Advices about Digital Input
bartgign
Hello !
I have curently this set up :
Intel NUC (with Daphile) -> Gustard X16 -> Gustard P26 -> DCX 2496 and three power Amp (one Yamaha P7000S, and two Yamaha P2500S -> DIY Speakers.
I think it may be a best solution to use AES input on the DCX 2496.
Which digital board, with an AES out, could be a good solution between the NUC and the DCX ?
Thanks a lot for your advices !
Cédric
TimW
Seattle, WA
Hello !
Cédric
I use a Behringer SRC 2496 to convert from SPDIF to AES. I also have a miniDSP OpenDRC-DI that can do that along with DSP filters and volume control. That's not really what you're looking for though.
For simple USB to AES converters here are a few options:
Matrix Audio X-SPDIF 2 which isn't cheap but looks well made and designed.
Gustard U16 which matches your X16.
Here's a few more options from Audiophonics.
There's also more pro oriented options from the likes of Yellowtech and others.
B
bartgign
Thanks for your answer. I think a miniDSP OpenDRC-DI could be a good option, i may try it to compare with my actually analog input set up. I need a control volume, its easier for me, with a remote.
May be Mini DSP OPEN DRC-DI will be my choice !
TimW
Seattle, WA
Keep in mind that the USB connection is only for changing DSP settings, you will need a SPDIF source for audio.
B
bartgign
I cannot use the USB to link my NUC in the Mini DSP ?
B
bartgign
Thanks. Very good unit this Mini dsp. But very expensive to do this.
I Just need an USB audio In, an AES out, with maximum transparency and a volume contrôle.
Or May be a control volume with the NUC but Daphile cannot. May be another player ? Dont know.
AnalogSteph
.de
According to installation instructions,
If you are using an audio device that is connected to speakers without an external amplifier you must turn on the “Settings → Audio Devices → [audio device] → Volume control” setting. With default value “Off – Bitperfect playback” you might even destroy your speakers if there isn't any volume control.
I think this might expand your choices just a bit... someone writes it'll work with a DCX.
BTW, something else I might consider...
B
bartgign
Difficult to find, any another idea, i don't want a DCX modification, and with this SPDIF / AES some coments are bad.
mdsimon2
Detroit, MI
mdsimon2
Detroit, MI
I also need a volume control ?
Sorry I missed that you cannot do volume control in the NUC. You could also do a miniDSP 2X4HD and use the I2S outputs in to an I2S to AES board. That would give you volume control in the miniDSP. I am not sure if there are any other cheaper USB to I2S interfaces with volume control.
Michael
