Advice for beginner
SlimlShady
Hello everyone.
After all I would like to congratulate everyone who contributes to this forum, even as a begginer I can spend hours reading and learning.
I want to buy a "setup" to my living room, I mostly listen to music (CD and spotify) at medium level and I wanna use it as home theater also. My budget is 800/900 euros, and I'm currently living in France.
Hope you can help me, thanks in advance
voodooless
Netherlands
What do you already have? Do you want surround for your HT? Do you need Blu-ray?
S
SlimlShady
I have the Denon D-M41DAB, but I'll use it in another room. I would like to play directly from the TV and I have no need for surround.
voodooless
Netherlands
So basically you have nothing. For CD’s you’ll need a CD player. Anything halfway decent that does not skip will probably do. Some second hand unit will save some money for speakers. Make sure it has digital out. That leaves pre-amp, DAC and speakers. Here you can go various ways, buy separate components, or look for an active speaker system with volume control and digital input.
Since you are in France, check out: https://www.audiophonics.fr/
Or these JBL’s: https://www.jbl.com/studio-monitors/306PMKII-.html couple with a cheap DAC like topping E30, and a CD player and you have a complete system to start with. Also reviewed here: https://audiosciencereview.com/forum/index.php?threads/jbl-306p-mk-ii-review-studio-monitor.18505/
abdo123
Brussels, Belgium
Since you're in France, I would go with the Revel Focal Aria 906 (French company).
Loxje A30 for amplification, volume control and DAC.
Raspberry pi 4 (for streaming) feeding the Loxje over USB.
Helicopter
Michigan
^This. Focal Aria 906 or Chora 806 and Loxjie A30.
I am running Arias with an A30 and they are great.
HiFidFan
U.S.A
I really like this recommendation. Except it blows the OP's budget.
HiFidFan
U.S.A
Aren't the Focals like $2k / pair?
HiFidFan
U.S.A
Wes
you could rip your CDs onto your computer and play from there
S
SlimlShady
Thanks for all the replies.
The options you gave me till now are something like this:
- 2x JBL 306p Mkii ~ 330 Eur
- Topping E30 ~ 130 Eur
- CD player (really don't know which to chose)
or
- Focal Aria 906 ~ 800 Eur
- Loxjie A30 ~ 160 Eur (never in stock)
- Raspberry pi 4 ~ 100 Eur
My questions are: should I make an effort and try to invest in a setup like the second, will the difference be noticeable? Is there an equivalent alternative to the Loxjie?
Unfortunately I can only try the focal one's at a close dealer, jbl's are not very common in here.
voodooless
Netherlands
While the speakers might be better, the amp is quite a bit less powerful. That might impact dynamics. On the other hand, you could leave that for a future upgrade.
abdo123
Brussels, Belgium
or
The Loxje should be in stock in April, based on their website.
I would invest 90% of my budget on speakers. As long as the other 10% is well spent.
Helicopter
Michigan
Are you using BT for Spotify, an analog connection, or a digital one?
Is the audio out of the TV Toslink or does it have RCA analog outputs?
Just thinking whether SMSL SA300 or Yamaha RS 202 might be alternatives to the Loxjie.
S
SlimlShady
Spotify over BT or Wi-Fi and TV over Toslink
S
SlimlShady
Are the Focal one's a good buy for the money? I read the great review, just wondering if there would be something similar.
abdo123
Brussels, Belgium
The Elac Debut reference 62 and the other Revel speakers measured on this forums are really good alternatives. But personally i would get the Focal aria 906 even if i had to squeeze or wait a bit.
