dc655321
- Joined
- Mar 4, 2018
- Messages
- 1,597
- Likes
- 2,236
I use mainly 12th order LR 96 dB/oct (linear phase)
12th order would be 72 dB/octave, no?
Yep. Meant to say 16th order. Thx for the catch.12th order would be 72 dB/octave, no?
Wow, this is the steepest I've heard any designer go. I'm guessing that this is all DSP active? Hard to imagine building such slopes in the analog domain.
Why do you need to do such steep slopes?
Which tools give you such slopes? I've seen support only for about 8th order in most tools.
I've played alot with this. I'm not willing to say higher order linear phase sounds better than lower order IIR, all things equal....and both setups perfectly aligned.Do you have any thoughts about lower order xo sounding different from higher order?
Understood. Thanks a lot. I have never dabbled in FIR, because I don't know anything about it, like a lot of novices who enter the DSP domain from the analog side. I'll need to read up I think.Yep. DSP active. FIR.
Even if such a high order could be done in the analog domain, I'm pretty sure the phase rotation and impulse response destruction make it a non-starter.
It's much easier to get the critical xover region well behaved, the region of summation between drivers (like -20dB used in the examples i gave).
Easier because the driver has less of a frequency range past the xover freq, that needs to be managed.
Most of the time, a driver is already rolling off response near xover. So having to deal with less rolloff by narrowing the range is a plus.
It also helps reduce lobing, simply because the width of the critical region is narrower. The two drivers summing have less of a freq range for polar triangulation issues.
Any FIR based platform...PC, or hardware like some of the miniDSPs, and lot's of other speaker management processors.
I'm using QSC's Qsys platform which has both FIR and IIR. It's a bit unusual in that it allows 16th order IIR, but like said above, such high "analogish" orders are a non-starter.
I am willing to say the odds of getting high order linear phase perfectly aligned are way, way, higher...
and for me have resulted in better sound.
Maybe this will help.
Using rePhase to plot electrical xovers of different orders, using electrical as a surrogate for the purpose of determining how wide is needed acoustically.
Here's a 2nd order LR 12 dB/oct @ 300Hz. (ignore the horiz dashed-red phase trace, xover is lin phase)
If we want smooth summation to say -20bB,
that looks like the low-passed side needs good performance down to 100Hz,
and the high-passed side to 900Hz.
Here's 4th order LR 24/dB/oct @ 300Hz.
If we want smooth summation to the same -20dB,
that looks like the low-passed side needs good performance down to 175Hz,
and the high-passed side to 515Hz.
I use mainly12th16th order LR 96 dB/oct (linear phase)
Same -20bB,
which gives low-passed side needs good performance down to 350Hz,
and the high-passed side to 250Hz.
(Achieving steep complementary linear phase acoustic offers considerable latitude in choosing xover points.)
Hope that helped.
That's a somewhat illegal comparision. It has nothing to do with speakers being speakers. The reason for the way most (not all) speaker step responses look like is the allpass (excess phase) contribution to the "default" shape, the latter being governed by magnitude frequency response, notably the roll-offs at either end.Compare measured impulse responses from some loudspeakers and you will see that all of them have an impulse response that looks terrible compared to any filter commonly used in loudspeaker crossovers, digital or analog.
Good paper thx, ....and good commentsIIR (and analog) filters can be made linear phase, too, in a limited bandwidth (by adding in allpass cascades with peaking group delay that sums up to a mirror image of the main group delay) and these again have, and must have, delay ... but no extra processing delay. Yet this delay of allpass corrected filters is larger than required because of the base delay below the frequencies of interest.
See here, Figure 6, on how this looks like in detail.
Yes, it makes tying drivers together much easier. I often have over an octave's width of room to choose xover frequency.Interesting approach indeed. Slopes of 96 dB/Oct would allow for blending almost any combination of drivers there is.
The linear phase xovers have solved (for me) the transient response degradation issue with traditional higher order analog or IIR xovers.Since you experimented on the subject... Higher crossover topologies should suffer from worse transient response. Is it also the case with a linear phase crossover? Are there any drawbacks you've noticed?
What do you mean by "complemetary linear phase XO"? Symmetric shapes/slopes (of the final acoustical target)?A 2nd is potential pre-ringing. My experience has been, if fully complementary linear phase xovers are used, they generate no pre-ringing.
I consider fully complementary a must.
Off-axis I've always seen residual pre-ringing as the summation of the individual drivers degrades by time-of-flight differences and non-identical directivities.
For me the objective has been to minimize the range of the critical summation region between driver sections.As for slopes, I prefer steep (or even infinite) final slopes but a very gradual transition region, like lower order Neville-Theile.
I routinely get measurements with this kind of look for whatever reference axis is chosen to tune to, ie directly on-axis or say 10 deg off-axis.
Of course the measurements don't display the same perfection awayf the tuning axis, but polars are still quite a bit better than most of the on-axis results we see posted. This is 3-way main from 100Hz up without a sub, using 96 dB/oct linear phase xovers.
The transient response is remarkable.
Drawbacks:
First is the processing delay of FIR, when used as linear phase.
The above impulse used about 43ms. If phase linearization extends down into sub territory, i typically use about 170ms of "FIR time".
It's also best to use a minimum phase high-pass on the sub, if a high pass is needed, to avoid potential pre-ring. So an extra complication, but any processer capable of that much FIR will also have the IIR capability for this task.
Which brings up a third drawback, the cost and complexity. The complexity and cost from an amplification/processing channel count point of view, i think is the same for a normal multi-way active. FIR is a little more costly, in that it takes either a very robust speaker processor, or integrating a PC into the line level signal flow. And perhaps more complicated in that extra knowledge needs to be acquired.
But my experience is, if folks more only knew how much vastly easier xovers are, and speaker tuning in general is, when using steep linear phase xovers,
well....i think they would change their minds about what's complex and what's not.
Do you also use such steep filters when adding in a sub(s)? What do you think about broadly overlapping xo in the bass/sub region? I’m just curious because I’m overlapping mine with the mains.
Indoors is tougher for me to make a call...we all know the low freq soup/mud we hear in a room huh? Hence the whole multiple sub thingy that works for a lot of folks, i guess.
I've designed and built a few active crossovers in my days ... NO OpAmps do not degrade the signal in any audible way. Take a look at the manufacturer's spec sheets ... you will find that with unity gain filters you are looking at frequency response practically from DC to a couple of hundred kilohertz and probably at distortion levels in hundredths of a percent. You won't get it that clean with transistors and absolutely never with tubes.They even sell the PCBs, great. Just what I was looking for. Thanks everyone for help!
One more thing for the end, since I started with op amps... Is it worth investing a lot into discrete op amps and what are good ones to look for?
I take it your phrase 'no opamps do not degrade' means they don't make an audible difference.I've designed and built a few active crossovers in my days ... NO OpAmps do not degrade the signal in any audible way. Take a look at the manufacturer's spec sheets ... you will find that with unity gain filters you are looking at frequency response practically from DC to a couple of hundred kilohertz and probably at distortion levels in hundredths of a percent. You won't get it that clean with transistors and absolutely never with tubes.
Still based on your writeup... I would suggest the MiniDSP modules, as the others did. If your needs change, you can simply reprogram and carry on... not so easy with hardware only solutions.
I went with a mini dsp product, but I really wanted something that doesn't produce a completely new signal. Still in the works, a basic 2way xover.
So far, 7 op amps, but I might ditch last two (output signal 'gain')
You should use these as unity gain output buffer amps.I might ditch last two (output signal 'gain')
I would keep the last two op amps.... being able to adjust the output level of an active crossover can come in VERY handy.So far, 7 op amps, but I might ditch last two (output signal 'gain')
