Adam t5v OR Genelec 8010A? Small Studio Space
devinpickering
Hi there - I'm wondering if a pair of t5v's or a Genelec 8010A's would work better for a small recording/performing space? What do you think? I've found a few more generic wall mounting options for the t5v's but they're not exactly the best option, wall mounting would save a lot of space for me so just one more thing to consider... really appreciate the advice thanks.
D
devinpickering
How small is the space?
basically, the corner of a small living room, measures approx. 6ft between speakers. Concept photo attached:
Digby
Have you listened to both? They likely have a different sound profile, I'd try listening to them both before purchase, if possible.
Lilith
I would check the IKM MTMs or the ilouds micro. T5V is deep (~28 cm).
