Adam S2V Studio Monitor Review
This is a review and detailed measurements of the Adam S2V Professional Studio Monitor (powered speaker). It is on kind loan from a member. The S2V costs US $1,750 (each, NOT a pair).
This is one beefy, heavy and deep bookshelf speaker:
Yes, the cone was a bit dusty. :)
The back panel shows the inputs and output plus user interface:
Adam S2V Monitor Powered Studio Speaker back panel controls connectors Audio Review.jpg
We are now at a price point where digital input (and pass-through) are provided. I used analog input however for my testing.
There is an OLED display which while small, is workable. What is not workable is the non-intuitive user interface involving that clickable rotary encoder. Even after reading the manual and watching a video, I still could not figure out how to interact with it. I was however able to select Analog input with Pure mode which is the factory preset for "flat" response.
There is a USB connector for PC control. Went to download the app but it asked me to register. Fine, I do that. But then it wants the serial number. I gave it the serial number and if of course tells me it is in use. :( Do they think no one ever sells these speakers? Being smart, I put in a random serial number and got through. :D
The app was much easier to use but still has issues. None of the changes you make take effect. Good test to see if you are subject to placebo! You have to hit the grayed out "store" or "write" to get them to take. And that takes 5 to 10 seconds and involves some ticks and pops and fade up. Shame as the filters in there would be great for quick fine tuning and lowering room modes.
Measurements that you are about to see were performed using the Klippel Near-field Scanner (NFS). This is a robotic measurement system that analyzes the speaker all around and is able (using advanced mathematics and dual scan) to subtract room reflections. It also measures the speaker at close distance ("near-field") which sharply reduces the impact of room noise. Both of these factors enable testing in ordinary rooms yet results that can be more accurate than anechoic chamber. In a nutshell, the measurements show the actual sound coming out of the speaker independent of the room. All measurements are reference to tweeter axis with the grill removed.
Over 1000 points around the speaker were measured (from 20 to 20 kHz) which resulted in well under 1% error in identification of the sound field emanating from the speaker. Resulting database is 1.3 Gigabytes in size.
Spinorama Audio Measurements
Acoustic measurements can be grouped in a way that can be perceptually analyzed to determine how good a speaker can be used. This so called spinorama shows us just about everything we need to know about the speaker with respect to tonality and some flaws:
Adam S2V Monitor Powered Studio Speaker Spinorama CEA2034 Audio Measurements.png
I know, I know. You think that step deep is because the speaker went into compression. Not so. The levels were already lower than what I use with passive speakers. But to stay on the safe side, I ran the entire ~3 hour measurement at less half the level and got the identical outcome. Levels were extremely low in the second try and the shelving behavior was there. The frequency is too low to have anything to do with directivity. I suspect this is a correction curve applied to the speaker on purpose, hoping that the room gain fills in the rest. What I can't explain is the anechoic chamber Adam provides:
Interesting enough though, we see a variation in response at the same point I measured a rise in response. I wonder if they used some kind of near-field curve to stitch here and the gain level is wrong there. They do show a tilt up the same way I have it at higher frequencies.
I plan to contact Adam and see if they have an explanation. And am open to suggestion and comments you may have on what may be going on.
Back to measurements, the crossover is at 3 kHz but you can't see it in the response curve which shows excellent blending of the two drivers. Likely DSP was used to fully correct the response but we take it however it comes.
Interestingly enough, the predicted in-room response is very good:
Adam S2V Monitor Powered Studio Speaker Spinorama CEA2034 Predicted In-Room Response Audio Mea...png
So that in-room shelving may be correct on-axis. We still have a dip though around 200 to 500 Hz so bass performance will still be a bit light.
That's it folks. The rest of the show is for people who want to dig really deep.
Advanced Speaker Measurements
Here is our zoomed in directivity:
Adam S2V Monitor Powered Studio Speaker Spinorama CEA2034 directivity Audio Measurements.png
We some error around the crossover area (3 kHz to 10 kHz) so a bit of room sensitivity is to be expected.
Adam S2V Monitor Powered Studio Speaker Spinorama CEA2034 Early Window Audio Measurements.png
The manual systems to get rid of all reflections. Above graphs says be careful in doing so. They are balancing each other out to give a very smooth curve.
Adam S2V Monitor Powered Studio Speaker Spinorama CEA2034 Horizontal and Vertical Audio Measur...png
Adam S2V Monitor Powered Studio Speaker Spinorama CEA2034 Full Horizontal and Vertical Audio M...png
Eye-candy Speaker Measurements
Here is our contour plots which agree very well with the manufacturer measurements (theirs is much lower resolution):
Adam S2V Monitor Powered Studio Speaker Horizontal Directivity Contour Audio Measurements.png
Adam S2V Monitor Powered Studio Speaker Vertical Directivity Contour Audio Measurements.png
Here is the company waterfall:
It is interesting in that it also shows the shelving response (top of the waterfall) which we have measured!
Speaker Distortion Measurements
You can see the true SPL levels in my first measurement presented above:
Adam S2V Monitor Powered Studio Speaker SPL and Distortion THD Percentage.png
If one believes above, it is very low level of distortion.
Listening Tests
I didn't have time for extended listening and comparison. I had the cheap Pioneer SP-BS22-LR on the right and the Adam S2V on the left. Levels roughly matched, the Pioneer definitely had more bass. That is, until I increased the volume a bit and it fell apart while the S2V powered on with authority. So subjectively seems like measurements were correct in bass being low on purpose. To wit, I changed to second factory house curve mode on S2V and bass came in with vengeance.
Overall, the Adam S2v is very listenable. I would of course EQ that shelve out to get the bass where it needs to be.
The Adam S2V is a serious monitor with seemingly good design. The low bass probably has an explanation that we can find. Or else easily correct with an EQ (including the one built into the speaker itself). The S2V was the first powered monitor I have tested so far that did not run out of power. Nor sounded like a little point source.
I am going to put the Adam S2V on my recommended list.
My wife is out and called to see if I want her to pick up something for dinner. Feeling quite poor, I suggested Kentucky Fried Chicken (KFC). Not looking forward to soggy chicken by the time she arrives but this is all I could afford. Please donate a few dollars so I can have better dinner tomorrow night using: https://www.audiosciencereview.com/forum/index.php?threads/how-to-support-audio-science-review.8150/
mhardy6647
Do "we" think the AMT driver in this monitor is the same as or different than the one in the B652-AIR?
ATTACH]
Doodski
Good review @amirm & nice speakers too. For the money some grills would be nice for when eating wet pasta at the desktop ;)
digicidal
Sin City, NV
Is that for a pair or each?
Each.
I'm reasonably sure that anyone forking over the cash for these monitors is not likely to eat wet pasta while mixing... and for everything else there's stands. ;)
majingotan
Laguna, Philippines
Yes, Is that each? I found them in Canada for $2359.00 but the retailer's web page does not indicate quantity.
EDIT:
wowowow $4718.00 per pair in Canada
Don't forget to add two of these for stereo sub as well. Price is in USD so it should be around ~2700 Canadian dollars
stunta
Boston, MA
Ehmm, Mr. Modesty, you do realize this is combination of you being smart and they being stupid? :facepalm:
Re: price, this is almost ATC level pricing. Would love a comparison.
Doodski
I heard the A7X and thought they sounded just fine, but nothing leapt out at me.
I was thinking how good can a 7" woofer plus a tweeter sound compared to something larger but then for mixing I suppose they need smaller speakers and these solve many issues, 350 watts amplification each is included, USB PC front end software and a claimed SPL of up to 120dB per pair.
napilopez
NYC
The price stings but I'm glad you aren't sacrificing sound quality for it! As is often the case in hi-fi speakers.. Seems like a great speaker. Wouldn't have thought the bass is from compression give where the shelving is. On the wide directivity side of the spectrum while maintaining good control around the crossover.
Ilkless
Singapore
I'm surprised they managed to cross at 3kHz without a dispersion mismatch despite the large woofer. That's a well-designed waveguide right there. Many dome tweeter waveguides cross an octave lower to match dispersion. Also means the midwoofer is one well-behaved midwoofer. Now I hope we get to see NFS graphs of the HEDD Type 07, with a similar form factor.
Yeh, I kept checking and double checking that the crossover is 3 kHz.
H
Hifihedgehog
Guest
Superb review! Expected no less from Adam after using my A7Xs. Incidentally, this industry professional with the credentials below is a unabashed Adam acolyte:
My near-field monitoring experience (from working in other recording studios and ownership of my own) range from ADAM itself, Genelic, Bowers & Wilkins, Yamaha (I still own an original set of NS10m monitors paired to a Bryston amp as part of reference use), Event (still own), Tannoy (still own), KRK (still own), JBL (still own), Meyer Sound, Fostex, and a slew of others I can’t recall from various studios stemming back to the 1990’s. I’ve also done feature film work at a small place called Dolby Laboratories and production work at another small place called Skywalker Sound.
napilopez
NYC
Indeed, I'm a fan of well-implemented small/shallow waveguide speakers. No crossover dip in the horizontal data, no bunching and even the vertical isn't too bad, but maintains wide directivity despite needing to cross with a largish woofer.
