Yes that is the AmpI'm guessing this is the amp you are using. The GFA-555 II.
So in series I would put the two positive wires together and the black wires together and hook them to the power amp?Yes, you can wire the 2 pair of speakers in a series configuration. You have lots of power available and the new Klipsch Heresy are rated for 8 Ohms.
It's that or get a 2nd amplifier for the 2nd pair of speakers.
No, do not do it that way. Do it like the diagram shows. It's all there. This diagram is for one side at a time.So in series I would put the two positive wires together and the black wires together and hook them to the power amp?
Ok got it .Thank you so much for the information I really appreciate it!No, do not do it that way. Do it like the diagram shows. It's all there. This diagram is for one side at a time.
Thank youand... you'll need a 1.5 volt battery to connect to the speakers to ensure they are in phase with each other. That is if they are different model of speakers. Powering the speaker with the battery should produce the same in/out response in each speaker.
? I understood the wiring and series resistance, I don't understand this.and... you'll need a 1.5 volt battery to connect to the speakers to ensure they are in phase with each other. That is if they are different model of speakers. Powering the speaker with the battery should produce the same in/out response in each speaker.
