- Joined
- Oct 25, 2019
- Messages
- 11,126
- Likes
- 14,798
Jimbo and Helicopter, I agree with both of you guys. Thankfully, no toddlers here, and none intended. We take great care of our HiFi gear. So even if someday we had amps with 4.4mm ports, it would still be OK. Why ? Because we intend to leave the interconnects permanently plugged to the amps (and never on the floor of course). Only the headphone cables will be plugged/unplugged every time. That is where we need the sturdy connectors... hence the mini-XLR.
I also want the connectors that are permanently plugged into the amps to be angled, to avoid accidents. That's why interconnects like these ones look great to me :
Last but not least, I have discovered that there are now modular multi-connector systems that would solve all the typical issues. Unfortunately they're really expensive, even in AliExpress.
Take a look at this one : https://www.aliexpress.com/item/1005001463529250.html . It looks nice because you can easily switch from balanced 4.4mm to balanced 3.5mm or to unbalanced 3.5mm, but... 41 € for three connectors ?
There's also this one : https://www.aliexpress.com/item/32839690851.html . Pretty much the same... and even more expensive.
And there's also nice adapters like this one (DJ44C - 3.5mm unbalanced male to 4.4mm balanced female) : https://www.aliexpress.com/item/4000672404478.html . "Only 24 €" for a damn adapter And we would need two of them if we decided to go A50s. So, even more money : more expensive amps, more expensive balanced cables, plus adapters. It's not reasonable.
You'll need 4 pin mini xlr for balanced of course. Which I think exists (?)
