alessandro_28
- Joined
- Jan 25, 2023
- Messages
- 3
- Likes
- 0
Hello everybody,
I have a home studio in my garage (6.20x4x2.60 meters).
I did an acoustic treatment with DIY bass traps using rock wool with a density of 70 (120x60x8cm each).
I placed them at the points of the first reflection using the mirror technique.
I put corner bass traps in the corners of the room, from floor to ceiling.
I also put corner bass traps in the corners of the long sides of the ceiling.
And three panels in the ceiling above the monitors, using the mirror technique.
On the floor, some carpets cover almost the entire surface.
Behind me, on the left at the back of the room, there is a vocal booth made with rock wool and drywall (150x160x230cm); a small sofa is immediately in front.
The distance between the monitors (event tr8) and the wall (actually the bass trap panels) is about 50cm.
I also attached some photos and a video to show the situation better.
After taking measurements with REW and an ecm8000, I got scared.
Unfortunately, I don't have high acoustic skills, and I would like to ask you for help to try to solve this disaster as much as possible
ps_ Excuse my English, and if I forgot something or you have any questions, I will do my best to answer.
Thank you very much for your invaluable help
Ale
Ale
