Adele live/unamplified to know what her voice truly sounds like. Even then, it often required 4 or 5 passes back and forth between X and Y until I could be sure.
By about half way through the test the ABX’ing got easier and I started to wonder which track was the high res track, A or B. I was blinded to the file names and I felt that there was a paradox. A seemed to have more detail but B actually sounded more natural in the sense that I felt as A was emphasized compare to B as opposed to B being subdued compared to A. Again, “natural” being an estimate since I don’t know what Adele sounds like in real life.
After a while, it was easy to detect the difference. Basically would just need XYXY and I would get it. But then it got a bit harder to hear the difference.
At trial 14, my wife asked me something. I took off my earbuds and when I put them back on, I just couldn’t hear a difference anymore. I took off my earbuds and put them back in. I then could hear the differences again but it didn’t seem as prominent of a difference as before and finished the test. I am not sure if there was a subtle difference in how the earbuds were put in my ear or if I lost my ability to discriminate the differences once I was no longer focusing on those six words from the song.
1) Differences are incredibly slight. I would not have found either rendition to be poor nor would I be able to identify the ABX if I only had one guess during testing.
2) Given the ability to click on ABXY as needed, not rushing, and only clicking when a difference wasn’t heard, it is possible to get good scores. At one point the differences seemed to be night and day but this wasn’t maintained.
3) Note that I said difference. At first I thought A was 24/96 since the sharper sound must be higher resolution but as I listened more, I thought that maybe it was aliasing and it was actually 16/44. In the end, I would still characterize them as different not good vs. bad
4) In any case, speakers offer the biggest difference. Get the biggest ones you have space for . Those are clearly different sounding.
Next step will be to try my Topping D50s and Geshelli amp to see if that makes it easier to distinguish between the two.
foo_abx 2.0.6d report
foobar2000 v1.6.7
2021-09-12 12:35:56
File A: 01 - Skyfall.flac
SHA1: 1c9672b1703fb51669dedfae655328bb574bb113
File B: 01-Skyfall.flac
SHA1: 8b3bdd707c075330b85a396a2e526292df3d894e
Output:
Default : Headphones (2- CA DacMagicXS 1.0) [exclusive], 24-bit
Crossfading: NO
12:35:56 : Test started.
12:38:42 : 01/01
12:40:02 : 02/02
12:41:01 : 03/03
12:41:51 : 04/04
12:42:14 : 05/05
12:42:44 : 06/06
12:43:13 : 07/07
12:43:31 : 08/08
12:43:51 : 09/09
12:44:10 : 10/10
12:44:26 : 11/11
12:44:47 : 12/12
12:45:22 : 13/13
12:45:34 : 14/14
12:47:52 : 15/15
12:48:37 : 16/16
12:48:37 : Test finished.
Total: 16/16
p-value: 0 (0%)
-- signature --
53d293236fdbf646a3dd2d0b61f9b4361602ef45
foobar2000 v1.6.7
2021-09-12 12:35:56
Output:
Crossfading: NO
12:38:42 : 01/01
12:40:02 : 02/02
12:41:01 : 03/03
12:41:51 : 04/04
12:42:14 : 05/05
12:42:44 : 06/06
12:43:13 : 07/07
12:43:31 : 08/08
12:43:51 : 09/09
12:44:10 : 10/10
12:44:26 : 11/11
12:44:47 : 12/12
12:45:22 : 13/13
12:45:34 : 14/14
12:47:52 : 15/15
12:48:37 : 16/16
Total: 16/16
p-value: 0 (0%)
-- signature --
