It is a very different way of thinking about things… you no longer set crossovers at all. Instead…So the ART signal is separate from the main signal?
Can I select a frequency interval for ART and a crossover point for bass management seperately?
I might want to have a different crossover for the main signal and the ART sounds which apparently are a lot lower in level and wouldn’t cause issues with smaller speakers as deep bass from the signal of that channel would do.
-You decide what speakers you want to be included in ART
-You decide the frequency range you want those speakers to be used for ART. Dirac will have its suggested range,but you can over ride it with whatever you want. For example if you have a surround speaker that is measuring down to 40hz in room, but you don’t want it playing anything below 80hz, you have that control.
